Jackalwolf Posted August 5, 2017 Share Posted August 5, 2017 Thoughts? Could it pass by Mkiv Chemos pattern? Link to comment Share on other sites More sharing options...
Dagoth Ur Posted August 5, 2017 Share Posted August 5, 2017 I quite like it. I've undertaken attempts to convert primaris into mk IV truescale myself and I have found that trimming down the collar, replacing the shoulders as well as bolter and trimming away the knee trim (potentially resculpting the knees if you feel that fancy) goes a very long way to pull away from the Primaris aesthetic,so that'd be my reccomendations if you feel like changing anything :) Link to comment Share on other sites More sharing options...
Lord Commander Eidolon Posted August 5, 2017 Share Posted August 5, 2017 I'm having similar thoughts mate, the new models are just begging to be painted Pink!! Purists will point out the leg greaves will need some conversion, to make them look less mkX and more mkIV. I was actually thinking using plastic rod and shaping them; I'll need to pick up the multipart set and have a ponder!! Reivers legs might be an easier alternative, as they lack the trim, but they'll require filling, so it's not a straight forward fix either way! Link to comment Share on other sites More sharing options...
Trixie Posted August 6, 2017 Share Posted August 6, 2017 Bring on the pink ! Link to comment Share on other sites More sharing options...
