Jochteas Posted August 26, 2017 Share Posted August 26, 2017 Does anyone have advice on magnetizing the Primaris Marines? I got the Dark Imperium set and I plan on building a Primaris army, I like to magnetize when ever i can and i know most of the models have options outside of what is given in the box, but I don't know really where to magnetize. Arms? Wrists? Backpack if necessary? Ive tried looking at a normal set sprue but I can't seem to find a good source. Link to comment https://bolterandchainsword.com/topic/338670-help-magnetizing-dark-imperium-primaris/ Share on other sites More sharing options...
Grotsmasha Posted August 26, 2017 Share Posted August 26, 2017 Looking at the sprues for both the Intercessor and Helblaster box sets, and comparing them to the actual DI sprues, your best bet for interchangeability is definitely the wrists. You'll want somethink like 1mm round x 2mm deep magnets as these will be small enough diameter to fit in the wrists, and deep enough to provide a strong attraction. Cheers, Jono Jochteas 1 Back to top Link to comment https://bolterandchainsword.com/topic/338670-help-magnetizing-dark-imperium-primaris/#findComment-4868696 Share on other sites More sharing options...
Jochteas Posted August 26, 2017 Author Share Posted August 26, 2017 the place i get magnets usually only does inches, 1/16" x 1/32" 1/8" x 1/16"3/16" x 1/16"1/4" x 1/16" etc,The first one being the smallest, would that be approximate? I Mean if you're absolutely confident only 2x1 mm will do it i'll order them online i don't mind. Also any thoughts on the Interceptors? Link to comment https://bolterandchainsword.com/topic/338670-help-magnetizing-dark-imperium-primaris/#findComment-4868701 Share on other sites More sharing options...
Arkhanist Posted August 26, 2017 Share Posted August 26, 2017 (edited) 1/32" x 1/16" disc is basically the same magnet as a 1mm x 2mm for our purposes - it's the usual marine wrist magnet for americans (technically it's fractionally smaller). The higher the N number, the stronger the magnet - try and get N48 or N52 if you can. You can use larger magnets for shoulders and backpacks. 1/8" x 1/32" is a common one for that. Edited August 26, 2017 by Arkhanist Jochteas 1 Back to top Link to comment https://bolterandchainsword.com/topic/338670-help-magnetizing-dark-imperium-primaris/#findComment-4868795 Share on other sites More sharing options...
Jochteas Posted August 27, 2017 Author Share Posted August 27, 2017 Arkhanist, much appreciated thank you! Link to comment https://bolterandchainsword.com/topic/338670-help-magnetizing-dark-imperium-primaris/#findComment-4869462 Share on other sites More sharing options...
