gitface Posted July 10, 2017 Share Posted July 10, 2017 Hi All Been lurking for a while and decided to share the work I've been doing for my Primaris Smurfs. Not wanting to sink a whole lot into the Primaris force since concentrating on the Death Guard I decided to do a conversion for a Primaris Librarian. To start this I chose the Primaris Lieutenants with the Sword as the base as I like the pose and he has some bling on him, I also raided my spare Grey Knight Terrmis spares for the other bits. First thing I did was to start on the hood using the method of a modding a shoulder pad by cutting the sides and attached this to the top. I need to use a bit of green stuff round the back to smooth the seam between the hood and top of the body. Next up was the backpack, for this I decided I needed to bling this up a bit by adding a book from the GK Termmies. I started by shaving a bit off to make it sit a bit flatter. Next up was removing the old sword and replacing it with one from the GK Termmies, first thought was is it too big then I thought no i'm a big ard marine and I deserve a big sword. I also used the horned head to bling up the shoulder pad. Hear is a mock up to do a test fit, I've used one of the GK heads because it has some cables on it and also filed down and replace the left shoulder pad with a GK Termmie pad. Things I intend to do are add a cloak to the back, add a few more purity seals and do the cabling from the hood to the backpack. I was going to remove the Bolt Pistol but think I'll leave it for the time being. Link to comment Share on other sites More sharing options...
