NatBrannigan Posted September 6, 2017 Share Posted September 6, 2017 So now blast templates have gone I've started using movement trays for my Infantry. I know others do as well and have asked where I got my trays from. Well Element games (elementgames.co.uk) have just released their own trays and they're perfect for Guard. I'll be replacing mine, check out their site if you're interested. I don't work for the company or anything, just something I stumbled across. duz_ 1 Back to top Link to comment https://bolterandchainsword.com/topic/339111-movement-trays/ Share on other sites More sharing options...
olcottr Posted September 6, 2017 Share Posted September 6, 2017 Thanks! I love finding new sources to feed my gaming addiction. Link to comment https://bolterandchainsword.com/topic/339111-movement-trays/#findComment-4878626 Share on other sites More sharing options...
WarriorFish Posted September 6, 2017 Share Posted September 6, 2017 Do you mean these trays Nat? A good idea with the round bases to enable you to move them without taking excessive room :) Link to comment https://bolterandchainsword.com/topic/339111-movement-trays/#findComment-4878629 Share on other sites More sharing options...
Jolemai Posted September 6, 2017 Share Posted September 6, 2017 These? http://elementgames.co.uk/element-essentials/element-movement-trays Interesting idea. Pfft. Ninjas everywhere these days. Silas7 1 Back to top Link to comment https://bolterandchainsword.com/topic/339111-movement-trays/#findComment-4878631 Share on other sites More sharing options...
NatBrannigan Posted September 6, 2017 Author Share Posted September 6, 2017 That'll be them! They look like they give you a nice bit of flexibility while still letting the more anal amongst us have their Infantry in nice, neat firing lines. Even some there for Bullgryns and Rough Riders / DKOK cav. Link to comment https://bolterandchainsword.com/topic/339111-movement-trays/#findComment-4878644 Share on other sites More sharing options...
Halfpint100 Posted September 6, 2017 Share Posted September 6, 2017 I tried using them. But terrain.... and deploying them normally can cover more ground for deep strike denial, etc Link to comment https://bolterandchainsword.com/topic/339111-movement-trays/#findComment-4878675 Share on other sites More sharing options...
NatBrannigan Posted September 6, 2017 Author Share Posted September 6, 2017 But they make sure your Infantry are in straight lines! I think someone needs their priorities sorted! "Denying deep strike"? "Using Terrain"? Honestly... duz_, Silas7, Jolemai and 2 others 5 Back to top Link to comment https://bolterandchainsword.com/topic/339111-movement-trays/#findComment-4878694 Share on other sites More sharing options...
Jolemai Posted September 6, 2017 Share Posted September 6, 2017 But they make sure your Infantry are in straight lines! I think someone needs their priorities sorted! "Denying deep strike"? "Using Terrain"? Honestly... Sounds like something taught by the Mordian Iron Guard... lash144 and Guardsman Bob 2 Back to top Link to comment https://bolterandchainsword.com/topic/339111-movement-trays/#findComment-4878705 Share on other sites More sharing options...
Shamansky Posted September 6, 2017 Share Posted September 6, 2017 Simple construction. Only needs a laser graver to reproduce. And i have one at my disposal. Link to comment https://bolterandchainsword.com/topic/339111-movement-trays/#findComment-4878715 Share on other sites More sharing options...
NatBrannigan Posted September 6, 2017 Author Share Posted September 6, 2017 Praetorian Guard thank you very much! These would be pretty easy to make, especially if you have the gear, but at £12 for 8 i'm happy enough. I might even consider some of the cloud ones for my Conscripts. Link to comment https://bolterandchainsword.com/topic/339111-movement-trays/#findComment-4878740 Share on other sites More sharing options...
Mithrilforge Posted September 8, 2017 Share Posted September 8, 2017 if only they made a single plate of 30 or even 50 ...i bet nid players would love em too ... Mithril Link to comment https://bolterandchainsword.com/topic/339111-movement-trays/#findComment-4880448 Share on other sites More sharing options...
NatBrannigan Posted September 8, 2017 Author Share Posted September 8, 2017 Maybe some kind of movement tray that you could put these movement trays on? Link to comment https://bolterandchainsword.com/topic/339111-movement-trays/#findComment-4880477 Share on other sites More sharing options...
Level9red Posted September 8, 2017 Share Posted September 8, 2017 I like the look of these, I sort of wish they did them in 4s for the new command squads. Has anyone ever found a 10 man one with a space for a heavy weapon team? I haven't so far. Thanks. Link to comment https://bolterandchainsword.com/topic/339111-movement-trays/#findComment-4880486 Share on other sites More sharing options...
Ranulf Posted September 8, 2017 Share Posted September 8, 2017 Thin plywood, drill, 25mm spade bit, small hacksaw and sandpaper will do the trick, custom built to suit the style you're after. I used to use Evergreen Plasticard until it got ridiculously expensive. Link to comment https://bolterandchainsword.com/topic/339111-movement-trays/#findComment-4880633 Share on other sites More sharing options...
