Kastor Krieg Posted September 16, 2017 Share Posted September 16, 2017 (edited) I know this is not WYSIWYG for his loadout, but since there are actually two mirror hands with Lantern, all parts complete, I thought it might be cool to have him be a gunslinger, with Silence across his back or somesuch Watch out when assembling (1d), the "roof" part (#25) needs to be glued in BEFORE #26 (the tank), because otherwise the tank will get in the way. There is an image showing how they should horizontally align, but not one indicating the sequence and I've found out that the hard way. Had to cut off a part of the top left lip of the "roof" to squeeze the part into place. That's a piece that would be mostly obscured anyway, but just look out, mates I'm also considering removing the standalone Nurglings from his base, especially the middle one, because it's too busy, even if it's funny. I could use them elsewhere, maybe. It's a very good idea not to glue him to the base and treat them as two separate sub assemblies. Same with wings, really. Edited September 16, 2017 by Kastor Krieg Azekai, Marshal Loss, Lord Marshal and 1 other 4 Back to top Link to comment https://bolterandchainsword.com/topic/339433-mortarion-assembly-woes-sequence-gunslinger-basing/ Share on other sites More sharing options...
Closet Skeleton Posted September 16, 2017 Share Posted September 16, 2017 I tried magnetizing a wing for transportation purposes. One attachment point isn't strong enough and the other point is too small for magnets. I'll try pinning it. Link to comment https://bolterandchainsword.com/topic/339433-mortarion-assembly-woes-sequence-gunslinger-basing/#findComment-4888001 Share on other sites More sharing options...
DeadFingers Posted September 16, 2017 Share Posted September 16, 2017 There's no way to magnetize those wings by themselves, period. But, BUT, if anyone's adventurous, daring, smart and skilled enough, they could try cutting the backpack tanks off the cloak bits, assembling that together with the wings, and magnetizing the whole thing to Mortarion's back. It's risky, but I think it can be pulled off. Link to comment https://bolterandchainsword.com/topic/339433-mortarion-assembly-woes-sequence-gunslinger-basing/#findComment-4888013 Share on other sites More sharing options...
Interrogator-Chaplain Ezra Posted September 16, 2017 Share Posted September 16, 2017 This might offer some insights. Gumo9 and Azekai 2 Back to top Link to comment https://bolterandchainsword.com/topic/339433-mortarion-assembly-woes-sequence-gunslinger-basing/#findComment-4888015 Share on other sites More sharing options...
happyslugger Posted September 16, 2017 Share Posted September 16, 2017 I looked at magnetising mine earlier and thought - no chance. I am not that skilled in model making/painting, so I will just glue the wings on once I have painted them and the model. If I have to transport it (unlikely) it will just have to sit in a box with some bubble wrap. Link to comment https://bolterandchainsword.com/topic/339433-mortarion-assembly-woes-sequence-gunslinger-basing/#findComment-4888079 Share on other sites More sharing options...
Closet Skeleton Posted September 17, 2017 Share Posted September 17, 2017 Mu-hahahaha!!! ...pinning the other connection point worked. Now I just have to try the other wing; probably with just pins. Link to comment https://bolterandchainsword.com/topic/339433-mortarion-assembly-woes-sequence-gunslinger-basing/#findComment-4888526 Share on other sites More sharing options...
Charlo Posted September 18, 2017 Share Posted September 18, 2017 I'm going to replace the wings with some different ones... Hopefully will make them a little easier to mag-lock in place. TOP idea on the Gun slinging... That I might just have to steal?! Link to comment https://bolterandchainsword.com/topic/339433-mortarion-assembly-woes-sequence-gunslinger-basing/#findComment-4889257 Share on other sites More sharing options...
Reyner Posted September 18, 2017 Share Posted September 18, 2017 Why stop at gunslinging Mortarion? Are there two scythes? Link to comment https://bolterandchainsword.com/topic/339433-mortarion-assembly-woes-sequence-gunslinger-basing/#findComment-4889288 Share on other sites More sharing options...
Lagrath Posted September 18, 2017 Share Posted September 18, 2017 I wonder how hard it would be to make him swing the scythe overhand, two handed like some of the old artwork. Link to comment https://bolterandchainsword.com/topic/339433-mortarion-assembly-woes-sequence-gunslinger-basing/#findComment-4889319 Share on other sites More sharing options...
DeadFingers Posted September 18, 2017 Share Posted September 18, 2017 Why stop at gunslinging Mortarion? Are there two scythes? Nope. Two hafts, one blade. You could do it if you get your hands on a second blade, but who'd sell that on its own? Plus I think Morty would look rather... weird, dragging two Silences around. On the other hand, you could try to get your hands on the Verminlord's... sickles? And give Mortarion a Malthael complex. http://cdn.segmentnext.com/wp-content/uploads/2016/03/Diablo-3-Season-6-620x349.jpg Iron Lord 1 Back to top Link to comment https://bolterandchainsword.com/topic/339433-mortarion-assembly-woes-sequence-gunslinger-basing/#findComment-4889323 Share on other sites More sharing options...
Closet Skeleton Posted September 18, 2017 Share Posted September 18, 2017 (edited) I'm going to replace the wings with some different ones... Hopefully will make them a little easier to mag-lock in place. The basic problem is the weight. The pin-magnet combo stops the weight from pulling the wing out of polarity and causing the thing to fall off. Ended up doing both wings the same. The angle was wrong for the two-pin solution. There's actually plenty of room at the large connection point. It would be perfect if it wasn't just too darn heavy for the polarity to stay aligned. It vorks! it vorks! I can basically wave it around and it might as well be glued. Only flaw is aesthetic if you insist on staring at where the pin goes in. Edited September 18, 2017 by Closet Skeleton Azekai and Arkhanist 2 Back to top Link to comment https://bolterandchainsword.com/topic/339433-mortarion-assembly-woes-sequence-gunslinger-basing/#findComment-4889388 Share on other sites More sharing options...
Panzer Posted September 18, 2017 Share Posted September 18, 2017 I can basically wave it around and it might as well be glued. Only flaw is aesthetic if you insist on staring at where the pin goes in. Nothing a little bit of greenstuff couldn't fix. ;) Link to comment https://bolterandchainsword.com/topic/339433-mortarion-assembly-woes-sequence-gunslinger-basing/#findComment-4889402 Share on other sites More sharing options...
Lagrath Posted September 20, 2017 Share Posted September 20, 2017 I wonder how hard it would be to make him swing the scythe overhand, two handed like some of the old artwork. oh my god that was incredibly difficult to brainstorm and execute... http://i.imgur.com/NUPA4Fn.jpg DeadFingers, Gumo9, hopkins and 13 others 16 Back to top Link to comment https://bolterandchainsword.com/topic/339433-mortarion-assembly-woes-sequence-gunslinger-basing/#findComment-4890780 Share on other sites More sharing options...
Arkhanist Posted September 20, 2017 Share Posted September 20, 2017 Looks *awesome* though. Link to comment https://bolterandchainsword.com/topic/339433-mortarion-assembly-woes-sequence-gunslinger-basing/#findComment-4890782 Share on other sites More sharing options...
Panzer Posted September 20, 2017 Share Posted September 20, 2017 Looks neat, but that's really not how you'd use a Scythe. More of an Axe or Sword pose imo. ^^ Link to comment https://bolterandchainsword.com/topic/339433-mortarion-assembly-woes-sequence-gunslinger-basing/#findComment-4890784 Share on other sites More sharing options...
Lagrath Posted September 20, 2017 Share Posted September 20, 2017 I imagine that the swing will either come down in a diagonal curve, or he's about to straight up cut someone in half down the middle. The new codex has fluff about how powerful Silence is, so it makes sense to me. Anyway it's based partly on my favorite old artwork: http://pro.bols.netdna-cdn.com/wp-content/uploads/2016/12/200px-Mortarion_Prince_of_Decay.jpg Azekai and Kisada 2 Back to top Link to comment https://bolterandchainsword.com/topic/339433-mortarion-assembly-woes-sequence-gunslinger-basing/#findComment-4890787 Share on other sites More sharing options...
happyslugger Posted September 20, 2017 Share Posted September 20, 2017 Awesome stuff, I don't have the skill set to even try and alter his model. I went for the Lantern pointing version so it looks like he is about to shoot something. I am however considering cutting off the little flies as they are driving me nuts whilst I try and paint him (something I am also not great at doing, art was never my thing lol). Link to comment https://bolterandchainsword.com/topic/339433-mortarion-assembly-woes-sequence-gunslinger-basing/#findComment-4890789 Share on other sites More sharing options...
Reyner Posted September 20, 2017 Share Posted September 20, 2017 That pose is amazing Lagrath :D I instantly saw the artwork in my mind, nicely done! Link to comment https://bolterandchainsword.com/topic/339433-mortarion-assembly-woes-sequence-gunslinger-basing/#findComment-4890791 Share on other sites More sharing options...
Kastor Krieg Posted September 20, 2017 Author Share Posted September 20, 2017 I've cut the flies away on mine. They will make cool base detail or sth. Or maybe objective markers. No clue yet. Link to comment https://bolterandchainsword.com/topic/339433-mortarion-assembly-woes-sequence-gunslinger-basing/#findComment-4891305 Share on other sites More sharing options...
Lagrath Posted September 22, 2017 Share Posted September 22, 2017 Updated pics on my blog for anyone who is interested in current progress: https://www.facebook.com/hexfleetvirules/posts/740488099477164 Link to comment https://bolterandchainsword.com/topic/339433-mortarion-assembly-woes-sequence-gunslinger-basing/#findComment-4892628 Share on other sites More sharing options...
bozo69pd Posted September 22, 2017 Share Posted September 22, 2017 wow Lagrath I may need to copy yo on that... if I have the skill to do it that is. Link to comment https://bolterandchainsword.com/topic/339433-mortarion-assembly-woes-sequence-gunslinger-basing/#findComment-4892934 Share on other sites More sharing options...
happyslugger Posted September 22, 2017 Share Posted September 22, 2017 I've cut the flies away on mine. They will make cool base detail or sth. Or maybe objective markers. No clue yet. I decided to cut the flies off mine in the end...too much around him. I also left off all the nurglings as these will go onto my tanks (as I want my tanks to look like they have been taken over by Nurglings). Link to comment https://bolterandchainsword.com/topic/339433-mortarion-assembly-woes-sequence-gunslinger-basing/#findComment-4892994 Share on other sites More sharing options...
Lagrath Posted September 22, 2017 Share Posted September 22, 2017 wow Lagrath I may need to copy yo on that... if I have the skill to do it that is. Thanks! For the record, every step of this has been incredibly hard, so I don't recommend it unless you are very brave haha. Link to comment https://bolterandchainsword.com/topic/339433-mortarion-assembly-woes-sequence-gunslinger-basing/#findComment-4893014 Share on other sites More sharing options...
Skerr Posted September 23, 2017 Share Posted September 23, 2017 Looks *awesome* though. Perhaps though it looks like he is about to put the finish on someone. Great job!! Link to comment https://bolterandchainsword.com/topic/339433-mortarion-assembly-woes-sequence-gunslinger-basing/#findComment-4893728 Share on other sites More sharing options...
Kastor Krieg Posted September 23, 2017 Author Share Posted September 23, 2017 wow Lagrath I may need to copy yo on that... if I have the skill to do it that is. Thanks! For the record, every step of this has been incredibly hard, so I don't recommend it unless you are very brave haha. Can you explain the steps please? Link to comment https://bolterandchainsword.com/topic/339433-mortarion-assembly-woes-sequence-gunslinger-basing/#findComment-4893730 Share on other sites More sharing options...
