CrimsonReign Posted July 14, 2017 Share Posted July 14, 2017 Was looking at the hellblasters today, and thought they'd make reasonable plasma chosen (with the other primes filling out the squad)anyone had any luck converting the new loyalists to the dark gods? or are they just too big to fit with a chaos army? Link to comment https://bolterandchainsword.com/topic/336634-converting-primaris-marines/ Share on other sites More sharing options...
Tamika Posted July 14, 2017 Share Posted July 14, 2017 Can just do a head swap since it's the same scale for the head? Link to comment https://bolterandchainsword.com/topic/336634-converting-primaris-marines/#findComment-4818809 Share on other sites More sharing options...
Marqol Posted July 14, 2017 Share Posted July 14, 2017 The heads and shoulders are the same scale as standard marines so they are easy to switch around. The rest of the model though is bigger than the other marines so it does look obvious they are different even at a glance. If you are fine with the different scales then I'd say it's very possible to convert them to Chosen. You could even say as they are chosen they have grown demonic bulk to explain why they are bigger. Link to comment https://bolterandchainsword.com/topic/336634-converting-primaris-marines/#findComment-4818970 Share on other sites More sharing options...
Kizzdougs Posted July 14, 2017 Share Posted July 14, 2017 Changing the head, shoulder plates, and power pack should all be pretty straight forward. Cutting off the gorget is also really easy and it should be child's play to remove the chest detail. The challenge will be adding appropriate detail to the rest of the armour (unless you're going for the newly renegade look). I did a head, shoulder plate, and power pack swap, converted the bolt rifle, and removed the high gorget on a Primaris to make a true-scale Blood Angel. It was all very easy to do (the bolter was a bit tricker). http://i1122.photobucket.com/albums/l522/kizzdougs/DSCN6017_zpsxyqqni9f.jpg Yes, they will look much bigger than the rest of your minis. 1 Back to top Link to comment https://bolterandchainsword.com/topic/336634-converting-primaris-marines/#findComment-4818977 Share on other sites More sharing options...
Canadian_F_H Posted July 14, 2017 Share Posted July 14, 2017 Bigger is fine if you were truescaling anyways... which is my current plan... Link to comment https://bolterandchainsword.com/topic/336634-converting-primaris-marines/#findComment-4818980 Share on other sites More sharing options...
CrimsonReign Posted July 14, 2017 Author Share Posted July 14, 2017 (edited) someone correct me here if I'm wrongbut can all chosen (except the champion) take a special heavy weapon in the index? to quote: "any additional chosen may replace his boltgun with one item from the special weapons or heavy weapons lists" if so then hellblasters are being bought 100% :D Edited July 14, 2017 by CrimsonReign Link to comment https://bolterandchainsword.com/topic/336634-converting-primaris-marines/#findComment-4818995 Share on other sites More sharing options...
Marqol Posted July 14, 2017 Share Posted July 14, 2017 5 chosen can take new weapons, 4 having more free range and then an additional 5th one choosing just a Heavy or a Special weapon. The wording is "An additional" not "Any Additional." You can still have a 6 man squad with 5 toting plasmas easy. In fact I'm thinking of running one all with meltas and advancing every turn :P Not sure it will be any good but it seems a fun thing to do. 1 Back to top Link to comment https://bolterandchainsword.com/topic/336634-converting-primaris-marines/#findComment-4819052 Share on other sites More sharing options...
CrimsonReign Posted July 14, 2017 Author Share Posted July 14, 2017 @Marqol - thanks for the correction! returns back to the issue I had with chosen in 7th then : why take them over havocs? Link to comment https://bolterandchainsword.com/topic/336634-converting-primaris-marines/#findComment-4819104 Share on other sites More sharing options...
hazard5259 Posted July 14, 2017 Share Posted July 14, 2017 Chosen V Havocs Chose have Plasma Pistol and Melee weapons options Fill Elite Slot Higher Leadership More Attacks Additional Heavy Weapon/Special Weapon Slot Link to comment https://bolterandchainsword.com/topic/336634-converting-primaris-marines/#findComment-4819268 Share on other sites More sharing options...
Plaguecaster Posted July 14, 2017 Share Posted July 14, 2017 (edited) Seems like a cool idea though that one squad will massively stick out compared to the rest of your army as the size difference is quite huge though (gets a bit odd when one squad towers over the rest of your army especially any chaos lords) , I'm planning on doing the same though using the squad for my Shadow War Armageddon killteam so it doesn't affect the rest of my army Edited July 14, 2017 by Plaguecaster Link to comment https://bolterandchainsword.com/topic/336634-converting-primaris-marines/#findComment-4819596 Share on other sites More sharing options...
hazard5259 Posted July 14, 2017 Share Posted July 14, 2017 I was thinking og doing the same myself but make them plague marines, sense the new plague marines are the same height Link to comment https://bolterandchainsword.com/topic/336634-converting-primaris-marines/#findComment-4819662 Share on other sites More sharing options...
