Galron Posted July 24, 2017 Share Posted July 24, 2017 Question on these, can they be set up within 9" of an opponents models? They go away if an enemy model ends its move within 9" of them, but doesn't say if they can be set up there at the same time. Link to comment https://bolterandchainsword.com/topic/337080-tau-stealth-team-homing-beacons/ Share on other sites More sharing options...
Interrogator-Chaplain Ezra Posted July 24, 2017 Share Posted July 24, 2017 Question on these, can they be set up within 9" of an opponents models? They go away if an enemy model ends its move within 9" of them, but doesn't say if they can be set up there at the same time. The rule doesn't appear to have a prohibition against that sort of tactic. But why would you even *want* to do that? It gives no benefit whatsoever. Link to comment https://bolterandchainsword.com/topic/337080-tau-stealth-team-homing-beacons/#findComment-4830788 Share on other sites More sharing options...
Galron Posted July 24, 2017 Author Share Posted July 24, 2017 Guy this weekend used stealths to infiltrate 12" away from my guys, bounced as far forward as he could on his move, dropped a beacon, deep struck a crisis team and a big drone team about 4" from a bunch of my stuff. They didn't accomplish much as he got a hit on a vulture and then I simply drove a Cyclops into the middle of his little group and popped it killing all but the crisis(I didn't know drones in a separate squad could take wounds for the crisis like that) and still did one wound on a crisis. Link to comment https://bolterandchainsword.com/topic/337080-tau-stealth-team-homing-beacons/#findComment-4830842 Share on other sites More sharing options...
Captain Coolpants Posted July 27, 2017 Share Posted July 27, 2017 Do homimg beacons specifically mention that they override normal deepstrike rules? i.e, ignore the 9" deepstrike rule? Because regardless of whether you can set up the beacon within 9" or not, if it doesn't specifically say it bypasses the normal deepstrike rules, then it's not possible anyway. Link to comment https://bolterandchainsword.com/topic/337080-tau-stealth-team-homing-beacons/#findComment-4834969 Share on other sites More sharing options...
Eddie Orlock Posted July 27, 2017 Share Posted July 27, 2017 ... if it doesn't specifically say it bypasses the normal deepstrike rules, then it's not possible anyway.There are no 'normal deepstrike rules', just common conventions applied by the authors. Remember, we only have about a dozen pages of core rules and near everything else is some bespoke unit ability or scenario condition. Yes, the homing beacon rule does specifically 'bypass' the Manta Strike rule. Manta Strike first allows you to place a unit in a location known as the 'manta hold' and then provides a procedure to extract the unit from that hold. The Homing Beacon ability provides an alternate procedure to extract a unit from a manta hold that it refers to as a 'low altitude drop'. Link to comment https://bolterandchainsword.com/topic/337080-tau-stealth-team-homing-beacons/#findComment-4834995 Share on other sites More sharing options...
