Guiltysparc Posted August 28, 2017 Author Share Posted August 28, 2017 Well done. Thank you! Microsol and Microset can really help with decals. Looking great. As an aside is there any reason you don't drill out the gun barrels? Word, i used 'ard coat for the gloss base, then microset, then sol on top a few times, then made some relief cuts, then a couple coats of medium to kill the gloss. Re Gun barrels, i don't have the little hand drill and didn't want to try using my regular power drill. Link to comment https://bolterandchainsword.com/topic/336259-our-brand-is-vengeance-a-primaris-plog/page/2/#findComment-4870621 Share on other sites More sharing options...
Marius Perdo Posted August 28, 2017 Share Posted August 28, 2017 Any sort of gloss varnish first is great. I actually use Klear floor polish (works good as a seal for oil/turpentine washes too).I think I used sol first to soften the decal and smoothed it over the shoulder pads, then set to re-glue/set it when happy with positioning, and then when dry a matt finish to take off the shine. It has been a while though.Pin vice drills are usually fairly cheap. In the UK at least. I can see some for £4.95 with free P&P & 20 pin drills included. I couldn't cope without one, barrels aside I couldn't pin any resin components to plastic ones, or do leg extensions, or keep heads detached until I was absolutely sure I had the facing right.If you do get one just remember any excessive shearing force and they snap, whether titanium coated or not, and then you end up gouging your fingers. Less likely these days with white metal gone the way of the dodo but the amount of times I maimed my fingers and needed a tetanus boost due to metallic spall in my fingers...well, that was just twice but you get the idea.Actually stay away from pin vice drills, they are capricious tools that bite the hand that owns them Rambling aside keep at it, those Primaris look great.Any of the multi-part kits tempting you? Link to comment https://bolterandchainsword.com/topic/336259-our-brand-is-vengeance-a-primaris-plog/page/2/#findComment-4870685 Share on other sites More sharing options...
Phatsquirre1 Posted August 29, 2017 Share Posted August 29, 2017 I'm with Marius, when do we get to see your take on Aggressors/Inceptors/Reivers? Admittedly, I think the models are personally, but if anyone can pull them off, it'd be you. Link to comment https://bolterandchainsword.com/topic/336259-our-brand-is-vengeance-a-primaris-plog/page/2/#findComment-4870892 Share on other sites More sharing options...
Guiltysparc Posted August 29, 2017 Author Share Posted August 29, 2017 Any sort of gloss varnish first is great. I actually use Klear floor polish (works good as a seal for oil/turpentine washes too). I think i used sol first to soften the decal and smoothed it over the shoulder pads, then set to re-glue/set it when happy with positioning, and then when dry a matt finish to take off the shine. It has been a while though. Pin vice drills are usually fairly cheap. In the UK at least. I can see some for £4.95 with free P&P & 20 pin drills included. I couldn't cope without one, barrels aside I couldn't pin any resin components to plastic ones, or do leg extensions, or keep heads detached until I was absolutely sure I had the facing right. If you do get one just remember any excessive shearing force and they snap, whether titanium coated or not, and then you end up gouging your fingers. Less likely these days with white metal gone the way of the dodo but the amount of times I maimed my fingers and needed a tetanus boost due to metallic spall in my fingers...well, that was just twice but you get the idea. Actually stay away from pin vice drills, they are capricious tools that bite they hand that owns them Rambling aside keep at it, those Primaris look great. Any of the multi-part kits tempting you? I had used my big power drill for magnetizing a leviathan and somehow managed to do it without drilling into my body parts, lol. I'll be grabbing a multi-part kit of the intercessors because i want a third squad for my battalion detachment. Not sure about the hellblasters or inceptors. As much as i like the inceptors, i find them hard to work into army lists due to their expense. I'm with Marius, when do we get to see your take on Aggressors/Inceptors/Reivers? Admittedly, I think the models are personally, but if anyone can pull them off, it'd be you. Oh don't you worry! I have a squad of aggressors next in line and the DI inceptors sitting on the tray too. I love the aggressor models, so i'm pretty excited to work on them. Have you seen the inceptors in person? I thought they looked pretty wonky in pictures, but in person i really like them. I've got all of the primaris models so far except the rievers (hit a snag ordering them then didn't get around to re-ordering). So they'll all make it into this thread at some point. Link to comment https://bolterandchainsword.com/topic/336259-our-brand-is-vengeance-a-primaris-plog/page/2/#findComment-4871445 Share on other sites More sharing options...
Sagentus Posted August 29, 2017 Share Posted August 29, 2017 These look epic. Great clean work with all of them. Look forward to seeing more Link to comment https://bolterandchainsword.com/topic/336259-our-brand-is-vengeance-a-primaris-plog/page/2/#findComment-4871535 Share on other sites More sharing options...
Marius Perdo Posted August 29, 2017 Share Posted August 29, 2017 Cool, looking forward to seeing what you do with the last of the DI stuff and the new kits. It is threads like yours that make me want to get my chaos done faster so I can build my DI and 3 boxes of 1st Strike stuff (especially as I prepped to do UMs myself for 6/7th). Well almost tempted, having too much fun gluing spines on things :) Link to comment https://bolterandchainsword.com/topic/336259-our-brand-is-vengeance-a-primaris-plog/page/2/#findComment-4871704 Share on other sites More sharing options...
Guiltysparc Posted August 31, 2017 Author Share Posted August 31, 2017 Closing in on the lieutenant. Sword, oath of moment script, and base, then decals...and i guess some cleaning up of the helm stripe too. Link to comment https://bolterandchainsword.com/topic/336259-our-brand-is-vengeance-a-primaris-plog/page/2/#findComment-4873698 Share on other sites More sharing options...
Bjorn Firewalker Posted August 31, 2017 Share Posted August 31, 2017 The LT looks impressive. Link to comment https://bolterandchainsword.com/topic/336259-our-brand-is-vengeance-a-primaris-plog/page/2/#findComment-4873740 Share on other sites More sharing options...
Guiltysparc Posted August 31, 2017 Author Share Posted August 31, 2017 The LT looks impressive. Thanks! I am thinking i'm going to do a blue/green power weapon for his sword instead of the metal color. Sotek green base then temple guard blue and the like. Link to comment https://bolterandchainsword.com/topic/336259-our-brand-is-vengeance-a-primaris-plog/page/2/#findComment-4873746 Share on other sites More sharing options...
Guiltysparc Posted September 2, 2017 Author Share Posted September 2, 2017 Finished! This is the first attempt at the crystal sword effect. At first i wasn't happy at all with it, the blends were really rough. Then i remembered talking to someone here about paitning lightening on swords and how that can help hide :cussty blends, so i thought, why not? I threw on some of these shimmer lines a la Duncan's witch blade video and man, it really made it look a lot better. Below is a shot before the lines so you can see how rough the blends were. For those interested, the recipe on the sword is: Sotek Green Base Drakenhoth shade over that Sotek Green thinned with medium to make the first set of stripes Temple Guard Blue thinned with medium to make the second set of stripes Baharroth blue on the edges and down the middle Then I did 3 layers of Waywatcher Green trying to tie it together Baharroth Blue on the edges against becuase all the green had really dulled it down Baharroth Blue to make the shimmer lines Blue Horror to make little dots on the shimmer lines where they cross the middle of the sword and also on the edges at the tip of the sword One thin coat of Waywatcher green to tie it all together Link to comment https://bolterandchainsword.com/topic/336259-our-brand-is-vengeance-a-primaris-plog/page/2/#findComment-4875239 Share on other sites More sharing options...
Bjorn Firewalker Posted September 2, 2017 Share Posted September 2, 2017 The skull on his right pauldron means he's an HQ unit, right? Again, I must compliment your work. Link to comment https://bolterandchainsword.com/topic/336259-our-brand-is-vengeance-a-primaris-plog/page/2/#findComment-4875403 Share on other sites More sharing options...
Guiltysparc Posted September 3, 2017 Author Share Posted September 3, 2017 The skull on his right pauldron means he's an HQ unit, right? Again, I must compliment your work. Yep, that's the lieutenant badge. The captains have a sculpted skull and wings instead. Link to comment https://bolterandchainsword.com/topic/336259-our-brand-is-vengeance-a-primaris-plog/page/2/#findComment-4875667 Share on other sites More sharing options...
Ascanius Posted September 3, 2017 Share Posted September 3, 2017 They look really nice. If you want the bases to pop a little more, that Agrellan Earth texture paint cracks more dramatically the thicker it's applied. Link to comment https://bolterandchainsword.com/topic/336259-our-brand-is-vengeance-a-primaris-plog/page/2/#findComment-4875716 Share on other sites More sharing options...
Guiltysparc Posted September 3, 2017 Author Share Posted September 3, 2017 They look really nice. If you want the bases to pop a little more, that Agrellan Earth texture paint cracks more dramatically the thicker it's applied. Thanks, ya, still getting hang of applying them. I got the box of skulls too and I might throw a few around on the bases to add some dimension, or maybe some small rocks. Link to comment https://bolterandchainsword.com/topic/336259-our-brand-is-vengeance-a-primaris-plog/page/2/#findComment-4875845 Share on other sites More sharing options...
deathspectersgt7 Posted September 3, 2017 Share Posted September 3, 2017 Great job on the LT . Link to comment https://bolterandchainsword.com/topic/336259-our-brand-is-vengeance-a-primaris-plog/page/2/#findComment-4875853 Share on other sites More sharing options...
The_Stray_Idea Posted September 3, 2017 Share Posted September 3, 2017 Great affect of the Lt power sword. Crisp work as always. Link to comment https://bolterandchainsword.com/topic/336259-our-brand-is-vengeance-a-primaris-plog/page/2/#findComment-4875854 Share on other sites More sharing options...
Guiltysparc Posted September 3, 2017 Author Share Posted September 3, 2017 Great job on the LT . Thanks! Great affect of the Lt power sword. Crisp work as always. Thank you! Ita amazing how a little thing can change the whole look of it, I was really unhappy with how it turned out before I did the shimmer lines, which I hadn't planned on doing from the start. Can't wait to do the next one! Link to comment https://bolterandchainsword.com/topic/336259-our-brand-is-vengeance-a-primaris-plog/page/2/#findComment-4876048 Share on other sites More sharing options...
Guiltysparc Posted September 5, 2017 Author Share Posted September 5, 2017 Time to get mechanized! Link to comment https://bolterandchainsword.com/topic/336259-our-brand-is-vengeance-a-primaris-plog/page/2/#findComment-4877473 Share on other sites More sharing options...
Sagentus Posted September 5, 2017 Share Posted September 5, 2017 That LT is ace and the painting is crisp. The sword really adds to the model and looks great, defo give the technique a go at some point, but make it more chaos looking. looking forward to seeing how the magnetizing come on! Link to comment https://bolterandchainsword.com/topic/336259-our-brand-is-vengeance-a-primaris-plog/page/2/#findComment-4877617 Share on other sites More sharing options...
Guiltysparc Posted September 10, 2017 Author Share Posted September 10, 2017 One of the lt and intercessor squad chillin' together. Link to comment https://bolterandchainsword.com/topic/336259-our-brand-is-vengeance-a-primaris-plog/page/2/#findComment-4882153 Share on other sites More sharing options...
Brother Callidan Posted September 10, 2017 Share Posted September 10, 2017 Looking really great man. There coming together nice and clean Link to comment https://bolterandchainsword.com/topic/336259-our-brand-is-vengeance-a-primaris-plog/page/2/#findComment-4882234 Share on other sites More sharing options...
Guiltysparc Posted October 9, 2017 Author Share Posted October 9, 2017 Finnaly got back to work on these guys! Going through my hellblaster squad now. Decided to make one of the helmeted dues the sargent for more red hats. I'm going to use one of the purity seals from the UM upgrade spure to set off his gun a little. I'm also super happy with this guy's face/head turned out. I tried out the 50/50 dawnstone/lahmian medium technique for stubble that Duncan has in one of his videos. I might go darker with the next one and use eshin grey instead of dawnstone. Link to comment https://bolterandchainsword.com/topic/336259-our-brand-is-vengeance-a-primaris-plog/page/2/#findComment-4904933 Share on other sites More sharing options...
Guiltysparc Posted November 3, 2017 Author Share Posted November 3, 2017 Hobby time has been squeezed as of late so i've only been able to get an hour here and there, but, the hellblasters are coming along. I'm hoping by the weekend i'll be able to finish the bodies and get started on the arms/guns. Link to comment https://bolterandchainsword.com/topic/336259-our-brand-is-vengeance-a-primaris-plog/page/2/#findComment-4923435 Share on other sites More sharing options...
Sagentus Posted November 6, 2017 Share Posted November 6, 2017 I know what you mean about hobby time lol.... These all look epic though mate, clean crisp lines and the quality of the faces is something else! Link to comment https://bolterandchainsword.com/topic/336259-our-brand-is-vengeance-a-primaris-plog/page/2/#findComment-4925530 Share on other sites More sharing options...
Guiltysparc Posted November 6, 2017 Author Share Posted November 6, 2017 I was indeed able to get all the bodies done this week and start in on the guns. Here's the sarge all ready to accept his arms. After that we'll do decals. I am thinking i should have this squad finished up by the end the of the weekend and then i'm going to tackle the librarian next. Link to comment https://bolterandchainsword.com/topic/336259-our-brand-is-vengeance-a-primaris-plog/page/2/#findComment-4925615 Share on other sites More sharing options...
