HeresyBeliever Posted August 3, 2017 Share Posted August 3, 2017 So I am after some clarity, Disgustingly Resilient rules is : Eath Time a Nurgle Daemon with this ability loses a wound, roll a D6 on a 5+ the model does not lose a wound War lord trait rule : Roll a D6 each time the warlord loses a wound. On a 6 the warlord does not lose the wound. So when a model is Hit, Wounded, then fails their Armour/invol save against a weapon with 3 Damage do you either: Roll one dice that ignores all the Damage or Roll 3 dice one for each wound caused by the damage Thank you for your help Link to comment Share on other sites More sharing options...
Medicinal Carrots Posted August 3, 2017 Share Posted August 3, 2017 (edited) From the Designer's Commentary FAQ: Q: When rolling for abilities such as ‘Disgustingly Resilient’ or ‘Tenacious Survivor’ against attacks which inflict multiple wounds, do you roll to ignore each individual wound inflicted by the attack, or do you roll only once to ignore all the wounds inflicted by the attack? A: Roll to avoid each wound lost separately. For example, if a model with Disgustingly Resilient fails its saving throw against an attack made by a thunder hammer (Damage 3), you would roll three dice and for each result of 5+ you would ignore a single wound. The links for all Rulebook, and Index FAQ are on this page: https://www.warhammer-community.com/2017/07/23/updated-faqs-and-boots-on-the-groundgw-homepage-post-2/ Forge World FAQ here: https://www.warhammer-community.com/2017/07/15/new-and-updated-forge-world-faqs-july16gw-homepage-post-2/ The specific FAQ containing this question is here: https://17890-presscdn-0-51-pagely.netdna-ssl.com/wp-content/uploads/2017/07/Warhammer_40000_Designers_Commentary.pdf Edited August 3, 2017 by Medicinal Carrots Link to comment Share on other sites More sharing options...
Medicinal Carrots Posted August 3, 2017 Share Posted August 3, 2017 (edited) · Hidden by Eddie Orlock, August 3, 2017 - Double post Hidden by Eddie Orlock, August 3, 2017 - Double post Double post Edited August 3, 2017 by Medicinal Carrots Link to comment
Brother Captain Sirus Posted August 3, 2017 Share Posted August 3, 2017 You would roll 3 dice using the disgustingly resilient 5+. Then if you still take wounds after this, you can roll your 6+ warlord trait for every wound still taken, 1 to 3 depending if you saved any with the 5+ roll. As they are seperate rules you can use both, its in one of the faqs but i cant remember which. Link to comment Share on other sites More sharing options...
