wulfgar hammerfist Posted July 18, 2017 Share Posted July 18, 2017 Seeing all the talk about flyer spam in the competitive scene has got me thinking. Do you think a list centered around our own flyers would be competitive? Our flyers are more expensive than those of our fellow astartes. I don't think 4 or 5 is viablessed but maybe two or three with some ground support could work? I have a lit in mind but would like to hear the thoughts of my fellow wolf lords. Link to comment https://bolterandchainsword.com/topic/336813-flyer-based-lists/ Share on other sites More sharing options...
Guest Posted July 18, 2017 Share Posted July 18, 2017 I planned on doing 2 flyers, 1 with 15 Blood Claws+Lukas, another with 10WG/5TDAWG's with a Lone wolf, Arjac, Grimnar. Might switch Grimnar out. Then add Long fangs with a razorback and snipers to hold objectivs. The other idera was a Stormfang with long fangs to get them wherever i wanted, and the WG's pack in a stormwolf, again with Snipers to hold oobjectives. Link to comment https://bolterandchainsword.com/topic/336813-flyer-based-lists/#findComment-4823242 Share on other sites More sharing options...
Deadnaughty Posted July 18, 2017 Share Posted July 18, 2017 A stormfang is only slighly more expensive then a Stormraven, but you have a Hellfrost Destructor which is great and you can gear for more anti flier with Skyhammer Missiles, at which point your cheaper then a Stormraven. I think SW might do the Air wing better then generic space marines actually. Link to comment https://bolterandchainsword.com/topic/336813-flyer-based-lists/#findComment-4823315 Share on other sites More sharing options...
Jackalwolf Posted July 18, 2017 Share Posted July 18, 2017 I think you're right. The Stormfang is the perfect melding of carrier + guship. I'd totally use two of them if I didn't hate the look of it. Link to comment https://bolterandchainsword.com/topic/336813-flyer-based-lists/#findComment-4823671 Share on other sites More sharing options...
wulfgar hammerfist Posted July 18, 2017 Author Share Posted July 18, 2017 Our flyers don't put out the same number of shots that the stormravens do but ours are of higher strength. Stormravens seem betger suited to killing infantry and light vehicles whereas our own take on larger targets better. I have one stormwolf and one Stormfang at the moment. I had considered fielding both of them along with 3 long fang packs, some razorbacks, and Bjorn. I may add a couple of bare bones BC packs for objective capping. Link to comment https://bolterandchainsword.com/topic/336813-flyer-based-lists/#findComment-4823939 Share on other sites More sharing options...
Rune Priest Jbickb Posted July 18, 2017 Share Posted July 18, 2017 Personally I find grey hunters better at camping. Not quite as cheap as blood claws but the bolters do much better in a more stationary role imho Link to comment https://bolterandchainsword.com/topic/336813-flyer-based-lists/#findComment-4824012 Share on other sites More sharing options...
wulfgar hammerfist Posted July 18, 2017 Author Share Posted July 18, 2017 I concur that GHs are better but I only have 130 points left in my list unless I make cuts elsewhere. Link to comment https://bolterandchainsword.com/topic/336813-flyer-based-lists/#findComment-4824020 Share on other sites More sharing options...
Deadnaughty Posted July 18, 2017 Share Posted July 18, 2017 I concur that GHs are better but I only have 130 points left in my list unless I make cuts elsewhere. Intercessors? Primaris arn't great as the workhorses of your army but they are cheap wounds and 30" range help keep them relevant while sitting still. Link to comment https://bolterandchainsword.com/topic/336813-flyer-based-lists/#findComment-4824205 Share on other sites More sharing options...
Gherrick Posted July 18, 2017 Share Posted July 18, 2017 Personally I find grey hunters better at camping. Not quite as cheap as blood claws but the bolters do much better in a more stationary role imho A squad of PAWG with chainsword x2 and storm bolters seems like it would hold an objective much better than GH, for only a bit more points. Not so much, I'd suppose, if you are using power levels. Link to comment https://bolterandchainsword.com/topic/336813-flyer-based-lists/#findComment-4824229 Share on other sites More sharing options...
wulfgar hammerfist Posted July 19, 2017 Author Share Posted July 19, 2017 Personally I find grey hunters better at camping. Not quite as cheap as blood claws but the bolters do much better in a more stationary role imho A squad of PAWG with chainsword x2 and storm bolters seems like it would hold an objective much better than GH, for only a bit more points. Not so much, I'd suppose, if you are using power levels.That's actually a pretty good idea. So far the list looks like this:Airwing Stormwolf, meltas Stormfang, stock Stormfang, stock Vanguard 3× 5 Wolf Guard, 1 combi-plasma, 4 storm bolters 5 Long Fangs, 4 ML 5 Long Fangs, 4 LC This leaves 426 points for an HQ and some other stuff. Still working it out really. Link to comment https://bolterandchainsword.com/topic/336813-flyer-based-lists/#findComment-4824294 Share on other sites More sharing options...
Gherrick Posted July 19, 2017 Share Posted July 19, 2017 Consider putting jump packs on some of those WG units. Pretty cheap upgrade, but having 10" movement vs 6" will help a ton on getting to the best available position to maximize any rapid fire opportunities. Link to comment https://bolterandchainsword.com/topic/336813-flyer-based-lists/#findComment-4824425 Share on other sites More sharing options...
Brother Hellion Posted July 19, 2017 Share Posted July 19, 2017 A stormfang is only slighly more expensive then a Stormraven, but you have a Hellfrost Destructor which is great and you can gear for more anti flier with Skyhammer Missiles, at which point your cheaper then a Stormraven. I think SW might do the Air wing better then generic space marines actually. While its true our planes are powerful compared to the stormraven or storm talon but they may have the advantage in point cost cause ours are pretty pricey. They can bring in two storm talons for one Stormwolf at bare bones cost. Still, the stormfang/stormwolf has a greater array of powerful options compared to the talon which has less options. Link to comment https://bolterandchainsword.com/topic/336813-flyer-based-lists/#findComment-4825033 Share on other sites More sharing options...
Deadnaughty Posted July 19, 2017 Share Posted July 19, 2017 A talon also has a further -1 to hit because it doesn't have PotMS. They hit other fliers on 5's. Thats why its so cheap ^^ Link to comment https://bolterandchainsword.com/topic/336813-flyer-based-lists/#findComment-4825057 Share on other sites More sharing options...
Brother Hellion Posted July 19, 2017 Share Posted July 19, 2017 (edited) Another thing to consider with these flyer lists that they can now be charged by anything with a pair of wings or jump packs. So make sure to include some Skyclaws to help run interference against both ground and aerial targets while your stormfangs and WG with Jump packs make key strikes at critical points in the enemy's defenses. Here's a list that might fit the theme to a flyer list: WL with jumppack Th/SS cause you want a heavy hitter. WP with Jumppack 5-man WG with jump packs, FA/SS if you got the bits or Th/SS. 3x 5-10 skyclaws loaded however you need them to be. 1x Stormfang armed with skyhammer/lascannons. Keep the bolters for handling mobs. If you got the room then add a Stormwolf with at least the multi melta for tank slagging. Put a pack of Wulfen in there so that they can get to the enemy faster and once out their curse will be a huge benefit to the sky claws. This would be a lethal first strike list if you can get first turn but its vulnerable to large mobs and heavy overwatch. But you will get people into close combat quickly and swarm them with attacks. I think I shall call it...Thunder of Fenris. Edited July 19, 2017 by Brotherblur Link to comment https://bolterandchainsword.com/topic/336813-flyer-based-lists/#findComment-4825069 Share on other sites More sharing options...
Gherrick Posted July 19, 2017 Share Posted July 19, 2017 Except you disembark before movement, meaning enemies get a full round before your wulfen can leave the transport and charge. Link to comment https://bolterandchainsword.com/topic/336813-flyer-based-lists/#findComment-4825124 Share on other sites More sharing options...
Brother Hellion Posted July 19, 2017 Share Posted July 19, 2017 Except you disembark before movement, meaning enemies get a full round before your wulfen can leave the transport and charge. True but the idea is to get the wulfen close enough on the next turn so they rarely fail to charge. Link to comment https://bolterandchainsword.com/topic/336813-flyer-based-lists/#findComment-4825457 Share on other sites More sharing options...
wulfgar hammerfist Posted July 21, 2017 Author Share Posted July 21, 2017 After poring over 220 pages of ETC lists, I found two to be pure Space Wolves and both were variants of flyer spam. Both lists featured Logan, RPs with JP, WGBLs with JP and then 3-4 flyers. One list used 4 Stormfangs with stormstrikes and multimeltas while the other had 3 stormwolves with lascannons and multimeltas. I'm assuming logan teleports down to support a round of shooting for the flyers. The priests increase survivability through storm caller or tempests wrath. Link to comment https://bolterandchainsword.com/topic/336813-flyer-based-lists/#findComment-4827375 Share on other sites More sharing options...
Rune Priest Jbickb Posted July 24, 2017 Share Posted July 24, 2017 The new FAQ made this considerably less desirable as flyers no longer count to prevent you being tabled. If all your non flyer models are dead you have been tabled. They did this to specifically combat flyer spam. Link to comment https://bolterandchainsword.com/topic/336813-flyer-based-lists/#findComment-4830988 Share on other sites More sharing options...
wulfgar hammerfist Posted July 24, 2017 Author Share Posted July 24, 2017 The new FAQ made this considerably less desirable as flyers no longer count to prevent you being tabled. If all your non flyer models are dead you have been tabled. They did this to specifically combat flyer spam. Tracking. I've pretty much abandoned the idea. Link to comment https://bolterandchainsword.com/topic/336813-flyer-based-lists/#findComment-4831014 Share on other sites More sharing options...
