Xenocide Enthusiast Posted July 23, 2017 Share Posted July 23, 2017 I'm keen to model a transparent sarcophagus on my dread, with a dessicated skeleton floating in a sea of colourful liquid. But I have no idea where to start. I don't even know the correct search terms, though I'm sure it's been done before. Link to comment https://bolterandchainsword.com/topic/337013-transparent-sarcophagus-modelling/ Share on other sites More sharing options...
Tyberos the Red Wake Posted July 23, 2017 Share Posted July 23, 2017 Cast the lid in clear resin. Link to comment https://bolterandchainsword.com/topic/337013-transparent-sarcophagus-modelling/#findComment-4829102 Share on other sites More sharing options...
Xenocide Enthusiast Posted July 23, 2017 Author Share Posted July 23, 2017 I don't want to do that. Seems hard. Link to comment https://bolterandchainsword.com/topic/337013-transparent-sarcophagus-modelling/#findComment-4829134 Share on other sites More sharing options...
sockwithaticket Posted July 23, 2017 Share Posted July 23, 2017 I don't want to do that. Seems hard. You're not going to get many suggestions if that's how you respond. 'That seems too difficult for me, can you think of another way?' would be much better. Howver, I'd caution that most responses to this topic will involve some fairly high level modelling as what you're asking isn't easy. The other issue you may well run into is the size of the skeleton vs the available size around the sarcophagus area as demonstrated by these two examples: http://demonwinner.free.fr/usa/2011Chicago/us_2011_cat_10_bronze.jpg http://images.dakkadakka.com/gallery/2011/1/23/176685_md-Chaos%20Space%20Marines%2C%20Conversion%2C%20Death%20Guard%2C%20Dreadnought%2C%20Greenstuff%2C%20Nurgle.jpg As an attempt to do it, cut out the existing sarcaphpgus and replace it with a construction of your own made from clear plastic with enough depth that you could fill it using this sort of method: http://magie-miniatures.blogspot.co.uk/2015/10/Steampunk-Resin-Water.html Xenocide Enthusiast 1 Back to top Link to comment https://bolterandchainsword.com/topic/337013-transparent-sarcophagus-modelling/#findComment-4829182 Share on other sites More sharing options...
Deadnaughty Posted July 23, 2017 Share Posted July 23, 2017 I don't want to do that. Seems hard. If your response is "that looks hard" then you shouldn't consider complicated modeling projects. Link to comment https://bolterandchainsword.com/topic/337013-transparent-sarcophagus-modelling/#findComment-4829191 Share on other sites More sharing options...
Xenocide Enthusiast Posted July 23, 2017 Author Share Posted July 23, 2017 I don't want to do that. Seems hard. You're not going to get many suggestions if that's how you respond. 'That seems too difficult for me, can you think of another way?' The Internet is difficult. But I hope my bad attitude to casting the lid in clear resin provides the clearest possible indication that I both don't want to do it and that it seems hard. I appreciate the rest of your post. The sizing issue is one I might have to contend with. I was considering using the new Primaris dread (Redemptor?) because it fits big boy scaling. A small plastic test tube could work here as well. Love the resin water base. I don't want to do that. Seems hard. If your response is "that looks hard" then you shouldn't consider complicated modeling projects. I don't think this project will be as complicated as all that. I'm just not terribly interested in casting parts at this stage. Link to comment https://bolterandchainsword.com/topic/337013-transparent-sarcophagus-modelling/#findComment-4829230 Share on other sites More sharing options...
Xenocide Enthusiast Posted July 23, 2017 Author Share Posted July 23, 2017 Actually, you know what, guys? I think I'm coming across as a real :cuss here, so forget I started the topic in the first place. I'm just very tired and very anxious and I probably should not be writing or responding to Internet posts right now. My sincere apologies. Link to comment https://bolterandchainsword.com/topic/337013-transparent-sarcophagus-modelling/#findComment-4829245 Share on other sites More sharing options...
Chaplain Raeven Posted July 23, 2017 Share Posted July 23, 2017 Isn't there are piece of corpse in the sarcophagus of the Venerable dread kit? You could cut off the front panel of the armoured plate, so you have only the frame, and glue some clear plastic in it. Fill up the sarcophagus with some green coloured watereffects and place the front panel when the resin has dried. Or get some coloured plastic (like from tic-tacs) so you don't have to bother with coloured resin. Link to comment https://bolterandchainsword.com/topic/337013-transparent-sarcophagus-modelling/#findComment-4829288 Share on other sites More sharing options...
Teetengee Posted July 23, 2017 Share Posted July 23, 2017 Oyumaru might work as well, just don't let the model get much above 70 degrees F/ 21 C. Link to comment https://bolterandchainsword.com/topic/337013-transparent-sarcophagus-modelling/#findComment-4829289 Share on other sites More sharing options...
old git Posted July 23, 2017 Share Posted July 23, 2017 From the fluff I remember, most interred marines are in the foetal position inside the sarcophagus. This will have two effects - the container can be smaller but modelling the marine might require lots of chopping. Link to comment https://bolterandchainsword.com/topic/337013-transparent-sarcophagus-modelling/#findComment-4829302 Share on other sites More sharing options...
Teetengee Posted July 23, 2017 Share Posted July 23, 2017 From the fluff I remember, most interred marines are in the foetal position inside the sarcophagus. This will have two effects - the container can be smaller but modelling the marine might require lots of chopping. Many probably aren't fully intact either... Link to comment https://bolterandchainsword.com/topic/337013-transparent-sarcophagus-modelling/#findComment-4829310 Share on other sites More sharing options...
sockwithaticket Posted July 23, 2017 Share Posted July 23, 2017 Isn't there are piece of corpse in the sarcophagus of the Venerable dread kit? No, there's an regular power armoured torso hardwired in with space for a helmet/head. Link to comment https://bolterandchainsword.com/topic/337013-transparent-sarcophagus-modelling/#findComment-4829325 Share on other sites More sharing options...
dogfender Posted July 25, 2017 Share Posted July 25, 2017 · Hidden by Bryan Blaire, July 26, 2017 - Non-constructive Hidden by Bryan Blaire, July 26, 2017 - Non-constructive I think if you want not-hard solutions to you problem, you will: get Smart *** remarks get poor results from lazy work with those in mind, based on what youve said so far I would recommend buying a 25c Toy in a marchine, put half a space marine in it and glue it to your dread. Otherwise, invest in some cheap casting materials or buy a vacuformer. This is your hobby, do what you want with it. If your attempts are lazy you will have bad results, expecting the right specific answer to solve your laziness is the wrong step forward. I would tread lightly. Link to comment https://bolterandchainsword.com/topic/337013-transparent-sarcophagus-modelling/#findComment-4832559
Xenocide Enthusiast Posted July 26, 2017 Author Share Posted July 26, 2017 · Hidden by Bryan Blaire, July 26, 2017 - Response to non-constructive Hidden by Bryan Blaire, July 26, 2017 - Response to non-constructive I think if you want not-hard solutions to you problem, you will: get Smart *** remarks get poor results from lazy work with those in mind, based on what youve said so far I would recommend buying a 25c Toy in a marchine, put half a space marine in it and glue it to your dread.Otherwise, invest in some cheap casting materials or buy a vacuformer. This is your hobby, do what you want with it. If your attempts are lazy you will have bad results, expecting the right specific answer to solve your laziness is the wrong step forward. I would tread lightly. Very useful. Thanks. Link to comment https://bolterandchainsword.com/topic/337013-transparent-sarcophagus-modelling/#findComment-4833361
