Valkyrion Posted August 3, 2017 Share Posted August 3, 2017 Daft question alert...! 'Does not include wargear' means that you only pay for whatever options are listed under the 'wargear options' section of the datasheet; whatever items come as standard is included in the points cost of the unit, correct? Link to comment https://bolterandchainsword.com/topic/337553-confusion-over-points/ Share on other sites More sharing options...
Silentz Posted August 3, 2017 Share Posted August 3, 2017 (edited) Incorrect. You need to pay for everything the model has. If the cost of the wargear is nominal or baked into the model cost (e.g. a bolt pistol or frag grenade) then it's points cost will be listed as 0. As an example, a terminator Model base cost 26 Power Fist 12 Storm Bolter 2 Total cost for 1 standard Terminator 40 pts Edited August 3, 2017 by Silentz Kisada and deus lo volt 2 Back to top Link to comment https://bolterandchainsword.com/topic/337553-confusion-over-points/#findComment-4842723 Share on other sites More sharing options...
Valkyrion Posted August 3, 2017 Author Share Posted August 3, 2017 Wow - stuffs gonna be expensive then! I presume every thing on the datasheet is mandatory though - e.g, you can't buy a Land Raider without twin heavy bolters. Link to comment https://bolterandchainsword.com/topic/337553-confusion-over-points/#findComment-4842825 Share on other sites More sharing options...
Silentz Posted August 3, 2017 Share Posted August 3, 2017 Wow - stuffs gonna be expensive then! I presume every thing on the datasheet is mandatory though - e.g, you can't buy a Land Raider without twin heavy bolters. Everything is mandatory. Note that if you swap out the heavy bolters for, say, lascannons - you play the lascannon cost INSTEAD of the heavy bolter cost, not in addition to it. Link to comment https://bolterandchainsword.com/topic/337553-confusion-over-points/#findComment-4842834 Share on other sites More sharing options...
Valkyrion Posted August 3, 2017 Author Share Posted August 3, 2017 Gotcha. Thanks. Link to comment https://bolterandchainsword.com/topic/337553-confusion-over-points/#findComment-4842837 Share on other sites More sharing options...
ONDIG Posted August 3, 2017 Share Posted August 3, 2017 · Hidden by Eddie Orlock, August 3, 2017 - Off Topic, vaguly trollish. Hidden by Eddie Orlock, August 3, 2017 - Off Topic, vaguly trollish. Or just use Power levels and rake in the savings! Link to comment https://bolterandchainsword.com/topic/337553-confusion-over-points/#findComment-4843122
deus lo volt Posted August 10, 2017 Share Posted August 10, 2017 I've been looking for this answer, thanks! Link to comment https://bolterandchainsword.com/topic/337553-confusion-over-points/#findComment-4851144 Share on other sites More sharing options...
