CrystalSeer Posted September 5, 2017 Share Posted September 5, 2017 What do ppl do to paint white pads over black undercoat? Currently layering is taking me forever and I'm not happy with the results. Link to comment Share on other sites More sharing options...
Grotsmasha Posted September 5, 2017 Share Posted September 5, 2017 The easiest method is to leave the pads off and prime them in white, then attach them. Cheers, Jono Helias_Tancred and Dumbcow1 2 Back to top Link to comment Share on other sites More sharing options...
Marshal_Roujakis Posted September 5, 2017 Share Posted September 5, 2017 I usually go with Ulthuan Grey, followed by a wash of Nuln Oil into the crevices, then a 2nd layer of Ulthuan Grey followed by a highlight of White Scar (or it's equivalent) these are my results: Link to comment Share on other sites More sharing options...
Castellan Doren Posted September 5, 2017 Share Posted September 5, 2017 Shhh, I use craft paints but the same applies. I use the lightest grey that goes on the smoothest with 2 coats. Then paint white over it. The longer answer is above. Link to comment Share on other sites More sharing options...
Sword Brother Adelard Posted September 5, 2017 Share Posted September 5, 2017 I use Celestra Grey as a base over black undercoat, then thin layers of Ulthuan (watered down), then highlight with White Scar. Link to comment Share on other sites More sharing options...
Ciler Posted September 5, 2017 Share Posted September 5, 2017 Depending on the area of the model, I will either prime white separately or apply coats of ceramite white. In the second case, I find that applying up to 4 coats of thinned down paint is necessary. Also, I advise to wait until the first coat is completely dry before applying the second one and whenever possible apply brush strokes in a different direction. Link to comment Share on other sites More sharing options...
Bukimimaru Posted September 5, 2017 Share Posted September 5, 2017 Ulthuan Grey, Palid Witch Flesh, White Skar. Link to comment Share on other sites More sharing options...
Shea Posted September 5, 2017 Share Posted September 5, 2017 The easiest method is to leave the pads off and prime them in white, then attach them. Cheers, Jono This. Dumbcow1 1 Back to top Link to comment Share on other sites More sharing options...
Zeruvar Posted September 5, 2017 Share Posted September 5, 2017 (edited) I'll have to try the white primer next time, layering watered down white scar paint does take a long time to get an even coverage As always those models look beautiful Marshall Roujakis Edited September 5, 2017 by Zeruvar Link to comment Share on other sites More sharing options...
Ciler Posted September 5, 2017 Share Posted September 5, 2017 You don't want to layer white scar over black basecoat anyway, it's a layer paint and thus purposefully slightly transparent. If anythin, you layer it over ulthuan grey or ceramite white. Firepower 1 Back to top Link to comment Share on other sites More sharing options...
Dumbcow1 Posted September 5, 2017 Share Posted September 5, 2017 The easiest method is to leave the pads off and prime them in white, then attach them. Cheers, Jono I second this. This is how i do it. I line the pads up on a piece of masking tape turned upside down. So the pads stick the adhesive, curl over the ends so you can adhere it to a surface to spray paint. Then i paint what ever color border is needed on it be it red for assault or black for initiates. Then all you have to do is scrape off the shoulders on the arms, and inside the pauldrons to get to naked plastic for gluing. Smarter not harder!!! Link to comment Share on other sites More sharing options...
Gendo Posted September 5, 2017 Share Posted September 5, 2017 I do 2 layers of Dawnstone, 2 of Ulthan/Celestial grey and at least 3 of Model Colour white, Then paint the black trim. I've been priming grey lately which saves me the first two layers. Link to comment Share on other sites More sharing options...
Brother_Gneecapper Posted September 7, 2017 Share Posted September 7, 2017 After painting 20 Dark Imperium Primaris (pre-attached shoulders) marines, I intend to leave shoulders unattached and spray them white/grey. I must have spent like 5-10 hours layering through grey to get to the desired white. It looks pretty good imo, but the amount of effort it took just for the shoulders has me burnt out on painting white anytime soon. I am very much looking forward to the 30+ Sword Brothers I have on deck if for nothing else than black shoulders with red trim. I think I can knock out a whole squad of 10 sword brethren in the amount of time it took me to do 5 shoulders. Link to comment Share on other sites More sharing options...
CrystalSeer Posted September 7, 2017 Author Share Posted September 7, 2017 Thanks everyone for the responses. Progress has been much better. Link to comment Share on other sites More sharing options...
