I have been working for awhile on a paint scheme for my SW's and I think I got an idea of what I wanted.
I plan on using the Primaris models when they come multi-part, with the Pauldrons from the Burning of Prospero with the lip. Wolf Guard will use the 40k pauldron with the lip that has a wolf symbol on it. I will be using the Primaris helmet for everyone except wolf guard again that will use the wolf helmet or something else. I am trying to not use fur and only a few bone bits. I'm going to use the Forgeworld transfers for my pack and company markings.
I wanted to make sure my colors would be okay and work well with each other. I wanted to use the 30k SW theme, but I thought the warhammer TV theme was a bit too bright so slightly adjusted and then changed a few things I thought was missing or would look better.
Body
Primer: Chaos Black
Base: Mechanicus Standard Grey
Shade: Agrax Earthshade
1st Edge: Administratum Grey
2nd Edge: Runefang Steel
Peak Edges: Stormhost silver on things like studs and the very edge of the corner to show raw metal
Brass, such as the pauldron lips, chest emblems etc
Base: Balthasar Gold
Shade: Nuln Oil
Edge: Fulgurute Copper
Peak Edge: Sycorax Bronze
Steel: On swords and the bolter
Base: Runefang Steel
Shade: Nuln Oil
Peake Edge: Stormhost Silver
Black: On bolters
Base: Abaddon Black
Edge: Eshin Grey
Peak Edge: Runefang Steel
Eye Lens
Thin line of ceramite white
Coat with Blood Letter around the edges
Cloak trying to go for a deep royal red like Ulriks.
Base: Mephiston Red
Shade: Carroburg Crimson (?)
Highlight/edge: Evil Sunz Scarlet
Frost Weapon
Base: Ceramite White (this is the brightest white right?)
Glaze/shade: Guilliman Blue or Drakenhoff Nightshade ( I can't find a good review of these)
Highlight with Wrack Write on the extreme edges
Runes I forgot how I did my runes on my first model, still trying to reverse engineer it...this is what i think it was
Base: ceramite white
Shade: Calegor blue
highlight the inside of the rune: Thousand Sons blue
Bone
Base: Zandri Dust
Highlight: Ushabiti Bone
Gems
Base: Stormholst Silver
Gem color  will be the GW technical gem colors.
Edited by Caldersson
https://bolterandchainsword.com/topic/336426-sw-grey-theme-helpsuggestions/
I also tried the WarhammerTV colour scheme, and also found it too bright :tongue.:
So i did almost as you did. The left being exactly as Duncan did on Warhammer TV, the right the darker version. Simply not doing an overall Dawnstone, and making that the first highlight, with administratum being the 2nd sharp highlight.
Edited by Hellrender
I use Grieuxs recipe for the bronzeassy bits
Balthasar gold
Reikland flesh shade
layer Blathasar gold
edge highlight Fulgurite copper
Purple in recesses
edge highlight Sycorax bronze
If this is too bronze, then a wash of seraphim sepia, can restore a bit of yellow to it for a brassy look
Check his first post, he lists his paint technique there. http://www.bolterandchainsword.com/topic/327134-a-skjalds-tale-of-the-days-of-darkness/?p=4540954
Register a new account
Sign in
