Kilamandaros Posted August 23, 2017 Share Posted August 23, 2017 Hi all, recently added a Stormraven to my army, mainly with the objective of deploying Helbrecht, a Castellan with relic helm, 2 assorted Crusader 5 man squads and a Relic Leviathan Dreadnought with double grav bombard deep behind enemy lines - however I've just hit upon a big flaw in my plan being that you need to deploy max 3 inches away from the transport unit or its base in the case of a Stormraven - Leviathans however are mounted on 80mm bases to accommodate their huge backsides, unfortunately about 4mm larger than 3 inches, so am I correct in believing if I attempted to disembark from the Stormraven it will immediately be destroyed for failing to deploy within 3? May have to try and squeeze him onto a 60mm... Link to comment https://bolterandchainsword.com/topic/338548-deploying-dreadnoughts-from-stormravens/ Share on other sites More sharing options...
Atia Posted August 23, 2017 Share Posted August 23, 2017 I don't think you can transport a Leviathan using a Stormraven, tbh ^^ Link to comment https://bolterandchainsword.com/topic/338548-deploying-dreadnoughts-from-stormravens/#findComment-4866001 Share on other sites More sharing options...
Dosjetka Posted August 23, 2017 Share Posted August 23, 2017 It has both the <CHAPTER> and <DREADNOUGHT> keywords on its datasheet so theoretically it works. However if the base is too big to be wholly deployed within 3 inches of it, it can't be deployed. And putting it on a smaller base is generally frowned upon and probably not allowed in most tournaments. Link to comment https://bolterandchainsword.com/topic/338548-deploying-dreadnoughts-from-stormravens/#findComment-4866007 Share on other sites More sharing options...
Gulltramarine Posted August 23, 2017 Share Posted August 23, 2017 Mightn't be a goer in tournaments, but I imagine most reasonable players wouldn't pull you up on it in general play. Link to comment https://bolterandchainsword.com/topic/338548-deploying-dreadnoughts-from-stormravens/#findComment-4866016 Share on other sites More sharing options...
Shea Posted August 23, 2017 Share Posted August 23, 2017 (edited) So if I read your post correctly you foresee a problem with an 80mm base fitting WITHIN the three inches? If that is correct, the closest side of the base has to be three inches away from the transport not the entire base within the three inches. A Thunderhawk Transporter could never carry any vehicle if it had to disembark within three inches. A visual, top is correct, bottom is (I think) what you're concerned about. http://i249.photobucket.com/albums/gg217/medli1/01_zpsxntxsepl.png Edited August 23, 2017 by Shea Kallas and Honda 2 Back to top Link to comment https://bolterandchainsword.com/topic/338548-deploying-dreadnoughts-from-stormravens/#findComment-4866026 Share on other sites More sharing options...
Ciler Posted August 23, 2017 Share Posted August 23, 2017 The rulebook says you must disembark [within 3"] : When a unit disembarks, set it up on the battlefield so that all ofits models are within 3" of the transport and not within 1" of anyenemy models – any disembarking model that cannot be set up inthis way is slain. The FaQ to the rulebok further clarifies : Q: Can you clarify what the difference is between ‘wholly within’and ‘within’ for rules purposes?A: If a rule says it affects units/models that are ‘whollywithin’ then it only applies if the entire unit/model iswithin. If it just says ‘within’, however, then it applies solong as any part of the unit/model is within.For example, units gain the benefit of cover if everymodel in the unit is either on or within terrain. So longas all the models in that unit are either on or partiallywithin the terrain, they gain the benefit of cover. Your leviathan is therefore fine as long as part of it's base is within 3". Othniel's Blade, Cognative, Dosjetka and 3 others 6 Back to top Link to comment https://bolterandchainsword.com/topic/338548-deploying-dreadnoughts-from-stormravens/#findComment-4866142 Share on other sites More sharing options...
Dosjetka Posted August 23, 2017 Share Posted August 23, 2017 My bad for thinking the base had to be wholly within the 3" bubble. Thanks for clearing that up. :tu: Link to comment https://bolterandchainsword.com/topic/338548-deploying-dreadnoughts-from-stormravens/#findComment-4866211 Share on other sites More sharing options...
Kilamandaros Posted August 23, 2017 Author Share Posted August 23, 2017 I don't think you can transport a Leviathan using a Stormraven, tbh ^^ Nope, any Dreadnought except the Primaris Redemptor is fine. ~ Thanks for the clarification chaps - that's very interesting that you only need part of the base within 3" - I've been playing this wrong with my infantry as well which can technically gain another inch (marines on big bases) I assumed they needed to be within the 3" limit. Honda and Brother Talarian 2 Back to top Link to comment https://bolterandchainsword.com/topic/338548-deploying-dreadnoughts-from-stormravens/#findComment-4866274 Share on other sites More sharing options...
SydonianDragoon404 Posted August 24, 2017 Share Posted August 24, 2017 I actually just did this recently! I dropped a Leviathan Dreadnought out of my Storm Raven and my opponent hilariously replied "Oh my god that flier just pooped out a giant robot!!" Honda 1 Back to top Link to comment https://bolterandchainsword.com/topic/338548-deploying-dreadnoughts-from-stormravens/#findComment-4866621 Share on other sites More sharing options...
Othniel's Blade Posted August 24, 2017 Share Posted August 24, 2017 Someone's about to post that old pic of a globemaster thanks to you. Link to comment https://bolterandchainsword.com/topic/338548-deploying-dreadnoughts-from-stormravens/#findComment-4867129 Share on other sites More sharing options...
