Wargamer Posted August 9, 2017 Share Posted August 9, 2017 Let's say there's a unit of Primaris Space Marines. One model has 1 wound remaining, the rest are unharmed. If I fire a 2 damage weapon at that squad and successfully wound, which model is prioritised for removal? The 1 wound model or the unharmed models? Link to comment https://bolterandchainsword.com/topic/337868-question-on-model-removal/ Share on other sites More sharing options...
Commander Dawnstar Posted August 9, 2017 Share Posted August 9, 2017 The rules for allocating Wounds specifically say that if a model in a unit has lost any wounds then damage must be assigned to them first. Link to comment https://bolterandchainsword.com/topic/337868-question-on-model-removal/#findComment-4850606 Share on other sites More sharing options...
Ciler Posted August 9, 2017 Share Posted August 9, 2017 I will add that since the the model has already lost one wound, the excess damage is lost and does not carry over to a different model, as per the inflict damage panel : If a model loses several wounds from a single attack and is destroyed, any excess damage inflicted by that attack is lost and has no effect. Link to comment https://bolterandchainsword.com/topic/337868-question-on-model-removal/#findComment-4850644 Share on other sites More sharing options...
Medicinal Carrots Posted August 9, 2017 Share Posted August 9, 2017 (edited) Also of note is that when firing weapons with random damage against multi-wound units, you need to roll the damage 1 at a time to see what order they get allocated in. For example, a squad of 10 Primaris are being shot at by something with D3 damage. 1 Primaris has 1 wound, the rest are full health. The Primaris fail 5 saves. 1st damage roll doesn't matter, the wounded Primaris dies. Even if they roll a 3, only that model dies. 2nd damage roll a 1, Primaris owner picks a model to get wounded. 3rd damage roll doesn't matter for the same reason as the 1st, and the Primaris wounded by the 2nd roll dies. 4th damage roll is a 3. Primaris owner picks a 3rd model to die. 5th damage roll is another 1. Primaris owner picks a model to take a wound. Edited August 9, 2017 by Medicinal Carrots Link to comment https://bolterandchainsword.com/topic/337868-question-on-model-removal/#findComment-4850910 Share on other sites More sharing options...
ONDIG Posted August 10, 2017 Share Posted August 10, 2017 Recently had an argument about weapons that do d3,d6 dmg. My opponent seemed to believe that you make a single roll and that then set the Dmg. for all subsequent wounds.I realize certain weapons (Deffgunz) function this way as per the wpn. Entry ,but other wpns. as well?Has anyone else been playing it this way ? Link to comment https://bolterandchainsword.com/topic/337868-question-on-model-removal/#findComment-4851251 Share on other sites More sharing options...
Eddie Orlock Posted August 10, 2017 Share Posted August 10, 2017 Has anyone else been playing it this way ?No, because it's a special interruption for Ork Deffgunz, and isn't even for wounds, but for attack generation. As an act it stands contrary to the instruction in the core rules that would by default have us resolve all attacks one at a time. Link to comment https://bolterandchainsword.com/topic/337868-question-on-model-removal/#findComment-4851284 Share on other sites More sharing options...
Spinsanity Posted August 10, 2017 Share Posted August 10, 2017 (edited) Has anyone else been playing it this way ?The rules say not to... See the Battle Primer sidebar on page 13: Modifying Characteristics [...] You may encounter a characteristic that is a random value instead of a number. For example, a Move characteristic might be 2D6", or an Attacks value might be D6. When a unit with a random Move characteristic is selected to move, determine the entire unit’s move distance by rolling the indicated number of dice. For all other characteristics, roll to determine the value on an individual – per-model – basis each time the unit makes attacks, inflicts damage, and so on. (emphasis mine) So random move is per unit, everything else is per model... Edited August 10, 2017 by Spinsanity Link to comment https://bolterandchainsword.com/topic/337868-question-on-model-removal/#findComment-4852440 Share on other sites More sharing options...
LucidNinja Posted August 11, 2017 Share Posted August 11, 2017 Hmm that's interesting that it's per model, so say that a weapon is heavy3 d3 damage all 3 shots would be of the same damage value? Link to comment https://bolterandchainsword.com/topic/337868-question-on-model-removal/#findComment-4853743 Share on other sites More sharing options...
Ciler Posted August 12, 2017 Share Posted August 12, 2017 No. You do your 3 rolls to hit, and then for each hit that wounds and isn't saved you then roll a D3 to see what damage is inflicted. Link to comment https://bolterandchainsword.com/topic/337868-question-on-model-removal/#findComment-4854013 Share on other sites More sharing options...
LucidNinja Posted August 12, 2017 Share Posted August 12, 2017 No. You do your 3 rolls to hit, and then for each hit that wounds and isn't saved you then roll a D3 to see what damage is inflicted.Mk that's what I thought but per model was confusing Link to comment https://bolterandchainsword.com/topic/337868-question-on-model-removal/#findComment-4854614 Share on other sites More sharing options...
