Studio Silvernale Posted September 17, 2017 Share Posted September 17, 2017 How hot of water do I need? I tried pure hot tap water and it doesn't seem to be working. Link to comment https://bolterandchainsword.com/topic/339462-fw-heavy-weapon-cables/ Share on other sites More sharing options...
m0nolith Posted September 17, 2017 Share Posted September 17, 2017 If it's not working, try a hair dryer. Link to comment https://bolterandchainsword.com/topic/339462-fw-heavy-weapon-cables/#findComment-4888310 Share on other sites More sharing options...
Tyberos the Red Wake Posted September 17, 2017 Share Posted September 17, 2017 Hot tap water takes forever and only lets you bend it slightly. It will also slowly curl back in place a little. Just use some boiling water and dip it, bend, and dunk in cold water. Works way better. Boiling water instantly makes it so bendy it almost feels liquid, at least for thin blades. Link to comment https://bolterandchainsword.com/topic/339462-fw-heavy-weapon-cables/#findComment-4888322 Share on other sites More sharing options...
Brother-Chaplain Kage Posted September 17, 2017 Share Posted September 17, 2017 Don't get a full roiling boil though. I wait until there's just a few of the bubbles on the bottom of the pan are floating to the surface. Link to comment https://bolterandchainsword.com/topic/339462-fw-heavy-weapon-cables/#findComment-4888339 Share on other sites More sharing options...
Tyberos the Red Wake Posted September 17, 2017 Share Posted September 17, 2017 Yeah, I guess I should have stated as much. Common sense tells you to never mess around with putting hands near and inserting things into roiling water. I boil the water fully then just pour it into a bowl and let it sit until it's calm but I can still feel heat from the surface. Basically "boiled" water and not "boiling" water. Link to comment https://bolterandchainsword.com/topic/339462-fw-heavy-weapon-cables/#findComment-4888359 Share on other sites More sharing options...
Brother-Chaplain Kage Posted September 17, 2017 Share Posted September 17, 2017 Depending on the size of whatever I'm going to soften up in the water, I either use a hemostat (surgical locking clamp) or some grilling tongs for the big stuff. I never drop the item into the boiling water but keep hold of it the entire time. Link to comment https://bolterandchainsword.com/topic/339462-fw-heavy-weapon-cables/#findComment-4888360 Share on other sites More sharing options...
Lorenzen Posted September 17, 2017 Share Posted September 17, 2017 Use a hair dryer. You can glue one end to the gun/backpack and then bend the feeds and glue them instantly can also use this to rework the feeds once tgeyre glued if you have a specific shape in mind Link to comment https://bolterandchainsword.com/topic/339462-fw-heavy-weapon-cables/#findComment-4888438 Share on other sites More sharing options...
Grim Dog Studios Posted September 17, 2017 Share Posted September 17, 2017 I usually just boil the kettle and pour the boiling water into a bowl and use that to bend any bits that need bending. Link to comment https://bolterandchainsword.com/topic/339462-fw-heavy-weapon-cables/#findComment-4888502 Share on other sites More sharing options...
Ovidius Incertus Posted September 17, 2017 Share Posted September 17, 2017 I just put a teacup in the microwave for like 1 or 1.5 minutes unless it's a big part that would require more water, then I use a pan. Other than that, I follow BCK's process. Link to comment https://bolterandchainsword.com/topic/339462-fw-heavy-weapon-cables/#findComment-4888518 Share on other sites More sharing options...
Studio Silvernale Posted September 17, 2017 Author Share Posted September 17, 2017 Thanks for all the responses. Link to comment https://bolterandchainsword.com/topic/339462-fw-heavy-weapon-cables/#findComment-4888551 Share on other sites More sharing options...
