Brother Tual Posted September 8, 2017 Share Posted September 8, 2017 Quick question. Does the main gun benefit from grinding advance rule? Link to comment https://bolterandchainsword.com/topic/339162-leman-russ-conqueror/ Share on other sites More sharing options...
Tirak Posted September 8, 2017 Share Posted September 8, 2017 The rule specifically says "This model does not suffer the penalty to it's Conqueror battle cannon..." So I would say yes. Link to comment https://bolterandchainsword.com/topic/339162-leman-russ-conqueror/#findComment-4880431 Share on other sites More sharing options...
Brother Tual Posted September 8, 2017 Author Share Posted September 8, 2017 Thanks. I was just looking at battlescribe and it only says turret weapons and then had a list of what these are. The conqueror cannon is not listed there. Link to comment https://bolterandchainsword.com/topic/339162-leman-russ-conqueror/#findComment-4880439 Share on other sites More sharing options...
Chaplain Gunzhard Posted September 8, 2017 Share Posted September 8, 2017 I think they forgot to list it, at least on the mars alpha version, and it was later added on the FAQ. But battlescribe is often wrong. Link to comment https://bolterandchainsword.com/topic/339162-leman-russ-conqueror/#findComment-4880520 Share on other sites More sharing options...
Captain_Krash Posted September 8, 2017 Share Posted September 8, 2017 Never use that shoddy program, it's calculated my points wrong often. It's made for laziness Krash Link to comment https://bolterandchainsword.com/topic/339162-leman-russ-conqueror/#findComment-4880605 Share on other sites More sharing options...
CoffeeGrunt Posted September 8, 2017 Share Posted September 8, 2017 That's why I use it. :P Otto von Bludd, Tirak and Kassill 3 Back to top Link to comment https://bolterandchainsword.com/topic/339162-leman-russ-conqueror/#findComment-4880626 Share on other sites More sharing options...
Ulrik_Ironfist Posted September 14, 2017 Share Posted September 14, 2017 This seems the best place to ask, but is the Co-axial storm bolter worth the shortened range and the extra 3 points over the standard Battle Tank? Link to comment https://bolterandchainsword.com/topic/339162-leman-russ-conqueror/#findComment-4886531 Share on other sites More sharing options...
Otto von Bludd Posted September 14, 2017 Share Posted September 14, 2017 Absolutely worth it, the Conqueror is just a flat out better LRBT. You pay almost nothing for the co ax gun which confers twin linked to your Battle Cannon within 24. That makes your Regular old Conqueror Cannon more accurate than a Tank Commander with BS3+ plus you can slap a pintle mounted storm bolter on top of it to get 8 stormbolter shots within 12" turning it into a mini LR Punisher. 48" range is almost always enough to hit anything on the board, so the reduced range isn't really an issue unless you play on very big boards, in which case just take a Basilisk. Chaplain Gunzhard, Guardsman Bob and duz_ 3 Back to top Link to comment https://bolterandchainsword.com/topic/339162-leman-russ-conqueror/#findComment-4886573 Share on other sites More sharing options...
Ulrik_Ironfist Posted September 15, 2017 Share Posted September 15, 2017 Absolutely worth it, the Conqueror is just a flat out better LRBT. You pay almost nothing for the co ax gun which confers twin linked to your Battle Cannon within 24. That makes your Regular old Conqueror Cannon more accurate than a Tank Commander with BS3+ plus you can slap a pintle mounted storm bolter on top of it to get 8 stormbolter shots within 12" turning it into a mini LR Punisher. 48" range is almost always enough to hit anything on the board, so the reduced range isn't really an issue unless you play on very big boards, in which case just take a Basilisk. See, that's kinda what I was thinking. I was going to be running it in addition to a squadron of Demolishers and Pask in a Vanquisher (I know that people say that vanquishers aren't worth it this edition but with Pask's 2+ it almost seems worth it). I play on standard 6x4 boards, so 48" should be fine. I know it doesn't pertain to the Conqueror, but in the same vein, does the Co-Ax Stubber make the Vanquisher any good? duz_ 1 Back to top Link to comment https://bolterandchainsword.com/topic/339162-leman-russ-conqueror/#findComment-4886633 Share on other sites More sharing options...
