Sweet Leviathan!  How difficult was it to magnetize?
Thanks mate :)
It was pretty simple to be honest. I bought a pack of 25, 3mmx1mm disc magnets from ebay for £2.29 and I already had a 3mm drill bit so it was cheap enough to do. Just make sure you get your polarity right by sticking too magnets together and with a permanent maker, mark the outside of each magnet so you know which side to glue. I had to heat and bend the cables on the siege drill as they should fit into the shoulder but obviously this wasn't possible. I bent them and glued them under the arm joint instead and it looks fine.
Register a new account
Sign in
