Drudge Dreadnought Posted July 24, 2017 Share Posted July 24, 2017 For plastic, I normally use Simple Green to strip paint. I wanted to check if that is also good when stripping Forgeworld resin. I've got a Thousand Sons dreadnought that needs a new paintjob, but I want to make sure not to damage it! Link to comment https://bolterandchainsword.com/topic/337066-paint-stripping-forgeworld/ Share on other sites More sharing options...
Slips Posted July 24, 2017 Share Posted July 24, 2017 I've had no problem stripping FW resin using a similar product to Green Stuff the MAIN thing I'd look out for is, if you're brushing any of the goop off, be careful with fine details as those are liable to being torn off; the prongs on my Sigismunds Iron Halo were lost that way. Link to comment https://bolterandchainsword.com/topic/337066-paint-stripping-forgeworld/#findComment-4830349 Share on other sites More sharing options...
Tyberos the Red Wake Posted July 24, 2017 Share Posted July 24, 2017 Simple Green is safe for resin. Although if you have a piece that someone coated in thick layers of enamel, lacquer, or house paint, it's not going to get anything off. When I strip my own FW, I use isopropyl rubbing alcohol, either 70% or 91%. It washes the acrylic paint away like water after a few minutes, but leaving the resin inside too long causes the surface to begin to soften into hard rubber, and requires weeks of air drying to re-harden. Cloud Runner 1 Back to top Link to comment https://bolterandchainsword.com/topic/337066-paint-stripping-forgeworld/#findComment-4830485 Share on other sites More sharing options...
Drudge Dreadnought Posted July 25, 2017 Author Share Posted July 25, 2017 Simple Green is safe for resin. Although if you have a piece that someone coated in thick layers of enamel, lacquer, or house paint, it's not going to get anything off. When I strip my own FW, I use isopropyl rubbing alcohol, either 70% or 91%. It washes the acrylic paint away like water after a few minutes, but leaving the resin inside too long causes the surface to begin to soften into hard rubber, and requires weeks of air drying to re-harden. When using simple green on normal models, I usually left them in it for a couple of days, then scrubbed them with a toothbrush, then left them in for another day or two. For isopropyl, do you have a recommended amount of minutes? Should I do simple green first to get most of the paint, then just do isopropyl for the remains? Link to comment https://bolterandchainsword.com/topic/337066-paint-stripping-forgeworld/#findComment-4831506 Share on other sites More sharing options...
