micahwc Posted July 27, 2017 Share Posted July 27, 2017 I've been asked about these in a couple of threads. They are Marx brand German WW2 88mm cannons. I've modified them by cutting the barrel nub down, and replacing it with a dowel slightly smaller than the thickest part of the barrel. The dowel is inset into the barrel, which was carved out with a dremel cutter. Card was added to make a muzzle break. This was done by wrapping a strip of card around the dowel I cut the barrel from, and super gluing it in place. Finally, the gun shield was cut an shaped with the Drexel, and then glued and green stuffed into place. This is the gun before modification next to a tempestus scion for scale. The stumpy barrel extension is what I cut off. http://i.imgur.com/yNrjXAy.jpg And here it is after modifying and after spraying it black. http://i.imgur.com/f0TNyGC.jpg http://i.imgur.com/yqVjzLD.jpg http://i.imgur.com/4tDNtsG.jpg http://i.imgur.com/QDg475b.jpg And finally, the entire battery: http://i.imgur.com/yvL0HDn.jpg These models where approximately $7 each, I think I paid $25 after shipping for all three. duz_ and CoffeeGrunt 2 Back to top Link to comment https://bolterandchainsword.com/topic/337202-earthshaker-carriage-proxies/ Share on other sites More sharing options...
major higgins Posted July 27, 2017 Share Posted July 27, 2017 Look solid. If you are interested, now victoria miniature sell shield plate for big guns Link to comment https://bolterandchainsword.com/topic/337202-earthshaker-carriage-proxies/#findComment-4834335 Share on other sites More sharing options...
micahwc Posted July 27, 2017 Author Share Posted July 27, 2017 I didn't see the big gun plates, but I did see the BFG shells and those look promising. Though the boxes of ammo are not particularly realistic for large artillery shells. 155mm comes in a pallet of 8 rounds stored vertically, and three such pallets are generally connected together. Each pallet kind of has a side profile shaped like a capital I, as there is a top wooden piece and a bottom wooden piece which are horizontal and then 8 rounds stored vertically between them. One pallet of 8 weighs approximately 800 pounds (362 kilos I think). These are generally "broken down" and moved by hand, 1 round at a time per person. The full 24 count pallets are moved via crane as they weigh over 1 ton. According to one of the 40k wikis, Earthshakers are 130mm, so they would be slightly smaller than 155s, or about 5" in diameter. 155mm is approximately 6". 105mm shells are in smaller crates of 2 rounds, but they are what I like to call "cute baby artillery", that hope to one day grow as big and strong as the 155mm. Link to comment https://bolterandchainsword.com/topic/337202-earthshaker-carriage-proxies/#findComment-4834729 Share on other sites More sharing options...
major higgins Posted July 27, 2017 Share Posted July 27, 2017 https://victoriaminiatures.com/collections/artillery/products/sledgehammer-bfg-blast-shield Link to comment https://bolterandchainsword.com/topic/337202-earthshaker-carriage-proxies/#findComment-4834952 Share on other sites More sharing options...
SydonianDragoon404 Posted July 27, 2017 Share Posted July 27, 2017 This is great. I'm looking for a Manticore platform proxy now that FW don't sell them anymore. Link to comment https://bolterandchainsword.com/topic/337202-earthshaker-carriage-proxies/#findComment-4835003 Share on other sites More sharing options...
micahwc Posted July 28, 2017 Author Share Posted July 28, 2017 The gun is a seperate piece from the base, so I don't think it would be difficult to convert into a manticore. Link to comment https://bolterandchainsword.com/topic/337202-earthshaker-carriage-proxies/#findComment-4835939 Share on other sites More sharing options...
