LutherMax Posted July 12, 2017 Share Posted July 12, 2017 Has anyone else had trouble getting the FW Deimos Rhino doors to fit? The diameter of the circle that the two doors form when fit together is larger than the hole they go in! Link to comment https://bolterandchainsword.com/topic/336573-deimos-rhino-assembly-problem/ Share on other sites More sharing options...
Chaplain Raeven Posted July 12, 2017 Share Posted July 12, 2017 I wouldn't be suprised if you have to trim off the excess. I had the same problem with my FW rhino doors (the square ones). How much bigger are they? Link to comment https://bolterandchainsword.com/topic/336573-deimos-rhino-assembly-problem/#findComment-4817300 Share on other sites More sharing options...
LutherMax Posted July 12, 2017 Author Share Posted July 12, 2017 I managed to squeeze them in after a lot of trimming and sanding down! Link to comment https://bolterandchainsword.com/topic/336573-deimos-rhino-assembly-problem/#findComment-4817342 Share on other sites More sharing options...
Ovidius Incertus Posted July 14, 2017 Share Posted July 14, 2017 Yeah, I had this problem too. Just filed the outer edge. Hardest thing is making sure you keep it in round as you file. Link to comment https://bolterandchainsword.com/topic/336573-deimos-rhino-assembly-problem/#findComment-4818976 Share on other sites More sharing options...
PeteySödes Posted July 14, 2017 Share Posted July 14, 2017 Hah i have 3 that I'm starting to build tonight so this freaked me out reading the title. Glad the fix seems not too bad. Link to comment https://bolterandchainsword.com/topic/336573-deimos-rhino-assembly-problem/#findComment-4819114 Share on other sites More sharing options...
