Gamer_217 Posted August 9, 2017 Share Posted August 9, 2017 Working on deciding how to paint flamers for my Salamanders and saw the heat shroud work on the Knight Warden exhaust pipes on GW's site: Anyone know how to get this look? Link to comment https://bolterandchainsword.com/topic/337870-painting-heat-shrouds/ Share on other sites More sharing options...
jaxom Posted August 9, 2017 Share Posted August 9, 2017 (edited) Bronze color of your choice for the base color and a very light silver for fine edge highlights. The exhaust build up can be done using a technique similar to that shown in the WHTV Muzzle Burn video. The video colors would work just as well, but it seems to me that the Knight goes from a black ink at the top (rather than purple) through shades of brown. EDIT: Forgot the link to the video. https://youtu.be/jIKEfVoqC5U Edited August 9, 2017 by jaxom Link to comment https://bolterandchainsword.com/topic/337870-painting-heat-shrouds/#findComment-4850695 Share on other sites More sharing options...
Ovidius Incertus Posted August 9, 2017 Share Posted August 9, 2017 (edited) Very easy with an airbrush. A bit more time consuming with a regular brush because of drying time. Depending on the base metal and the type of heat scarring you're trying to achieve, you just use a series of washes: sepia, brown, blue, violet. I'm currently using a mix of old GW washes (e.g. Asurmen Blue) and new stuff (Agrax) but those basic four colors get you all the variation you need. Be patient with your gradation and don't forget to overlap the colors a bit. If you're brushing, let it dry; it'll take a while and many coats, probably. If you're airbrushing, don't spray too much because you'll easily cause ripples since the color is so wet; blow air from a distance to shorten your time between coats. Note of caution: if you mask the exhaust at some point after you've done your discoloration, make sure you've varnished first. Every time I've done so and not varnished, I've ruined my work. I assume because of how little pigment is actually in the wash. Here are some examples using only those four colors. No black was used at all; personally, I don't think it gives the tone you'd want. If you want soot at the tip, dry pigment or even black paint is a better option. Also shows the tones you'll get with different base metal colors. The exhaust on the Land Raider is Vallejo Metal Color White Aluminum; the muffler tip is VMC Gunmetal Grey (IIRC). The thermal cannon baffle is, I think, Metal Color Gold, and the muzzles are Vallejo Model Air Steel. Edited August 9, 2017 by Ovidius Incertus Stoic Raptor, KhorneHunter57x and jaxom 3 Back to top Link to comment https://bolterandchainsword.com/topic/337870-painting-heat-shrouds/#findComment-4850977 Share on other sites More sharing options...
Claws and Effect Posted August 10, 2017 Share Posted August 10, 2017 (edited) I use silver for most of my exhausts. Then I drybrush a good chunk of it with gold, copper, or a metallic chocolate brown I have. Then I drybrush the end with flat black. Edited August 10, 2017 by Claws and Effect Link to comment https://bolterandchainsword.com/topic/337870-painting-heat-shrouds/#findComment-4852077 Share on other sites More sharing options...
Gamer_217 Posted August 10, 2017 Author Share Posted August 10, 2017 Ok thanks. I'll look into testing with some gold and copper colored paints with sprue pieces to see what looks best. Link to comment https://bolterandchainsword.com/topic/337870-painting-heat-shrouds/#findComment-4852138 Share on other sites More sharing options...
