olcottr Posted July 17, 2017 Share Posted July 17, 2017 Probably overthinking it, but you can consolidate even when you've wiped out all nearby enemy units? So you would have to move toward enemies that are farther than 3" away, even if you can't see them? Link to comment Share on other sites More sharing options...
Eddie Orlock Posted July 17, 2017 Share Posted July 17, 2017 Yes to all. With the noted exception that you don't have to consolidate if you don't want to. If it helps, imagine that most units are likely tapped into some kind of local comms, command, and control network even if it's just a simple vox net/auspex that'll inform them that there is life with out proper IFF markings over yonder. 'Nids'll smell you. olcottr 1 Back to top Link to comment Share on other sites More sharing options...
