TheShredder Posted August 4, 2017 Share Posted August 4, 2017 I run infantry-IG armies based around multiple pseudo-platoons along these lines:Company CommanderCommissarInfantry Squad with Lascannon and PlasmagunInfantry Squad with Missile Launcher and PlasmagunInfantry Squad with FlamerHWS with 3 Heavy Bolters My question is - do you think I'd be better off with a Lascannon in the second squad, instead of a Missile Launcher? Or are Missile Launchers with it for the extra versatility over Lascannons? I ask because i like having some variety in my lists, however, I'm also aware that I've only ever used a Missile Launcher's Frag mode once, so I'm wondering if Lascannons would be the pragmatic choice. Any thoughts? Link to comment Share on other sites More sharing options...
Kinstryfe Posted August 4, 2017 Share Posted August 4, 2017 While flexibility is good, one thing I've gleaned along for similar advice is that in most cases you want your units to have a goal or purpose. Lascannons are there to blow up big things, and missile launchers seem to only be good if you specifically need that anti-infantry mode. If you're running a flamer and 3 heavy bolters with each of these platoons (and I assume you run multiple?) That's a decent amount of anti infantry, and personally I'd take the Lascannon to help kaboom bigger targets. Just my humble $.02. Halfpint100 1 Back to top Link to comment Share on other sites More sharing options...
Halfpint100 Posted August 5, 2017 Share Posted August 5, 2017 While flexibility is good, one thing I've gleaned along for similar advice is that in most cases you want your units to have a goal or purpose. Lascannons are there to blow up big things, and missile launchers seem to only be good if you specifically need that anti-infantry mode. If you're running a flamer and 3 heavy bolters with each of these platoons (and I assume you run multiple?) That's a decent amount of anti infantry, and personally I'd take the Lascannon to help kaboom bigger targets. Just my humble $.02. I agree with this. while missiles and lascannons look similar anti-armour wise. that str 9 means you wound pretty much all vehicles on a 3+. while missiles would on a 4+ against the big guys (land raiders, russes, knights, etc) and with the amount of anti-infantry you already have there. I would go for a second lascannon Link to comment Share on other sites More sharing options...
TheShredder Posted August 5, 2017 Author Share Posted August 5, 2017 That's good advice and an excellent point regarding the strength of Lascannons vs the toughness of most heavy vehicles. Cheers, guys. Link to comment Share on other sites More sharing options...
duz_ Posted August 5, 2017 Share Posted August 5, 2017 Given they are the same point cost Id take Lascannons for pure AT duties. However MLs do offer flexibility against hordes for take all comer lists. Link to comment Share on other sites More sharing options...
mertbl Posted August 5, 2017 Share Posted August 5, 2017 I use 2xlascannon heavy weapon squads and 1 missile launchers squad. The frags are a bonus. It is nice having the option for up to 18 shots against some horde when they are the only available target. i found myself shooting at plaguebearers with lascannons because I didn't have proper targets. Link to comment Share on other sites More sharing options...
Stylian_StHugh Posted August 5, 2017 Share Posted August 5, 2017 Always lascannon over missile launcher. The frag is just...naff. Why would you ever use it now when you can dish out D6 D to a tough target? It really needs to be a few points cheaper and to come with flakk missiles to be a viable choice again this edition Link to comment Share on other sites More sharing options...
DrLoveMonkey Posted August 6, 2017 Share Posted August 6, 2017 (edited) I'd say that probably what's best is to have a mix of lascanons and maybe heavy bolters or autocannons for other targets, but I don't think missile launchers are an awful choice. Being able to choose their ammunition has a few benefits that are not immediately obvious. For one if you're not list tailoring against an opponent, which isn't always a malicious thing mind you, it let's you have some flexibility against horde and monster/tank armies. It also lets you pick based on that particular turn. Did a very dangerous monster just appear from behind LOS and you need it dead right now? 9 krak missiles ought to help, and at T6/T7 not really be any worse than a lascanon. But then the next turn you seriously need to clear those pox walkers out before they charge? 9d6 frag shots help, and then overwatch with the same if you get multi charged. I'm not saying it's better than going a mix of H. bolters and lascannons, but it's also not strictly worse either. Edited August 6, 2017 by DrLoveMonkey Link to comment Share on other sites More sharing options...
Beams Posted August 6, 2017 Share Posted August 6, 2017 I like missile launchers. You don't lose much, but gain a lot of flexibility in your list. So, maybe it's not "ideal" in either situation, but if you go heavy on missiles than your never unprepared. Just my 2c. Kallas 1 Back to top Link to comment Share on other sites More sharing options...
