Taken from the FAQ:
Q: When making a hit roll with a supercharged plasma weapon, do you determine whether a ‘1’ was rolled before or after applying re-rolls and modifiers?
A: You apply all re-rolls and modifiers first. For example, if, after re-rolls and modifiers, the final result is then a 1 (or counts as a 1, as explained above), then the supercharged plasma weapon injures or kills the firer.
Q: If a rule or ability grants a re-roll on, for example, ‘hit rolls of 1’ (such as a Space Marine Captain’s Rites of Battle ability) does that effect trigger before or after applying modifiers to the hit rolls? A: Re-rolls always happen before modifiers, so the re-roll ability is triggered before applying modifiers. For example, let’s imagine a Space Marine (Ballistic Skill 3+) moves and fires a heavy bolter (a Heavy 3 weapon) whilst within range of a Space Marine Captain’s Rites of Battle ability (allowing you to re-roll hit rolls of 1). The hit dice are rolled and result in a 1, 2 and 5. Re-rolls are applied before modifiers. In this example a single dice is re-rolled because of the Captain’s ability, this time resulting in a 3. Modifiers are applied after re-rolls. In this example there is a -1 modifier to the hit rolls for moving and firing a Heavy weapon. That means that the post-re-roll scores of 2, 3 and 5 are modified to 1, 2 and 4. Comparing the final results to the model’s Ballistic Skill, only one shot hits the target.
So yes. According to this, pask and the command salamander does equal all dice are 2+
For shooting, wounding and armor saves, "A roll of 1 always fails, irrespective of any modifiers that may apply."
So a command tank can prevent overheats, but those attacks still miss.  And if you move, or are firing at Raven Guard/Night Lords/Alpha Legion/Fliers, rolls of 1 will be modified to 2 and then back down to 1, the sponsons will both overheat and miss.
Edited by Withershadow
Whenever I ask a question we always seem to come back to discussing this overheat rule! I guess that's what happens when the answer to everything in the game is "overheated plasma"...
I thought it was:
Re-rolls taken before any modifiers applied
Any extra effects resolved after modifiers applied
Natural 1's always fail (but not for any extra dice related effects like exploding plasma)
Register a new account
Sign in
