Mileposter Posted August 10, 2017 Share Posted August 10, 2017 Thin models. Precarious positions. Frail weaponry. The physique of the Space Elves (light, dark, and laughing varieties) is one of lithe and nimble grace. Unfortunately, this makes their models a pain to transport stock, to say nothing of any additions we crafters might make to the fragile package. I'm looking for some way to transport my Aeldari safely to and from the places I'll be playing. Solutions I've tried thus far have not been satisfactory. So I'd like to see - how do you transport your unseemly balanced models (like jetbikes) to a fro? I'm hoping to pine together a solution for my own woes. Link to comment https://bolterandchainsword.com/topic/337925-transporting-aeldari/ Share on other sites More sharing options...
CrystalSeer Posted August 10, 2017 Share Posted August 10, 2017 The gw cases actually work pretty well. I've got my entire harlequins army in one. Aside from that, buy Tupperware and metal sheet from Walmart/home depot, Then put magnets in bases. Link to comment https://bolterandchainsword.com/topic/337925-transporting-aeldari/#findComment-4852179 Share on other sites More sharing options...
Mileposter Posted August 11, 2017 Author Share Posted August 11, 2017 Looking at the GW cases, it seemed like the way the foam walls were set might bend/damage the thin pieces of the models - like the spears and bolas' of your Harlequins. How is that faring for you? How do your jetbikes sit in the GW case? walter h 1 Back to top Link to comment https://bolterandchainsword.com/topic/337925-transporting-aeldari/#findComment-4853098 Share on other sites More sharing options...
CrystalSeer Posted August 11, 2017 Share Posted August 11, 2017 I removed two foam sections to make extra room for vehicles and bikes. There are no issues with the infantry. Link to comment https://bolterandchainsword.com/topic/337925-transporting-aeldari/#findComment-4853278 Share on other sites More sharing options...
Spiritual Liege Posted August 18, 2017 Share Posted August 18, 2017 Aside from that, buy Tupperware and metal sheet from Walmart/home depot, Then put magnets in bases.The problem with this are the transparent hovering bases that bikes and grav tanks come with. Link to comment https://bolterandchainsword.com/topic/337925-transporting-aeldari/#findComment-4861437 Share on other sites More sharing options...
Mileposter Posted August 18, 2017 Author Share Posted August 18, 2017 Aside from that, buy Tupperware and metal sheet from Walmart/home depot, Then put magnets in bases.The problem with this are the transparent hovering bases that bikes and grav tanks come with. This is the basis of my issue, yarr. Lots of bikes! Link to comment https://bolterandchainsword.com/topic/337925-transporting-aeldari/#findComment-4861563 Share on other sites More sharing options...
The_Chaplain Posted August 20, 2017 Share Posted August 20, 2017 (edited) Aside from that, buy Tupperware and metal sheet from Walmart/home depot, Then put magnets in bases. I would just like to say, that is a fantastic idea and I will probably shamelessly use that in the future; my bases tend to tip so gluing washers to the bottoms and then having a cookie tin covered in magnets to keep them in place would solve a lot of transporting issues for me, One method a local player uses for transporting his bikes is using plastic egg cartons (I don't know what brand of eggs they are, but the casing is really domed and allows the bikes to nestle in perfectly). Edited August 20, 2017 by The_Chaplain Link to comment https://bolterandchainsword.com/topic/337925-transporting-aeldari/#findComment-4862896 Share on other sites More sharing options...
CrystalSeer Posted August 23, 2017 Share Posted August 23, 2017 I replaced the transparent base on my bikes with standard bases. Just drill a hole in the center and slot the stem in. Link to comment https://bolterandchainsword.com/topic/337925-transporting-aeldari/#findComment-4866259 Share on other sites More sharing options...
The_Chaplain Posted August 24, 2017 Share Posted August 24, 2017 (edited) I replaced the transparent base on my bikes with standard bases. Just drill a hole in the center and slot the stem in. Yep, I did this too- it allows for basing opportunities that clear bases don't as well. Edited August 24, 2017 by The_Chaplain Link to comment https://bolterandchainsword.com/topic/337925-transporting-aeldari/#findComment-4866911 Share on other sites More sharing options...
hushrong Posted September 14, 2017 Share Posted September 14, 2017 Guy in my group did as CrystalSeer has said more or less. Plastic toolbox, fitted and secured thin metal sheets, and magnets in the bases. By some dark magic it held his venoms and bikes pretty darn good. I am more amazed they didn't come off the plastic stands. Could I recommend battlefoam? They have pluck-foam trays and even ones shaped for particular units too, plus cases to boot. Link to comment https://bolterandchainsword.com/topic/337925-transporting-aeldari/#findComment-4886466 Share on other sites More sharing options...
jlmb_123 Posted October 9, 2017 Share Posted October 9, 2017 The direct alternative to a metal sheet in a box with magnets in the bases is what I've done with my BFG fleet. Buy a magnetic sheet (used for signs on the side of cars (like taxis)) from ebay for about £4 and glue large, flat washers to the bottom of your bases. Link to comment https://bolterandchainsword.com/topic/337925-transporting-aeldari/#findComment-4904546 Share on other sites More sharing options...
