redshadow Posted August 29, 2017 Share Posted August 29, 2017 so would anyone be upset if i turned up with a glottkin and used it as an renagade knight ? (paladin) there about the same size, the rule fit the model with the wounds, its armour saves can be put under its bloatedness as discusting resiliance. even tho i like the idea of converting a knight the glottkin already looks awesome and the part, it also fits the theame of all the new nurgle releases. Honda 1 Back to top Link to comment https://bolterandchainsword.com/topic/338824-glottkin/ Share on other sites More sharing options...
Commissar K. Posted August 29, 2017 Share Posted August 29, 2017 Hmm if youd add more mechanical bits I wouldnt mind, otherwise its more akin to a Greater Daemon... Link to comment https://bolterandchainsword.com/topic/338824-glottkin/#findComment-4871813 Share on other sites More sharing options...
Honda Posted August 29, 2017 Share Posted August 29, 2017 I would enhance it with some mechanical bits, then you could play it as either a GD or a knight. I thought about this as well and think that if your group is Ok with the base model, run with it. Link to comment https://bolterandchainsword.com/topic/338824-glottkin/#findComment-4871815 Share on other sites More sharing options...
Sawtooth Posted August 29, 2017 Share Posted August 29, 2017 How big are the Maggoth Riders compared to the Glotkin? I had considered using one as a greater demon or prince, but I've never physically seen the models. Link to comment https://bolterandchainsword.com/topic/338824-glottkin/#findComment-4871836 Share on other sites More sharing options...
Azekai Posted August 29, 2017 Share Posted August 29, 2017 (edited) Our very own Lagrath seems to have used maggoth parts to make maulerfiends... so it would appear that they are approximately the same size, with the maggoth being a bit taller thanks to back spikes and having a rider. Both fiendish beasties are significantly smaller than the Glottkin. Edited August 29, 2017 by Azekai Link to comment https://bolterandchainsword.com/topic/338824-glottkin/#findComment-4871875 Share on other sites More sharing options...
Sception Posted August 29, 2017 Share Posted August 29, 2017 Glotkin without conversiob makes a great greater daemon of nurgle. To run as a knight, you'd really need to convert it to show the knight's weaponry, at the very least. Link to comment https://bolterandchainsword.com/topic/338824-glottkin/#findComment-4871917 Share on other sites More sharing options...
Khornestar Posted August 30, 2017 Share Posted August 30, 2017 (edited) Eh, I'd be cool with it as long as you had a written list to show me so I could reference its loadout. And the same size base as a knight, that would be ideal. Edited August 30, 2017 by Juggernut Honda 1 Back to top Link to comment https://bolterandchainsword.com/topic/338824-glottkin/#findComment-4872058 Share on other sites More sharing options...
Dallas Drake Posted August 30, 2017 Share Posted August 30, 2017 (edited) My Knight is a Glotkin conversion using both kits. Took about 12 hours to convert. I've since painted it and it looks really good on the table. Edited August 30, 2017 by Dallas Drake Panzer, Commissar K., Goreshed and 10 others 13 Back to top Link to comment https://bolterandchainsword.com/topic/338824-glottkin/#findComment-4872171 Share on other sites More sharing options...
Panzer Posted August 30, 2017 Share Posted August 30, 2017 My Knight is a Glotkin conversion using both kits. <img src='https://i.imgur.com/KjdkALQ.jpg' /> Took about 12 hours to convert. I've since painted it and it looks really good on the table. Yeah that's how I'd recognize it as Knight. Otherwise it looks too much like it could be a Great Unclean one instead. Also you have to use the [ img ] tags if you want to make a picture show. ;) Link to comment https://bolterandchainsword.com/topic/338824-glottkin/#findComment-4872180 Share on other sites More sharing options...
Toomanyprojects Posted August 30, 2017 Share Posted August 30, 2017 I wouldn't mind personally, but remember that rule 1 applies (have fun and let other have fun too) and let them know what it is, and show them the unit's profile if they want to see it. I'd also avoid doing anything thats non-thematic. I.e. there isnt an equivalent of the thermal cannon, so dont have the model playing as a knight equipped with a thermal cannon Honda 1 Back to top Link to comment https://bolterandchainsword.com/topic/338824-glottkin/#findComment-4872193 Share on other sites More sharing options...
Dallas Drake Posted August 30, 2017 Share Posted August 30, 2017 My Knight is a Glotkin conversion using both kits. <img src='https://i.imgur.com/KjdkALQ.jpg' /> Took about 12 hours to convert. I've since painted it and it looks really good on the table. Yeah that's how I'd recognize it as Knight. Otherwise it looks too much like it could be a Great Unclean one instead. Also you have to use the [ img ] tags if you want to make a picture show. I think if you want it as a Knight you need to find a way to use as many Knight parts as possible, I used everything except the legs and copious amounts of green stuff. I won't lie, it's one of the most ambitious conversions I've done and I've done quite a few, the fear comes from the fact you're cutting up 2 very expensive kits. The biggest tip I can give is to dry fit and measure everything several times, also don't fear making a mistake, with green stuff and bits even a balls up can be fixed. I was in a rush leaving the house so couldn't be bothered linking it properly, all fixed nice now Plaguecaster 1 Back to top Link to comment https://bolterandchainsword.com/topic/338824-glottkin/#findComment-4872201 Share on other sites More sharing options...
Panzer Posted August 30, 2017 Share Posted August 30, 2017 Luckily applying greenstuff is very forgiving with the way Nurgle things look. :D Dallas Drake 1 Back to top Link to comment https://bolterandchainsword.com/topic/338824-glottkin/#findComment-4872207 Share on other sites More sharing options...
Plaguecaster Posted August 30, 2017 Share Posted August 30, 2017 (edited) Well to be fair if you were wanting to use another systems units as something it looks nothing like normally then you should at least put some effort into converting it to represent , just look at Dallas Drakes' gorgeous model yes it uses the glotkon as a base but there will be no confusion what it is meant to be compared to just slapping an unconverted Glotkin on the table and explaining that it is a knight and has weapons clearly not modelled on it. I mean having it as a count as for a game or two isn't so bad but anymore and you may encounter some issues Edited August 30, 2017 by Plaguecaster Dallas Drake 1 Back to top Link to comment https://bolterandchainsword.com/topic/338824-glottkin/#findComment-4872216 Share on other sites More sharing options...
Goreshed Posted August 30, 2017 Share Posted August 30, 2017 Dallas that is beautiful and exactly what I had in mind when I do up my own knight. Care to share more pics with the class?? Link to comment https://bolterandchainsword.com/topic/338824-glottkin/#findComment-4872298 Share on other sites More sharing options...
Arkangilos Posted August 30, 2017 Share Posted August 30, 2017 My Knight is a Glotkin conversion using both kits. Took about 12 hours to convert. I've since painted it and it looks really good on the table. Do you have a link for that? Link to comment https://bolterandchainsword.com/topic/338824-glottkin/#findComment-4872446 Share on other sites More sharing options...
Khar'vros the Crazed Posted August 30, 2017 Share Posted August 30, 2017 Unless they come out with a new guo, I plan to convert a glotkin myself. I def think it needs mechanical parts for a knight. Commissar K. 1 Back to top Link to comment https://bolterandchainsword.com/topic/338824-glottkin/#findComment-4872456 Share on other sites More sharing options...
Dallas Drake Posted August 30, 2017 Share Posted August 30, 2017 Dallas that is beautiful and exactly what I had in mind when I do up my own knight. Care to share more pics with the class?? Here you go. Like I said, it's a doable conversion. The hard part is attaching the Knight 'torso' to the Glotkin legs, I also attached the Glotkin back to the Knight torso, I ordered about 5 feet of green stuff off ebay but also use a lot of bluetac to fill in gaps as when you build it you need to bulk out the space in order to get it to glue then green stuff. The advantage of using the Knight torso is that you can then have the weapon fitting, which I magnetised, and the pouldrons and caraoace to get that 'Knight' look. I was all set to run mine as a Nurgle Renegade Knight but *snip* they went the way of the dodo unfortunately I would post new pics of it painted up in Black Legion colours but I'm converting Obliterators and painting Brims & Blue Horrors so my work space is a bit of a mess. I will get around to it at some point, promise... http://i.imgur.com/RCx6Hyp.jpg http://i.imgur.com/rprwpms.jpg http://i.imgur.com/bBww2XD.jpg http://i.imgur.com/RCx6Hyp.jpg Panzer 1 Back to top Link to comment https://bolterandchainsword.com/topic/338824-glottkin/#findComment-4872846 Share on other sites More sharing options...
Goreshed Posted August 30, 2017 Share Posted August 30, 2017 Love the use of the forgefiend gun. Well done! Link to comment https://bolterandchainsword.com/topic/338824-glottkin/#findComment-4872888 Share on other sites More sharing options...
El_Dicko Posted August 31, 2017 Share Posted August 31, 2017 Digging that change of the jaw into a "hat"! I ordered the glotkin head from a bits seller and am spicing it into a maggoth to build a GUO. Link to comment https://bolterandchainsword.com/topic/338824-glottkin/#findComment-4872968 Share on other sites More sharing options...
Sception Posted August 31, 2017 Share Posted August 31, 2017 The forgefiend hades cannons do look fantastic on knights. If you're looking for that topshell piece to convert your glotkin into a more knight-looking knight, try to find someone with the FW chaos knight model. The forgeworld bits replace that top shell, so they may still have the parts to spare. Link to comment https://bolterandchainsword.com/topic/338824-glottkin/#findComment-4873033 Share on other sites More sharing options...
CaptainBoxman Posted August 31, 2017 Share Posted August 31, 2017 Ok, so I've been planning to convert my Glottkin into a Knight just for fun for a while and I finally got some Knight armour and the Reaper chainsword I don't however have any access to the guns and no one will bloody sell me any (someone scammed me too!), so I was wondering whether you reckoned I could just use the right hand with the open maw as the gun and chalk/fluff it up as warp nonsense rather than having to model something I can't seem to get hold of Link to comment https://bolterandchainsword.com/topic/338824-glottkin/#findComment-4873785 Share on other sites More sharing options...
Panzer Posted August 31, 2017 Share Posted August 31, 2017 Ok, so I've been planning to convert my Glottkin into a Knight just for fun for a while and I finally got some Knight armour and the Reaper chainsword I don't however have any access to the guns and no one will bloody sell me any (someone scammed me too!), so I was wondering whether you reckoned I could just use the right hand with the open maw as the gun and chalk/fluff it up as warp nonsense rather than having to model something I can't seem to get hold of Well it depends on how fixated your usual group is on WYSIWYG. Link to comment https://bolterandchainsword.com/topic/338824-glottkin/#findComment-4873796 Share on other sites More sharing options...
bozo69pd Posted September 3, 2017 Share Posted September 3, 2017 Personally I think the cannon arm Glottkin comes with looks fine as a rapid fire battle cannon (phlegm bombs just like soul grinder). The tentacle is a little tricky to call a reaper chainsword so I just call that a fist (that tentacle could totally HURL an enemy). I glued a Cultist with heavy stubber on the base, then cut and magnetized the different carapace weapons for his back. I was also contemplating converting Glottkin into a Leviathan because they are of similar height, but then I decided I wanted to do that with the new primaris Dread. Sheesh Mode 1 Back to top Link to comment https://bolterandchainsword.com/topic/338824-glottkin/#findComment-4875695 Share on other sites More sharing options...
