Syrakul Posted September 4, 2017 Share Posted September 4, 2017 I'm converting a Rhino Chassis into a Deimos-Inspired Predator for my 30k-40k SoH/Black legion. some pics so far: I've got the sides magnetized, will do same for top, so that I can go Rhino/Predator, and Autocannon/2LC/Others, and HB/Lascannons For the turret, I used a Gacha capsule as a mould for Tamiya puddy (cheap greenstuff equivalent) and it comes out to the same approx. Though Im only working with HH art pics and photos, never seen a real Deimos in the flesh. I'm thinking of properly rebuilding the circular shields around the sponson weapons, to better mimic the Deimos. Just have to bend some plasticard. Markus_ and Azekai 2 Back to top Link to comment Share on other sites More sharing options...
Jolemai Posted September 4, 2017 Share Posted September 4, 2017 Looks good so far Is it a time consuming process? Link to comment Share on other sites More sharing options...
Syrakul Posted September 4, 2017 Author Share Posted September 4, 2017 (edited) I started this way back making the sides and top then got disillusioned making the turret. just returned a few days ago. Here are some pics on the sponsons. The circular part the guns are on are also magnetized so they can turn and be taken off. I didnt plan to run a predator without sponsons weapons, so in that case I'll just remove the sides and put Rhino doors on as usual, Like the Rhino option. The top will be removeable and I can just magnetically swap it and the sponsons for the usual rhino doors to run as a Rhino. Edited September 7, 2017 by Syrakul Marqol and Azekai 2 Back to top Link to comment Share on other sites More sharing options...
Syrakul Posted September 7, 2017 Author Share Posted September 7, 2017 (edited) I filled out the space under the turret hatch with this plumbers pipe clay. smells like tuna, 2 part like GS and dries in an hour to a rock like (but sandable and sliceable) hard GS.The turret lascannons were a bit of a botch job, I have added a spacer under the weapon to give more clearance to weapons, but i cant rotate over the oversized grating on the rear. I suspect the real Deimos cant either, anyways.I will make an Autocannon version in the future with plastic pipe.To do still:Orange: change sponson guards to resemble correct ones using bent plasticardRed: find or make small shielded cameras for gun targetters.Purple: bore a hole and place a pipe with some circle valve bit in the hole, then shave down flush with sphere.Blue: build a back compartment for the turret. Most likely using the half-circle predator compartment and some other boxes, like IG lascannon team batteries, or fabricated with GS and PC.Green: build small sensor boxes on both sides.I will use the smaller razorback dozerblade, with a rack of skulls for the front. Edited September 7, 2017 by Syrakul Link to comment Share on other sites More sharing options...
Syrakul Posted September 15, 2017 Author Share Posted September 15, 2017 (edited) Bit of work. Did the little circle bit, using some plastic pipe and vox grill from IG radio backpack, then just carve the pipe flush with sphere. Im using magnets to keep on the turret and the turret platform. Its nice that magnets are hidden for the turret rotaion, popping it off or rotating is hasslefree!Project is waiting on progress of my new Spartan! Going to use the Spartan sponson shields and targetters to GS mould parts for this pred.Then Ill need to add boxes at back of turret, Some SoH brass etch and should be good! Edited September 15, 2017 by Syrakul Link to comment Share on other sites More sharing options...
Bjorn Firewalker Posted September 15, 2017 Share Posted September 15, 2017 The custom turret looks promising. I applaud your modeling skills. Link to comment Share on other sites More sharing options...
