Sugarlessllama Posted July 28, 2017 Share Posted July 28, 2017 Hello everyone! So with the coming of 8th I purchased the Dark Imperium starter set for the rule book and Primaris Marines. However, I am now noticing that in my area there seems to be a distinct lack of Non-Imperial armies being played. And since I kept the DG models that came in the boxed set I thought I might be able to fix that. But here is my problem.... I can't seem to come up with a color scheme. I have been wracking my brain trying to come up with something that is not the current primary studio scheme. And so, I come to you fine folks of the CSM boards... any nifty ideas you wouldn't mind sharing? Link to comment https://bolterandchainsword.com/topic/337278-requesting-some-help-in-creating-a-nurgle-warband/ Share on other sites More sharing options...
Lord Marshal Posted July 28, 2017 Share Posted July 28, 2017 I presume you've seen the Vectorum schemes in the Death Guard booklet from Dark Imperium? Link to comment https://bolterandchainsword.com/topic/337278-requesting-some-help-in-creating-a-nurgle-warband/#findComment-4836310 Share on other sites More sharing options...
Sugarlessllama Posted July 28, 2017 Author Share Posted July 28, 2017 Yeah, and some of them look interesting... but none of them really jumped out at me. Link to comment https://bolterandchainsword.com/topic/337278-requesting-some-help-in-creating-a-nurgle-warband/#findComment-4836331 Share on other sites More sharing options...
MikeyB83 Posted July 28, 2017 Share Posted July 28, 2017 I saw a Plaguebearer painted in shades of purple on a 40k facebook page. Looked interesting in my opinion. What sort of theme are you going for? Sugarlessllama 1 Back to top Link to comment https://bolterandchainsword.com/topic/337278-requesting-some-help-in-creating-a-nurgle-warband/#findComment-4836332 Share on other sites More sharing options...
Azekai Posted July 28, 2017 Share Posted July 28, 2017 Yellow is a good option often associated with an unhealthy pallor (yay liver failure!) and corruption. Not a glowing Imperial Fist yellow, but a treacly yellow, the color of crusty gound. Sugarlessllama 1 Back to top Link to comment https://bolterandchainsword.com/topic/337278-requesting-some-help-in-creating-a-nurgle-warband/#findComment-4836346 Share on other sites More sharing options...
Sugarlessllama Posted July 28, 2017 Author Share Posted July 28, 2017 (edited) As for theme, I am a little stuck on that one. I have been mulling it over for parts of the day and thought that a fleet based renegade warband might be fun. Maybe in addition to physical diseases, they all also suffer from severe mental illness, and thus they believe that they are helping the imperium by making hordes of zombies. But that is about as far as I got. I really hadn't thought much about starting a chaos force until I noticed that almost every match up I have had since 8th dropped has been some hot SM v SM action. And since I already owned a small but cohesive DG force via the Dark Imperium box I might be able to help mix things up a bit. And the purple sounds pretty interesting, as does that yellow..... Edited July 28, 2017 by Sugarlessllama Link to comment https://bolterandchainsword.com/topic/337278-requesting-some-help-in-creating-a-nurgle-warband/#findComment-4836358 Share on other sites More sharing options...
Isolia Posted July 28, 2017 Share Posted July 28, 2017 (edited) I'm doing a cross between Pallid Hand,Pox Mortis and Putrid Choir : Undercoat White Screaming skull base Trims and fringes with bronze General wash with diluted (3:2 with lahmian) Drakenhof nightshade, twice in the darker areas and on bronzes Glazes with quite dilute Nihilak Oxide It shall give a sickly pale oxidized blue over a kind of warm beige base that goes well with the bronze and gives a less shiny Putrid Choir theme . The idea is to have a 30k-ish scheme that has not been taken care of for ten millennia and the oxidized bronze has seeped onto the whole armor. I'll try and get some pics soon . The theme will be more Putrid Choiry, with a lot of bells and a blightbringer or two to keep the poxwalkers marching. Here is also some tests I made with purple plaguebearers using washes : http://www.bolterandchainsword.com/topic/337214-quick-purple-daemons-poxwalkers-with-washes/?do=findComment&comment=4836369 I'm sure it can be used for Marines too, I'll give it a try if i have some time next week :) Edited July 28, 2017 by Isolia Sugarlessllama 1 Back to top Link to comment https://bolterandchainsword.com/topic/337278-requesting-some-help-in-creating-a-nurgle-warband/#findComment-4836381 Share on other sites More sharing options...
Azekai Posted July 28, 2017 Share Posted July 28, 2017 (edited) Hmm. Maybe have them be a bunch of crazy resurrectionists who believe that the only way of bringing final, eternal peace to the galaxy is by uniting Nurgle and the Emperor. Maybe they are think slaughtering and then raising the dead is actually a means of freeing the downtrodden Imperial citizenry... all as they slowly work their way toward Segmentum Solar in order to bring the blessing of unlife to the Corpse God. Or not, whatever. Zombies are fun though, and I do love Papa Nurgle. If you like having both yellow and purple, maybe use them both? They are complimentary. Purple oxygen-starved guts and corroded yellowing armor.Edit: Does your proto-vectorium have a name, Llama? Edited July 28, 2017 by Azekai Link to comment https://bolterandchainsword.com/topic/337278-requesting-some-help-in-creating-a-nurgle-warband/#findComment-4836386 Share on other sites More sharing options...
MikeyB83 Posted July 28, 2017 Share Posted July 28, 2017 Best thing is to mix it up maybe? Plus if you have the Dark Imperium set the plasma guys can be Chosen with a lil' old Nurgle-ification. You've definitely gone to the faction for customised minis and (modelling) options ;) Link to comment https://bolterandchainsword.com/topic/337278-requesting-some-help-in-creating-a-nurgle-warband/#findComment-4836387 Share on other sites More sharing options...
Sugarlessllama Posted July 28, 2017 Author Share Posted July 28, 2017 Whoa! That sounds pretty rad. Yeah, I really look forward to seeing that scheme. :D Isolia 1 Back to top Link to comment https://bolterandchainsword.com/topic/337278-requesting-some-help-in-creating-a-nurgle-warband/#findComment-4836388 Share on other sites More sharing options...
Leonite Posted July 28, 2017 Share Posted July 28, 2017 I do any vaguely Nurgle aligned models with skin in a pale blue, referencing the effect Cholera has on people. Isolia and Azekai 2 Back to top Link to comment https://bolterandchainsword.com/topic/337278-requesting-some-help-in-creating-a-nurgle-warband/#findComment-4836400 Share on other sites More sharing options...
DeadFingers Posted July 28, 2017 Share Posted July 28, 2017 Yellow is a good option often associated with an unhealthy pallor (yay liver failure!) and corruption. Not a glowing Imperial Fist yellow, but a treacly yellow, the color of crusty gound. Alternatively, go for an even more intense yellow and paint yourself some hazmat-esque radioactive Plague Marines. Link to comment https://bolterandchainsword.com/topic/337278-requesting-some-help-in-creating-a-nurgle-warband/#findComment-4836489 Share on other sites More sharing options...
Sugarlessllama Posted August 2, 2017 Author Share Posted August 2, 2017 So I picked up a pack of the push fit Plague Marines in order to dink around with paint schemes. However, I would love some feedback. :D Link to comment https://bolterandchainsword.com/topic/337278-requesting-some-help-in-creating-a-nurgle-warband/#findComment-4841960 Share on other sites More sharing options...
Azekai Posted August 2, 2017 Share Posted August 2, 2017 The color palette looks solid, if a bit typical. Some contrast could also help, as it looks very clean, almost polished. Any plague marine can be improved with streaks of blood, crusted bile and several centuries of dirt. :D Link to comment https://bolterandchainsword.com/topic/337278-requesting-some-help-in-creating-a-nurgle-warband/#findComment-4842140 Share on other sites More sharing options...
Warsmith Annüss Posted August 2, 2017 Share Posted August 2, 2017 (edited) I went with a Pallid Hand/Weeping Legion scheme for my Vectorium. I finally figured out what to do with the bases so will have more soon. So, I may be biased but I'm liking your scheme so far.https://www.flickr.com/gp/156756495@N04/7554rM Edited August 2, 2017 by Thrall_Love Link to comment https://bolterandchainsword.com/topic/337278-requesting-some-help-in-creating-a-nurgle-warband/#findComment-4842227 Share on other sites More sharing options...
Fhanados Posted August 3, 2017 Share Posted August 3, 2017 Mine are rusty brown. The flesh will eventually be a drowned-white kind of colour but the armour is basically done. In terms of background I stumbled upon mention of a renegade warband called Dark Tusks which wore corroded power armour and just went with that. I haven't read the novel they feature in though so I could be way off, but they have a cool name and match my colour scheme! Draakur and Azekai 2 Back to top Link to comment https://bolterandchainsword.com/topic/337278-requesting-some-help-in-creating-a-nurgle-warband/#findComment-4842455 Share on other sites More sharing options...
DuskRaider Posted August 3, 2017 Share Posted August 3, 2017 I'm a big fan of bone colored armour on Death Guard (using it myself), but you need a contrast color of some sort. Something to pop out on all the white. The tentacles do it alright, but the armour itself needs something. If you look at mine, I have black (actually a black built up to a dark grey - blue) to contrast the white of the armour, with red as a spot color in select places. http://i.imgur.com/t8mQGQEh.jpghttp://i.imgur.com/4Vl5rLfh.jpg Sugarlessllama, Azekai and Fhanados 3 Back to top Link to comment https://bolterandchainsword.com/topic/337278-requesting-some-help-in-creating-a-nurgle-warband/#findComment-4842486 Share on other sites More sharing options...
Panzer Posted August 3, 2017 Share Posted August 3, 2017 The Iron Warrior Plague Marines in the 4 Generals in last months White Dwarf looked pretty nice as well. Since he wanted to stay true to the Iron Warrior color scheme but didn't think it'd fit Plague Marines he instead went for a grey-ish color scheme for them. I won't be able to take any pics for a good 10h since I just arrived at work but maybe someone else can. My mobile cam isn't good at all anyway. Link to comment https://bolterandchainsword.com/topic/337278-requesting-some-help-in-creating-a-nurgle-warband/#findComment-4842514 Share on other sites More sharing options...
