General Strike Posted August 31, 2017 Share Posted August 31, 2017 Does anyone know the size difference between the mk 3 BOP marines and the new plague marines? It seems like a big one since plague marines almost match Rubrics with crests. Link to comment https://bolterandchainsword.com/topic/338904-size-comparison-between-mk-iii-and-plague-marines/ Share on other sites More sharing options...
HellHunter Posted August 31, 2017 Share Posted August 31, 2017 Not much of a size difference overall. Plague Marines are a little bulked out is all. Hope this helps. Link to comment https://bolterandchainsword.com/topic/338904-size-comparison-between-mk-iii-and-plague-marines/#findComment-4873974 Share on other sites More sharing options...
General Strike Posted September 1, 2017 Author Share Posted September 1, 2017 That helps a lot, I was planning to run some Mk3 as plague marines, but I'm slowly coming around to the actual plague marines. Thank you though! Link to comment https://bolterandchainsword.com/topic/338904-size-comparison-between-mk-iii-and-plague-marines/#findComment-4874041 Share on other sites More sharing options...
Master Commander Ajax Posted September 1, 2017 Share Posted September 1, 2017 I've seen some Head swaps done with the Death Guard models and the plastic Mk III helmets and looked at a glance to be 100% compatible. They deliberately designed the Scarab Occult Terminators from the Thousand Sons release to be compatible (at least partially) with the Plastic Tartaros Terminators as well which would suggest to e that they are of a very similar if not identical scale. Hope this helps! Link to comment https://bolterandchainsword.com/topic/338904-size-comparison-between-mk-iii-and-plague-marines/#findComment-4874088 Share on other sites More sharing options...
Major_Gilbear Posted September 21, 2017 Share Posted September 21, 2017 I saw a better comparison recently, posted on another forum by Mad Doc Morris: http://www.lead-adventure.de/gallery/29/1034_17_08_17_10_30_27.jpg Whilst they are close enough to swap some bits between, the new figures are more distinctly "Primaris-sized" than the mk3 models are. With similar colours, some creative modelling, and a bit of basing assistance, I think you could get still get them close enough to disguise the size differences. General Strike and betrayer41 2 Back to top Link to comment https://bolterandchainsword.com/topic/338904-size-comparison-between-mk-iii-and-plague-marines/#findComment-4892025 Share on other sites More sharing options...
General Strike Posted September 21, 2017 Author Share Posted September 21, 2017 I could boost their height with basing and call it good. Thank you, thats a perfect picture. Link to comment https://bolterandchainsword.com/topic/338904-size-comparison-between-mk-iii-and-plague-marines/#findComment-4892312 Share on other sites More sharing options...
betrayer41 Posted September 21, 2017 Share Posted September 21, 2017 I saw a better comparison recently, posted on another forum by Mad Doc Morris: http://www.lead-adventure.de/gallery/29/1034_17_08_17_10_30_27.jpg Whilst they are close enough to swap some bits between, the new figures are more distinctly "Primaris-sized" than the mk3 models are. With similar colours, some creative modelling, and a bit of basing assistance, I think you could get still get them close enough to disguise the size differences. Are those plague marines from Dark Imperium or seperate Link to comment https://bolterandchainsword.com/topic/338904-size-comparison-between-mk-iii-and-plague-marines/#findComment-4892324 Share on other sites More sharing options...
Arkhanist Posted September 21, 2017 Share Posted September 21, 2017 The one at the front and one to the right are from the 3-man 'easy to build' set. Link to comment https://bolterandchainsword.com/topic/338904-size-comparison-between-mk-iii-and-plague-marines/#findComment-4892329 Share on other sites More sharing options...
Major_Gilbear Posted September 21, 2017 Share Posted September 21, 2017 I think they may be from First Strike, but as I mentioned in my post, they aren't mine. Link to comment https://bolterandchainsword.com/topic/338904-size-comparison-between-mk-iii-and-plague-marines/#findComment-4892352 Share on other sites More sharing options...
Bloody Legionnaire Posted September 25, 2017 Share Posted September 25, 2017 I think they may be from First Strike, but as I mentioned in my post, they aren't mine. They are definitely from the 3 man easy to build set. I wonder if they are the wrong size though.. I just got my Dark Brethren box of Plague Marine and I could sear they aren't that much bigger than the MkIII marines. Unfortunately I don't have the access to them to compare. Link to comment https://bolterandchainsword.com/topic/338904-size-comparison-between-mk-iii-and-plague-marines/#findComment-4895205 Share on other sites More sharing options...
