CarbonBased Posted June 30, 2017 Share Posted June 30, 2017 Hello all, Now that landraiders and other models that have been collecting dust are worth using, I need to get rid of all that dust. Does anyone have suggestions on the best way to clean off years of dust from models in various states of paint/unpaint/painted but not sealed? Here's a for instance http://i.imgur.com/wZeVgB8.jpg?1 Thanks in advance! Link to comment https://bolterandchainsword.com/topic/335915-best-way-to-clean/ Share on other sites More sharing options...
NovemberIX Posted June 30, 2017 Share Posted June 30, 2017 I generally use a can of compressed air and that works well enough, but if it's really stuck on, maybe a cotton swab with warm water followed by a dry cotton swab to sop up any left over liquid. CarbonBased and Bryan Blaire 2 Back to top Link to comment https://bolterandchainsword.com/topic/335915-best-way-to-clean/#findComment-4803389 Share on other sites More sharing options...
BadgersinHills Posted July 1, 2017 Share Posted July 1, 2017 (edited) I've had success running dusty models under some cold water. It removes most of the dust in a matter of seconds, and doesn't affect the paintjob or the model. Edited July 1, 2017 by Ashenwyte CarbonBased 1 Back to top Link to comment https://bolterandchainsword.com/topic/335915-best-way-to-clean/#findComment-4804166 Share on other sites More sharing options...
Kinstryfe Posted July 1, 2017 Share Posted July 1, 2017 Old but still soft large brush and clean water to dampen it. Have done it in the past , ironically with a raider as well. And now should do it again. CarbonBased 1 Back to top Link to comment https://bolterandchainsword.com/topic/335915-best-way-to-clean/#findComment-4804168 Share on other sites More sharing options...
Subtle Discord Posted July 1, 2017 Share Posted July 1, 2017 My go-to model dusting solution is a 2" paint brush with natural bristles; a moderately good quality wall paining brush that you can get at any hardware store. The key factor I've found is the natural bristles. They taper down to very fine points better then most synthetic bristles, and that lets them get into even the tightest nooks-and-crannies and physically scrub dust particles free that might resist a blast of air. Additionally, the fine tapered bristles are very forgiving, bending easily even if you're aggressively removing dust, with no chance of harming details or in-process paint jobs. Be sure to clean it once-and-awhile to remove any oils or dirt that might build up over time, but otherwise I find it works well dry, applying just enough scrubbing action to remove the dist and nothing more. Note: it is best to do dust removal outside if you can, especially if the layer is substantial. If you knock it off and back into the air, at least some of it will end up back on your work. Remove it completely from your environment; dust is inevitable, but you can do things to reduce and minimize it. Link to comment https://bolterandchainsword.com/topic/335915-best-way-to-clean/#findComment-4804893 Share on other sites More sharing options...
GawFang Posted July 1, 2017 Share Posted July 1, 2017 My models mostly live in their gaming cases to avoid the dust but when I do need to remove it I use a big soft brush like Subtle Discord does. Link to comment https://bolterandchainsword.com/topic/335915-best-way-to-clean/#findComment-4804974 Share on other sites More sharing options...
