Brendaen Posted August 12, 2017 Share Posted August 12, 2017 Howdy fellow tread heads. I'm looking through the IA: Index - Forces of the Astra Militarum and I have a big problem: The point cost of the Thunderer and the Demolisher cannon puts it a 40 points more than a Demolisher tank (which has one addition hull weapon). Surely the initial points cost of the Thunderer includes the cost of it's cannon. That has to be a typo... My Thunderer is one of my favorite tanks... Link to comment https://bolterandchainsword.com/topic/338004-forgeworld-thunderer-question/ Share on other sites More sharing options...
Halfpint100 Posted August 12, 2017 Share Posted August 12, 2017 Even if it is a typo or not. That is the points cost unfortunately Link to comment https://bolterandchainsword.com/topic/338004-forgeworld-thunderer-question/#findComment-4854314 Share on other sites More sharing options...
CoffeeGrunt Posted August 14, 2017 Share Posted August 14, 2017 It doesn't help that the Demolisher feels pretty lacklustre this edition as well. Link to comment https://bolterandchainsword.com/topic/338004-forgeworld-thunderer-question/#findComment-4856280 Share on other sites More sharing options...
shandwen Posted August 14, 2017 Share Posted August 14, 2017 FW has a track record for being off a lot... Hopefully it will get fixed. Eventually. Halfpint100 1 Back to top Link to comment https://bolterandchainsword.com/topic/338004-forgeworld-thunderer-question/#findComment-4856284 Share on other sites More sharing options...
Withershadow Posted August 16, 2017 Share Posted August 16, 2017 It doesn't help that the Demolisher feels pretty lacklustre this edition as well.Demolisher is actually one of the better guns, it's the Leman Russ that is underwhelming. Link to comment https://bolterandchainsword.com/topic/338004-forgeworld-thunderer-question/#findComment-4858474 Share on other sites More sharing options...
Brendaen Posted August 19, 2017 Author Share Posted August 19, 2017 FYI: I just got an email from FW. I had asked about the points cost. They replied that the cost of the Thunderer DOES include the Demolisher Cannon and it will be fixed in the upcoming FAQ. Going to save the email until that happens. Halfpint100, narcolepticltd and duz_ 3 Back to top Link to comment https://bolterandchainsword.com/topic/338004-forgeworld-thunderer-question/#findComment-4862225 Share on other sites More sharing options...
Withershadow Posted August 19, 2017 Share Posted August 19, 2017 I figured that maybe the case, still not sure if it's a good purchase for the cost. I have 3 Dracosans I intended to run as Thunderers, but maybe I'll make a makeshift battle cannon/coax gun for them to run as Conquerors. Thank the Emperor for magnets. Link to comment https://bolterandchainsword.com/topic/338004-forgeworld-thunderer-question/#findComment-4862432 Share on other sites More sharing options...
Chaplain Gunzhard Posted August 19, 2017 Share Posted August 19, 2017 I figured that maybe the case, still not sure if it's a good purchase for the cost. I have 3 Dracosans I intended to run as Thunderers, but maybe I'll make a makeshift battle cannon/coax gun for them to run as Conquerors. Thank the Emperor for magnets. Victoria miniatures now has an excellent Conqueror turrets, I will put some pictures of mine up later. Withershadow 1 Back to top Link to comment https://bolterandchainsword.com/topic/338004-forgeworld-thunderer-question/#findComment-4862450 Share on other sites More sharing options...
Withershadow Posted August 19, 2017 Share Posted August 19, 2017 Looking forward to seeing them completed. My search fu is failing me, got a link? Link to comment https://bolterandchainsword.com/topic/338004-forgeworld-thunderer-question/#findComment-4862511 Share on other sites More sharing options...
Chaplain Gunzhard Posted August 19, 2017 Share Posted August 19, 2017 (edited) Here are mine unpainted, though I'm almost finished with them: Here's the link: https://victoriaminiatures.com/collections/artillery/products/matilda-boss-battle-tank Edited August 20, 2017 by Chaplain Gunzhard Link to comment https://bolterandchainsword.com/topic/338004-forgeworld-thunderer-question/#findComment-4862535 Share on other sites More sharing options...
Withershadow Posted August 20, 2017 Share Posted August 20, 2017 Very nice, shame they don't sell them individually. I'd have to drop $45 on three turrets, and toss the rest. Link to comment https://bolterandchainsword.com/topic/338004-forgeworld-thunderer-question/#findComment-4862550 Share on other sites More sharing options...
Solar_Pattern Posted August 21, 2017 Share Posted August 21, 2017 Here are mine unpainted, though I'm almost finished with them: Here's the link: https://victoriaminiatures.com/collections/artillery/products/matilda-boss-battle-tank How much effort did you have to put into getting the mantlet to fit inside the turret? It's the only think putting me off ordering from across the sea. Link to comment https://bolterandchainsword.com/topic/338004-forgeworld-thunderer-question/#findComment-4864292 Share on other sites More sharing options...
Chaplain Gunzhard Posted August 21, 2017 Share Posted August 21, 2017 (edited) Here are mine unpainted, though I'm almost finished with them: Here's the link: https://victoriaminiatures.com/collections/artillery/products/matilda-boss-battle-tank How much effort did you have to put into getting the mantlet to fit inside the turret? It's the only think putting me off ordering from across the sea. So minimal... I just used a saw, like you would for clearing big chunks of flash off a forgeworld model, and cut a bit off the back. I put it next to my FW turret to draw the line. It was incredibly easy. For the holes for the magnets I just measured 3mm up from the bottom and did the same on the turret, made a guide hole and started drilling. Note - you don't need to do anything to them and they fit inside the FW turret, but they look better with a little cut off the back. My saw is something like this: I'm pretty sure she designed them with FW / GW parts in mind for conversions... Edited August 21, 2017 by Chaplain Gunzhard Link to comment https://bolterandchainsword.com/topic/338004-forgeworld-thunderer-question/#findComment-4864300 Share on other sites More sharing options...
Chaplain Gunzhard Posted August 21, 2017 Share Posted August 21, 2017 I only have the FW turret so I don't know if the GW plastic version is the same size. Link to comment https://bolterandchainsword.com/topic/338004-forgeworld-thunderer-question/#findComment-4864314 Share on other sites More sharing options...
Solar_Pattern Posted August 22, 2017 Share Posted August 22, 2017 Here are mine unpainted, though I'm almost finished with them: Here's the link: https://victoriaminiatures.com/collections/artillery/products/matilda-boss-battle-tank How much effort did you have to put into getting the mantlet to fit inside the turret? It's the only think putting me off ordering from across the sea. So minimal... I just used a saw, like you would for clearing big chunks of flash off a forgeworld model, and cut a bit off the back. I put it next to my FW turret to draw the line. It was incredibly easy. For the holes for the magnets I just measured 3mm up from the bottom and did the same on the turret, made a guide hole and started drilling. Note - you don't need to do anything to them and they fit inside the FW turret, but they look better with a little cut off the back. My saw is something like this: I'm pretty sure she designed them with FW / GW parts in mind for conversions... Sounds nice and simple, just the way a lazy sod like me likes it. Definitely going to have to consider it. Then again though I saw this on shapeways as a Proxy Conqueror Turret: https://www.shapeways.com/product/M2VD3MSW9/28mm-invader-tank-turret?li=shareProduct duz_ 1 Back to top Link to comment https://bolterandchainsword.com/topic/338004-forgeworld-thunderer-question/#findComment-4865225 Share on other sites More sharing options...
