Emperor's Furor Posted July 1, 2017 Share Posted July 1, 2017 So I did a test model today of the Star Phantoms and I think it came out pretty well but was wondering if you had any tips to make it look crisper. I did it from a black base. http://i.imgur.com/d09NYUN.jpg Link to comment https://bolterandchainsword.com/topic/335974-tips-on-painting-white/ Share on other sites More sharing options...
Master Commander Ajax Posted July 1, 2017 Share Posted July 1, 2017 To start with I'd advise that you switch your undercoat from a black to grey. It looks like you may have used a black wash to shade the armour aswell? It's kind of hard to tell from the pic. Link to comment https://bolterandchainsword.com/topic/335974-tips-on-painting-white/#findComment-4804777 Share on other sites More sharing options...
Brother-Chaplain Kage Posted July 1, 2017 Share Posted July 1, 2017 Use rattlecans or an airbrush to get a smooth base coat. For either method, prime the figure in several thin coats of black, making sure you get good coverage, and then do the same with white primer to get a bright white finish. Kierdale 1 Back to top Link to comment https://bolterandchainsword.com/topic/335974-tips-on-painting-white/#findComment-4804831 Share on other sites More sharing options...
Kinstryfe Posted July 1, 2017 Share Posted July 1, 2017 Very thin paints. White's a tricky pigment and can get sticky and weird pretty quickly if it's too thick and doesn't dry right. Limit your shading as it will stain a lot. Thin shades a LOT before use, you only want the pigment where it needs to be. Grey shades can be a lot more effective than black. Personal preference: use white-white only for the highest highlights. I Use off white (I use pallid wych flesh) for the bulk of the painting, and only use true white for very sparring highlights. Also, practice. Like yellow, it can take a good bit of experimentation to figure out what works for you. Master Commander Ajax 1 Back to top Link to comment https://bolterandchainsword.com/topic/335974-tips-on-painting-white/#findComment-4804838 Share on other sites More sharing options...
sockwithaticket Posted July 1, 2017 Share Posted July 1, 2017 If starting from black, get yourself a decent grey basecoat to start with.I go with Vallejo Stonewall Grey, then cover that with with Vallejo Ghosty Grey, then Reaper Master Series Pure White, then Vallejo Model Colour White. I go back and shed where necessary using the two greys in the basecoat process.The key once you get to the white itself is thin layers and patience.Looks like this:HOWEVER, if your models are going to be all white you probably want to prime grey or white. Also if you want the blackline look and have a steady hand, painting black into the recesses rather than using a black wash can be a less messy process. Kierdale and Master Commander Ajax 2 Back to top Link to comment https://bolterandchainsword.com/topic/335974-tips-on-painting-white/#findComment-4804844 Share on other sites More sharing options...
Emperor's Furor Posted July 1, 2017 Author Share Posted July 1, 2017 (edited) I used watered down dawnstone grey for the shading, I tried to limit the white over it but if I did to much I used the watered down dawnstone to correct it. I may not go with white, I want a really nicely painted armour for once and I think I should stick to simpler colours. Edited July 1, 2017 by Emperor's Furor Link to comment https://bolterandchainsword.com/topic/335974-tips-on-painting-white/#findComment-4804867 Share on other sites More sharing options...
Ciler Posted July 2, 2017 Share Posted July 2, 2017 Check Duncan's tutorials on warhammertv on youtube, there's a number of them on painting white. As a general rule, white is never achieved with actual white paint because it can't be highlighted. More often, it's a combination of light shades of grey and pure white highlights. Link to comment https://bolterandchainsword.com/topic/335974-tips-on-painting-white/#findComment-4805289 Share on other sites More sharing options...
Redking Posted July 3, 2017 Share Posted July 3, 2017 Check Duncan's tutorials on warhammertv on youtube, there's a number of them on painting white. As a general rule, white is never achieved with actual white paint because it can't be highlighted. More often, it's a combination of light shades of grey and pure white highlights. This. I just painted an apothecary using Duncan's video as a guide. White primer, Ulthuan Grey, shade with Russ Grey, White Scar highlight. I probably would have added another layer of an Ulthuan/Scar mix before the edge highlight. Agrax or Nuln Oil can give a different look instead of the Russ. I've been considering a Phantom army, but the white has been keeping me away. Good luck. Link to comment https://bolterandchainsword.com/topic/335974-tips-on-painting-white/#findComment-4806362 Share on other sites More sharing options...
Guiltysparc Posted July 3, 2017 Share Posted July 3, 2017 Check out world eaters thread link in my signature. I got a pretty good white without much hassle by spraying with corax white, washing with thinned nuln oil, then light dry brush with ceramite white and edge highlighting with white scar on bigger models (tanks, characters, etc). Turns out like this... Reguar dudes Character Tank Kierdale and Emperor's Furor 2 Back to top Link to comment https://bolterandchainsword.com/topic/335974-tips-on-painting-white/#findComment-4806836 Share on other sites More sharing options...
