Feral_80 Posted August 25, 2017 Share Posted August 25, 2017 I've made this two with a combination of plasticard, 40k bitz, and ww2 scale models bitz. I believe they are the correct size (about 23cm diameter). Note they are two slightly different patterns ;) Do they look ok? Anything you an suggest to add or adjust? They should look a bit better once painted. Some comparison with your own version? I was hoping to add a few more bitz, and then magnetize the top to house a Basilik tank deck section, so I can swap and use the same both piece for both platforms and tank artillery depending on the game. I'll update with a few more wip pics of the upper part, as I'll need to integrate the Basiliks decks as well since I do not have complete parts of those. duz_ and Chaplain Gunzhard 2 Back to top Link to comment https://bolterandchainsword.com/topic/338619-my-scratch-built-artillery-platforms-wip/ Share on other sites More sharing options...
duz_ Posted August 25, 2017 Share Posted August 25, 2017 Looking good just needs gun! :D Link to comment https://bolterandchainsword.com/topic/338619-my-scratch-built-artillery-platforms-wip/#findComment-4867903 Share on other sites More sharing options...
wulfgar hammerfist Posted August 25, 2017 Share Posted August 25, 2017 Those look great! Link to comment https://bolterandchainsword.com/topic/338619-my-scratch-built-artillery-platforms-wip/#findComment-4867979 Share on other sites More sharing options...
