major higgins Posted July 26, 2017 Share Posted July 26, 2017 Hi comrades, I'm struggling against flyer... But I cannot see any real good AAA except Hydra battery. Although a single piece is a bargain, I fear that it never will have a chance to shoot, because we give up first turn one on six and if the enemy has flyer, Hydra will became its first target... I don't want any flyer by myself because I run a fluffy Siege list... Any Idea, or suggestion? Link to comment https://bolterandchainsword.com/topic/337178-flack-for-dkk/ Share on other sites More sharing options...
Halfpint100 Posted July 26, 2017 Share Posted July 26, 2017 maybe some terrain pieces? there are some with icarus weapons. or just mass autocannon weapon team dakka Link to comment https://bolterandchainsword.com/topic/337178-flack-for-dkk/#findComment-4833364 Share on other sites More sharing options...
CoffeeGrunt Posted July 26, 2017 Share Posted July 26, 2017 Fliers are only a -1 to Hit now, so normal shooting does a lot better against them. The simple answer to your Hydra vulnerability problem is to park it behind LoS, or deploy it last so the Flier will struggle to get a good bead on it. Die4Emprah 1 Back to top Link to comment https://bolterandchainsword.com/topic/337178-flack-for-dkk/#findComment-4833392 Share on other sites More sharing options...
Galron Posted July 26, 2017 Share Posted July 26, 2017 Play ITC rules so you actually might get a chance to go first? I have not actually encountered a single actual "Flyer" in my meta yet, lots of battlesuits though. In fact with the proliferation of flyers in non-flyer form(suits, jump packs) if I was running a ground based army I would have at least two hydras or hydra turrets, they will earn their pay. Do any of the fortifications allow for AA guns? Autocannon squads should still shoot the crap out of them if you have enough. Link to comment https://bolterandchainsword.com/topic/337178-flack-for-dkk/#findComment-4833405 Share on other sites More sharing options...
Die4Emprah Posted July 26, 2017 Share Posted July 26, 2017 Fliers are only a -1 to Hit now, so normal shooting does a lot better against them. The simple answer to your Hydra vulnerability problem is to park it behind LoS, or deploy it last so the Flier will struggle to get a good bead on it. yep, make them get closer, hope for lascannon/melta spam to kill them. I also take the 8-shot autocannon that comes with the aegis. even if they have no flyers, 8 shots at -1 against ground targets? Sure. CoffeeGrunt 1 Back to top Link to comment https://bolterandchainsword.com/topic/337178-flack-for-dkk/#findComment-4833439 Share on other sites More sharing options...
CoffeeGrunt Posted July 26, 2017 Share Posted July 26, 2017 It can use the Operator's Ballistic Skill as well, IIRC. Stick a Lord Commissar on it for BS2+, 3+ against Fliers. That's enough to scare most things. It'd integrate really well with a typical gunline setup. Die4Emprah 1 Back to top Link to comment https://bolterandchainsword.com/topic/337178-flack-for-dkk/#findComment-4833455 Share on other sites More sharing options...
Chaplain Gunzhard Posted July 26, 2017 Share Posted July 26, 2017 Even a fully kitted out StormRaven shouldn't kill the Hydra in one turn. And as others have said the -1 to Hit isn't that hard to overcome now. You could also hire a Tech-priest Enginseer to keep fixing your tanks too. Link to comment https://bolterandchainsword.com/topic/337178-flack-for-dkk/#findComment-4833525 Share on other sites More sharing options...
