JimVandy85 Posted August 9, 2017 Share Posted August 9, 2017 (edited) Hi guys and gals! Long time lurker here. Finally decided to sign up and post pics of my recently converted Sword Brethren Assault Terminators. These were made using a variety of parts including deathwing knights torsos, forge world shoulders (recasts), and spellcrow hammers and shields. These also show off my first attempt at green stuffing shackles. Overall, I believe they turned out really well. Please let me know what you think. Edited August 9, 2017 by DarkApostle85 Link to comment Share on other sites More sharing options...
+Chaplain Matthias+ Posted August 9, 2017 Share Posted August 9, 2017 Very nice! Looks like we had a similar idea. I like you're greenstuff work JimVandy85 1 Back to top Link to comment Share on other sites More sharing options...
JimVandy85 Posted August 9, 2017 Author Share Posted August 9, 2017 Very nice! Looks like we had a similar idea. I like you're greenstuff work Thanks for your response. I'm going to try my hand at sculpting tabards soon. I've got 60 mkivs lying around that I need to do something with. Honda 1 Back to top Link to comment Share on other sites More sharing options...
Honda Posted August 10, 2017 Share Posted August 10, 2017 Nice start, the Spellcrow bits look really good. Another tip for making shackles that I sort of stumbled into is cutting a segment from a plastic tube the width you want, then slice it down the middle to make two halves. Then you can fix it around the wrist, add a little GS for the lock and hinge and your off the the races. I had to find another way to make the shackles because my GS attempts weren't going as well as I liked. I think yours are fine, but if you have a bunch of Mk IVs to work on, that's a lot of GS work. I'm looking forward to seeing some paint on them. Cheers, Link to comment Share on other sites More sharing options...
Dumbcow1 Posted August 10, 2017 Share Posted August 10, 2017 cant wait to see them painted up and ready for the Crusade!!!!!! Post pics on your work here! Link to comment Share on other sites More sharing options...
JimVandy85 Posted August 10, 2017 Author Share Posted August 10, 2017 Another tip for making shackles that I sort of stumbled into is cutting a segment from a plastic tube the width you want, then slice it down the middle to make two halves. When you say plastic tube are you referring to plasticard tubing? If so, what diameter did you use? Paint will be a few weeks away. I've ordered a bottle of createx auto air candy pigment black to try out. I'm wanting to do these in a metallic scheme simply because I like that look. I've also ordered a meter of 1.5mm chain to test out. Even though the chains on the terminators turned out fine, they look a little small to my eye. Thank you so much for the tips and suggestions. Any other comments and suggestions are welcome and much appreciated. Link to comment Share on other sites More sharing options...
Honda Posted August 11, 2017 Share Posted August 11, 2017 When you say plastic tube are you referring to plasticard tubing? If so, what diameter did you use? Correct, plasticard tubing. The two diameters I appear to have is, 3/16" (4.8 mm) and 5/32" (4.0 mm). Here's a picture of Mordred's crozius for my scratch built Grimaldus. Link to comment Share on other sites More sharing options...
JimVandy85 Posted August 11, 2017 Author Share Posted August 11, 2017 When you say plastic tube are you referring to plasticard tubing? If so, what diameter did you use? Correct, plasticard tubing. The two diameters I appear to have is, 3/16" (4.8 mm) and 5/32" (4.0 mm). Here's a picture of Mordred's crozius for my scratch built Grimaldus. That looks so much better than my meager attempt. Consider that stolen, sir! Honda 1 Back to top Link to comment Share on other sites More sharing options...
