Bythehololight Posted July 30, 2017 Share Posted July 30, 2017 If I have my veteran tactical squad using the outflank and sniper buff. Can the outflank inside a dreadclaw? Also can dreadclaw zoom? Or it it always in hover mode or landed? Thanks chaps Link to comment https://bolterandchainsword.com/topic/337336-dreadclaw-with-veteran-tacticals/ Share on other sites More sharing options...
Slips Posted July 30, 2017 Share Posted July 30, 2017 Its a flyer so it can zoom, yes, but arrives in hover mode per its entry if you deep strike it. Now, that said, iirc, Outflank is omly conferred to vehicles if its a dedicated transport for the unit conferring the rule. As to outflanking them, why? Theyve got Drop Pod Assault and Inertial Guidance and can turbo boost for even better positioning. BLACK BLŒ FLY 1 Back to top Link to comment https://bolterandchainsword.com/topic/337336-dreadclaw-with-veteran-tacticals/#findComment-4837677 Share on other sites More sharing options...
Bythehololight Posted July 30, 2017 Author Share Posted July 30, 2017 Thanks for the reply slips. I actually use the dreadclaw so i can bring in 2 dreadnought drop pods on turn 1. If I don't deepstrike the dreadclaw, does that mean the dreadnought drop pods will not be able to arrive turn 1? I was considering outflanking the dreadclaw just to have a entire table edge of no scatter placement. You are right inertial guidance should be good enough, I'm wary about scatter off the table edge. Its a flyer so it can zoom, yes, but arrives in hover mode per its entry if you deep strike it. Now, that said, iirc, Outflank is omly conferred to vehicles if its a dedicated transport for the unit conferring the rule. As to outflanking them, why? Theyve got Drop Pod Assault and Inertial Guidance and can turbo boost for even better positioning. Link to comment https://bolterandchainsword.com/topic/337336-dreadclaw-with-veteran-tacticals/#findComment-4837752 Share on other sites More sharing options...
Lord Asvaldir Posted August 1, 2017 Share Posted August 1, 2017 No need to be wary of the table edge, just deploy twelve inches from the table edge than turbo boost 24", meaning you can basically get anywhere you want. More drop pods in drop pod assault means more pods that can come on the board turn one so I don't see why you'd ever want to outflank a dreadclaw. Link to comment https://bolterandchainsword.com/topic/337336-dreadclaw-with-veteran-tacticals/#findComment-4840981 Share on other sites More sharing options...
Bythehololight Posted August 3, 2017 Author Share Posted August 3, 2017 No need to be wary of the table edge, just deploy twelve inches from the table edge than turbo boost 24", meaning you can basically get anywhere you want. More drop pods in drop pod assault means more pods that can come on the board turn one so I don't see why you'd ever want to outflank a dreadclaw. Awesome, thanks for the advice Link to comment https://bolterandchainsword.com/topic/337336-dreadclaw-with-veteran-tacticals/#findComment-4842511 Share on other sites More sharing options...
Bythehololight Posted August 3, 2017 Author Share Posted August 3, 2017 Can a dreadclaw land as soon as it arrives? Or does it have to arrive in hover mode? I ask in case someone use intercept and tries to shoot it down the turn it arrives Link to comment https://bolterandchainsword.com/topic/337336-dreadclaw-with-veteran-tacticals/#findComment-4842686 Share on other sites More sharing options...
Slips Posted August 3, 2017 Share Posted August 3, 2017 Hove mode is its landed state; its not immobilized like a regular pod when it arrives. And with if youre afraid of Interceptor, just land it out of range and turbo boost it where you want it to be once the movement phase is done and your opponent can no longer intercept. Link to comment https://bolterandchainsword.com/topic/337336-dreadclaw-with-veteran-tacticals/#findComment-4842718 Share on other sites More sharing options...
Bythehololight Posted August 3, 2017 Author Share Posted August 3, 2017 Hove mode is its landed state; its not immobilized like a regular pod when it arrives. And with if youre afraid of Interceptor, just land it out of range and turbo boost it where you want it to be once the movement phase is done and your opponent can no longer intercept. Rightio. Thanks again Slips Link to comment https://bolterandchainsword.com/topic/337336-dreadclaw-with-veteran-tacticals/#findComment-4843630 Share on other sites More sharing options...
Ghorgul Posted October 4, 2017 Share Posted October 4, 2017 Nothing optional in the Drop Pod Assault rule. Link to comment https://bolterandchainsword.com/topic/337336-dreadclaw-with-veteran-tacticals/#findComment-4902500 Share on other sites More sharing options...
NoLifeKing Posted October 13, 2017 Share Posted October 13, 2017 Nothing optional in the Drop Pod Assault rule. This. Link to comment https://bolterandchainsword.com/topic/337336-dreadclaw-with-veteran-tacticals/#findComment-4907983 Share on other sites More sharing options...
Baluc Posted October 17, 2017 Share Posted October 17, 2017 Also outflank is only shared with dedicated transports, not any vehicle a unit happens to be transporting a unit with infiltrate/scout/outflank. Link to comment https://bolterandchainsword.com/topic/337336-dreadclaw-with-veteran-tacticals/#findComment-4911228 Share on other sites More sharing options...
