Hmm, if you are scratch building a platform 120 mm should be fine, although aesthetically it might be a bit too narrow for such a large artillery piece.
If you want to exactly replicate the old kit, I just measured my old FW Earthshaker platform resin piece (it's too bad they no longer make this).  The 2 cross pieces both measured 8.5 inches across (diameter). I think this translates to about 216 by 216 mm.  So your base would have to be in that neighborhood
Very good, if you look at the picture of my army (caledonian death corps) you can figure out by yourself. They are designed to fit in a chimera chassie. But the static emplacement with sandbag ecc looks cool enough for me. It looks like a WWI siege gun, and if you want a long barrel, with a small sacion of plastic tube 1cm wide you can easily get an heartshaker gun
Register a new account
Sign in
