Brother Syddraf Posted September 14, 2017 Share Posted September 14, 2017 (edited) Bike painted in Eshin Grey all over, then Dawnstone highlight first then Ulthuan Gray as a point highlight. Has had all over wash with bulb oil. Does it look to grey. Does anyone have any suggestions. Thanks Edited September 14, 2017 by Brother Syddraf Othniel's Blade 1 Back to top Link to comment https://bolterandchainsword.com/topic/339347-advice-on-ravenwing-paint-work/ Share on other sites More sharing options...
Grotsmasha Posted September 14, 2017 Share Posted September 14, 2017 If you want to darken it, you have two options. Firstly, you can hit it over, and over, and over with Nuln Oil until it's dark enough. Secondly, (and my recommendation) is to grab out Black and neatly paint it between the greys on the most prominent panels. Cheers, Jono Brother Syddraf 1 Back to top Link to comment https://bolterandchainsword.com/topic/339347-advice-on-ravenwing-paint-work/#findComment-4885687 Share on other sites More sharing options...
dtse Posted September 14, 2017 Share Posted September 14, 2017 Yea too grey. Ravens are black. Link to comment https://bolterandchainsword.com/topic/339347-advice-on-ravenwing-paint-work/#findComment-4886583 Share on other sites More sharing options...
Brother Syddraf Posted September 14, 2017 Author Share Posted September 14, 2017 Going to do a thinned out eshin grey next time as a thick edge highlight to see the difference. Also does anyone have a tyre painting scheme. Was thinking Brown's edges over the black and a brown wash. Not doing weathering. Just need a colour difference between the armour and rubber Link to comment https://bolterandchainsword.com/topic/339347-advice-on-ravenwing-paint-work/#findComment-4886600 Share on other sites More sharing options...
sneakybamsen Posted September 15, 2017 Share Posted September 15, 2017 Yea too grey. Ravens are black. Have to agree with dtse here. Not that my bikes are pretty (none of my work is, really), but a solid black is just more true to the Ravenwing. I personally find tyres to be something I do not spend time on painting, as highlights on them will easily come to look quite "unnatural". I also feel they should be black, as that's what tyres normally are coloured, and I don't like weathering. Painting bikes is timeconsuming enough as is, so I try to not make it worse. Regards Sneaky Link to comment https://bolterandchainsword.com/topic/339347-advice-on-ravenwing-paint-work/#findComment-4886766 Share on other sites More sharing options...
JJD Posted September 15, 2017 Share Posted September 15, 2017 I have tried several ways of painting black but this is the method I am happiest with. http://taleofpainters.blogspot.co.uk/2015/05/tutorial-how-to-paint-dark-angel.html I still haven't found a way to paint white that I like. Brother Syddraf 1 Back to top Link to comment https://bolterandchainsword.com/topic/339347-advice-on-ravenwing-paint-work/#findComment-4886902 Share on other sites More sharing options...
Abachrael Posted September 15, 2017 Share Posted September 15, 2017 I find that too grey for my taste.What I do is Abbadon black, Eshin grey for first highlighting, and Dawnstone for the final touch. It's simple, it's quick, it looks very good, and more specially, it's a scheme that goes VERY well with vehicles (Speeders, Vengeances/Shrouds, Talons/Nephs, etc).And it goes very well with the traditional Ravenwing heraldry.I use the same scheme for all my Ravenwing units and, as usual, having a recognizable and constant theme over a big force makes it look VERY GOOD.I'm not a very good painter, so you take a close look at one of my bikes, and it's "meh" at best for the better painters out there. But you see them all together on their shelves, and they ROCK. Link to comment https://bolterandchainsword.com/topic/339347-advice-on-ravenwing-paint-work/#findComment-4886916 Share on other sites More sharing options...
dtse Posted September 15, 2017 Share Posted September 15, 2017 Yea it's crazy how time consuming painting bikes is. Especially detailed ones lokeblack knights. Painting 15 black knights was fricking killer Link to comment https://bolterandchainsword.com/topic/339347-advice-on-ravenwing-paint-work/#findComment-4886948 Share on other sites More sharing options...
Chaplain Raeven Posted September 15, 2017 Share Posted September 15, 2017 Eshin Grey as a base is a bit too grey for Ravenwing. I usually use that as highlight, pared with Fenrisian grey. I painted my tires Dawnstone and washed the heck out of it with Nuln Oil Link to comment https://bolterandchainsword.com/topic/339347-advice-on-ravenwing-paint-work/#findComment-4886995 Share on other sites More sharing options...
Ania Redfang Posted September 18, 2017 Share Posted September 18, 2017 (edited) I paint black like this: Abaddon Black over black undercoat. Drybrush Stegadon Scale Green Drybrush Thunderhawk Blue Drybrush Fenrisian Grey Wash Nuln Oil Edge highlight fenrisian grey. I use this for Deathwatch mostly but I think it would look good on any black armour. Edited September 18, 2017 by The Call of the Hunt Hellrender, Interrogator Stobz and Syphid 3 Back to top Link to comment https://bolterandchainsword.com/topic/339347-advice-on-ravenwing-paint-work/#findComment-4889055 Share on other sites More sharing options...
Gillyfish Posted September 19, 2017 Share Posted September 19, 2017 Try adding some other colours before deciding whether it's too grey - they will give you a more objective sense of the tone of the model. If it helps, this is what I have done with my bikes. Black undercoat. Drybrush of either charadon granite or adeptus battlegrey Light drybrush of codex grey I then go back and paint chaos black into the centre of the armour panels. It's quick and easy to do and gives thinner highligths than brushing. That said, on the marine, I will paint on highlights rather than drybrush - it helps draw attention to the marine. In terms of tyres - they should be a dark grey/brown. So I generally mix a mid brown colour like the old bestial brown with codex grey and some black to darken it a touch. then take that mix and add more codex grey to paint around the areas where the tyres would catch the light - this helps to give them a curved feel. Weathering can then be added as you like. I'll have to see if I can dig out some of my bikes at some point and provide some pictures. My method speeds up the painting of Ravenwing A LOT! Interrogator Stobz 1 Back to top Link to comment https://bolterandchainsword.com/topic/339347-advice-on-ravenwing-paint-work/#findComment-4889872 Share on other sites More sharing options...
Hertz Posted September 25, 2017 Share Posted September 25, 2017 Yeah, I spent years trying to find the optimal way to paint ravenwing. Just black and some greys its to "boring" of a surface, and with other colours0 it will just look of. I've "recently"-ish gotten an airbrush to experiment with, and are thinking of doing filters of greens and perhaps reds on the blacker parts, to make it more interesting. Very thin layers, so you dont get the colour, only just so it adds depth to it. Well. Next time I get home I'll get to it. Link to comment https://bolterandchainsword.com/topic/339347-advice-on-ravenwing-paint-work/#findComment-4895017 Share on other sites More sharing options...
Master Toddius Posted September 25, 2017 Share Posted September 25, 2017 I've learned a ton from him:https://youtu.be/a7p2us0W-10 Link to comment https://bolterandchainsword.com/topic/339347-advice-on-ravenwing-paint-work/#findComment-4895487 Share on other sites More sharing options...
Syphid Posted September 26, 2017 Share Posted September 26, 2017 I paint black like this: Abaddon Black over black undercoat. Drybrush Stegadon Scale Green Drybrush Thunderhawk Blue Drybrush Fenrisian Grey Wash Nuln Oil Edge highlight fenrisian grey. I'm going to try this! I use this for Deathwatch mostly but I think it would look good on any black armour. Link to comment https://bolterandchainsword.com/topic/339347-advice-on-ravenwing-paint-work/#findComment-4895595 Share on other sites More sharing options...
