Brother Casman Posted July 14, 2017 Share Posted July 14, 2017 So, I found this picture whilst sorting through some files: We originally created this here on the B&C in 2009 (I think), and I wanted to bring it up-to-date with the new edition (that's my conversion in the picture!). Some background can be found on Lexicanum. My first pass of a possible profile is: Name: Sabre Tank Hunter Power Rating: 10 (Points: 200) Battlefield Role: Heavy Support A Sabre Tank Hunter is a single model equipped with a heavy laser destroyer array. Stats M WS BS S T W A Ld Sv * 6+ * 6 8 11 * 8 3+ Damage Remaining Wounds M BS A 6-11+ 10" 3+ 3 3-5 5" 4+ d3 1-2 3" 5+ 1 Weapons Name Range Type S AP Damage Abilities Heavy laser destroyer array 60" Heavy d3 9 -3 d6 When attacking units with the Vehicle keyword, roll 2 dice when inflicting damage and discard the lowest result. Options: Hunter-killer missile, Storm Bolter Abilities: Explodes, Smoke Launchers Faction Keywords: Imperium, Adeptus Astartes, <Chapter> Keywords: Relic, Vehicle, Sabre Tank Hunter This first pass only has the Heavy Laser Destroyer Array as an option, since that is basically what I originally built mine with. That said, I think the Vanquisher Cannon option could probably be resurrected. I sort of envision the tank as the initial punch to enemy armour before you get to close-quarters, or perhaps the dealer of the finishing blow to clean up the battlefield. It's definitely not intended to operate alone! Some of you may ask "why bring back the Sabre and not just counts-as a Deimos Pattern Vindicator Laser Destroyer?" Much as I like the idea of the Vindicator Laser Destroyer as a spiritual successor, it still feels like a Vindicator to me: short-ranged, in-your-face. The Sabre is more of a long(ish) range response to enemy threats, I feel. Plus, when I built mine, the concept of a Laser Volley Cannon didn't exist yet - it wouldn't feel right for my Sabre to sit still and get double the shots. D3 shots isn't quite right either, but it's closer to the original intent, I think. Others may ask "why are you using an Astra Militarum gun instead of the Laser Destroyer as seen on the Mastodon/Rapier? Or the Neutron Pulse Cannon?" The Laser Destroyers seem a little too short-ranged as well and a little too powerful. Likewise, the Neutron Pulse Cannon seems too powerful for what I'm envisioning - I'm not sure the Rhino chassis can handle the strain of firing one of those! ;) So, with that in mind: thoughts, comments, criticisms? Link to comment https://bolterandchainsword.com/topic/336622-sabre-tank-hunter/ Share on other sites More sharing options...
Bjorn Firewalker Posted July 15, 2017 Share Posted July 15, 2017 I thought of adding a Razorback turret to the Vindicator Laser Destroyer, to reduce its vulnerability to enemy flyers and infantry. Maybe that should be an option for the laser destroyer array-armed Sabre Tank Hunter as well? (Not for the Vanquisher cannon-armed variant, as the turret and sponsons would diminish the loading and stowage of cannon shells, as well as interfere with the cannons' operation.) Link to comment https://bolterandchainsword.com/topic/336622-sabre-tank-hunter/#findComment-4819793 Share on other sites More sharing options...
Brother Casman Posted July 15, 2017 Author Share Posted July 15, 2017 Hmmm... while the Ork in me likes the thought of strapping on more guns, the Imperial in me is concerned about precedent. I can't bring to mind any examples where a rhino-sized vehicle had a big gun in the front and a gun on top. (I may be a little tired, to be honest). Anyway, my initial thought is that would be why the Sabre has an option for a cupola storm bolter. Link to comment https://bolterandchainsword.com/topic/336622-sabre-tank-hunter/#findComment-4820054 Share on other sites More sharing options...
Brother Casman Posted September 29, 2019 Author Share Posted September 29, 2019 So, we've seen a few changes in the Space Marine Codex since I first looked at a possible Sabre Tank Hunter, namely GW added a Repulsor Executioner... with a Heavy laser destroyer! We now have a Space Marine weapon that I feel fits the Sabre. We've also seen a few adjustments to points and power levels, so I've adjusted both of these down. Version 2 Name: Sabre Tank Hunter Power Rating: 7 (Points: 165) Battlefield Role: Heavy Support A Sabre Tank Hunter is a single model equipped with a heavy laser destroyer. Stats M WS BS S T W A Ld Sv * 6+ * 6 8 11 * 8 3+ Damage Remaining Wounds M BS A 6-11+ 10" 3+ 3 3-5 5" 4+ d3 1-2 3" 5+ 1 Weapons Name Range Type S AP Damage Abilities Heavy laser destroyer 72" Heavy 2 10 -4 d6 When resolving an attack made with this weapon, a damage roll of 1 or 2 counts as 3 instead. Options: Hunter-killer missile, Storm Bolter Abilities: Angels of Death, Explodes (d3 mortal wounds within 6"), Smoke Launchers Faction Keywords: Imperium, Adeptus Astartes, <Chapter> Keywords: Relic, Vehicle, Sabre Tank Hunter ------------ I'd still like to add an Autocannon or Vanquisher Cannon variant of some sort, but I'm not sure if I want to use the weapon from the Astra Militarum or not. Something to think about, at the very least. Link to comment https://bolterandchainsword.com/topic/336622-sabre-tank-hunter/#findComment-5398187 Share on other sites More sharing options...
Bjorn Firewalker Posted September 29, 2019 Share Posted September 29, 2019 I'm grateful you updated this for 8th Edition. Link to comment https://bolterandchainsword.com/topic/336622-sabre-tank-hunter/#findComment-5398200 Share on other sites More sharing options...
