mertbl Posted July 21, 2017 Share Posted July 21, 2017 I have an old shrike model that has not aged well and I need to replace his lightning claw. What is the best way to remove the old arm? Link to comment https://bolterandchainsword.com/topic/336980-best-tool-to-remove-metal-arm/ Share on other sites More sharing options...
Stercus Posted July 21, 2017 Share Posted July 21, 2017 Razor saw. They cut literally anything and are pretty easy to use. Mazer Rackham 1 Back to top Link to comment https://bolterandchainsword.com/topic/336980-best-tool-to-remove-metal-arm/#findComment-4827936 Share on other sites More sharing options...
Isolia Posted July 22, 2017 Share Posted July 22, 2017 (edited) Razor saw. They cut literally anything and are pretty easy to use.I second that. If it is the glued arm, superglue is quite brittle especially when cold, so I'd suggest a half hour stay in the freezer and a gentle snapping off of said arm (holding pieces with a cloth so as not to damage detail on the pewter) Edited July 22, 2017 by Isolia Link to comment https://bolterandchainsword.com/topic/336980-best-tool-to-remove-metal-arm/#findComment-4828300 Share on other sites More sharing options...
Brother-Chaplain Kage Posted July 24, 2017 Share Posted July 24, 2017 Razor saw. They cut literally anything and are pretty easy to use. I don't know about literally everything, but most hobby materials should be fine. PeteySödes and Shinespider 2 Back to top Link to comment https://bolterandchainsword.com/topic/336980-best-tool-to-remove-metal-arm/#findComment-4830096 Share on other sites More sharing options...
Cloud Runner Posted July 24, 2017 Share Posted July 24, 2017 As an alternative to the razor saw (which is great, though sometimes heavy) I would suggest a jewellers saw like this https://www.amazon.co.uk/Faithfull-FAIPRS-TB-Piercing-Saw/dp/B000297TEY/ref=sr_1_1?ie=UTF8&qid=1500900711&sr=8-1&keywords=jewellers+saw Able to get into fine areas, and doesn't obliterate so much detail - takes a little more care to use (the blades can snap very easily) but it's brilliant for getting into hard to reach areas. Link to comment https://bolterandchainsword.com/topic/336980-best-tool-to-remove-metal-arm/#findComment-4830728 Share on other sites More sharing options...
