Chaos Lord Tom Posted June 27, 2017 Share Posted June 27, 2017 Hi, sorry if this question was already raised and answered. Canis Wolfborn gives 6'' close units the ability to re roll to wound rolls of 1 (Champion of deathwolves rule) His wolfclaws allow you to reroll failed to wound rolls Here's how I see this : I roll to wound a 2 when I needed 3+ then I apply wolfclaw rule. Second roll is 1 then I can apply Canis' rule to reroll. I roll to wound a 1 then I apply Canis' rule. Second roll is a 2 (+3 needed), I then reroll thanks to wolfclaws. Am I correct ? Link to comment Share on other sites More sharing options...
joschlumpf Posted June 27, 2017 Share Posted June 27, 2017 You can only reroll once. If you apply one rule and reroll you have to go with the second roll Link to comment Share on other sites More sharing options...
Halandaar Posted June 27, 2017 Share Posted June 27, 2017 You can't use both, so you'll have to choose to use the re-roll that is most appropriate for the situation. Core rules, page 4: You can never re-roll a dice more than once Link to comment Share on other sites More sharing options...
