XstaSea Posted August 16, 2017 Share Posted August 16, 2017 I see a lot of tactics discussion about using transports to get strike squads into the action. I was just wondering, if you had a storm raven or a razorback that is filled with strikes, can you move the transport, then disembark the strikes in the same turn. Or do you have to disembark them at the start of the movement phase, so you move the razorback in the first turn and shoot with that, then in your next turn you disembark the strikes and shoot/charge with them? If you do disembark, does that count as the squad having used up their movement or can you move/advance them as soon as they come out? Link to comment https://bolterandchainsword.com/topic/338235-a-question-about-transports/ Share on other sites More sharing options...
Brother Captain Sirus Posted August 16, 2017 Share Posted August 16, 2017 You must disembark at the start wholly within 3" of the vehicle, the unit can then move normally that turn, but will always class as moving in the case of firing heavy weapons Adeptus 1 Back to top Link to comment https://bolterandchainsword.com/topic/338235-a-question-about-transports/#findComment-4859710 Share on other sites More sharing options...
