Helvner Posted August 30, 2017 Share Posted August 30, 2017 Im looking to magnetize the organ part of the exorcist in a way so that, you can remove the organ and be able to run the model as a immolator/rhino.I am having a hard time finding a good spot where the bottom u plate of the organ attaches to put magnets that would still look good when the organ is off. Anyone have any suggestions? Link to comment https://bolterandchainsword.com/topic/338856-exorcist-magnetizing/ Share on other sites More sharing options...
Ficinus Posted August 30, 2017 Share Posted August 30, 2017 Would the connection be strong enough if you put the magnets on the inside the hull rather than on the outside? Link to comment https://bolterandchainsword.com/topic/338856-exorcist-magnetizing/#findComment-4872469 Share on other sites More sharing options...
Eddie Orlock Posted August 30, 2017 Share Posted August 30, 2017 Anyone have any suggestions?Fabricate a decorative plug/cap to cover the joins? My preferred answer would be to just trawl e-bay for a spare tank hull to dedicate as your exorcist chassis, but if you're tight on budget I can see why you might not. Seriously though, there's probably a deal out there on one that wouldn't be too, too, hard to refurbish for your needs. Link to comment https://bolterandchainsword.com/topic/338856-exorcist-magnetizing/#findComment-4872638 Share on other sites More sharing options...
CaptainHelion Posted August 31, 2017 Share Posted August 31, 2017 I've found that the organ tends to stay put fairly well without glue or magnets as it is. If you find your Exorcist is like that, then you can just hot-swap our the Rhino/Immolator hatches. Link to comment https://bolterandchainsword.com/topic/338856-exorcist-magnetizing/#findComment-4873086 Share on other sites More sharing options...
Helvner Posted August 31, 2017 Author Share Posted August 31, 2017 i finally was a suitable location for the magnets the do not interfere with the seam lines of the organ's bottom platehttp://i.imgur.com/0b2CCpG.jpg http://i.imgur.com/SbkmqTz.jpg http://i.imgur.com/oBARSC0.jpg Beams, CaptainHelion and robofish7591 3 Back to top Link to comment https://bolterandchainsword.com/topic/338856-exorcist-magnetizing/#findComment-4873367 Share on other sites More sharing options...
