skarn Posted September 22, 2017 Share Posted September 22, 2017 What is the best load out for gk? I dont use razorbacks so I tend to go for MM/las, but the assault cannon/typhoon combo looks interesting too. Link to comment https://bolterandchainsword.com/topic/339673-stormraven-load-out/ Share on other sites More sharing options...
Danarc Posted September 22, 2017 Share Posted September 22, 2017 I use it as anti infantry so I set my SR with assault cannon, HB and hurricane bolters. But also the anti tank load out is quite good, even if it is more expansive. Link to comment https://bolterandchainsword.com/topic/339673-stormraven-load-out/#findComment-4892687 Share on other sites More sharing options...
Seizeman Posted September 22, 2017 Share Posted September 22, 2017 Assault cannon and melta are the most efficient options. On the turret, it's between assault cannon and laser. You can take laser if you already have enough anti-infantry, but it is significantly more expensive so usually there's no spare points to purchase it. Otherwise, assault cannons are just the more generally useful weapon. On the front it is a lot easier. Bolter is very mediocre, specially when you already have assault cannons. The typhoon is just a much worse anti-tank weapon than the melta, so there's no reason to not take the melta instead. Link to comment https://bolterandchainsword.com/topic/339673-stormraven-load-out/#findComment-4892721 Share on other sites More sharing options...
Corvus Fortis Posted September 22, 2017 Share Posted September 22, 2017 I stick to using laser turret with multimelta. My army is always full of stormbolters to deal with infantry and Raven already has hurricanes. Assault cannon is decent though. Very good at dealig with MEQs and GEQs, can scratch vehicles too by sheer number of shots. But you can do the same with psybolt ammo. With psybolt hurricanes you deal the same damage to everything, just wound GEQs on 3+, not 2+. Bolter is puny. Good synergy with psybolt hurricanes, but 6 shots are just pathetic. Can scare a Marine unit, though. I won't use it even to save points. Multi-melta is a beast against vehicles. Typhoon is only 4 points cheaper, but can be effective against armies with 5+ invuln vehicles. Frag mode help with hordes. In short, I prefere antivehicle loadout just because GK has very few ranged AV options. If there are lots of Orks and Nids in your meta, assault cannon with Typhoon are better, of course. Link to comment https://bolterandchainsword.com/topic/339673-stormraven-load-out/#findComment-4892779 Share on other sites More sharing options...
skarn Posted September 23, 2017 Author Share Posted September 23, 2017 Typhhon looks insteresting because its not that much wprse than the melta, but is also anti infantry if needed. But maybe I'll stick with las/mm. Link to comment https://bolterandchainsword.com/topic/339673-stormraven-load-out/#findComment-4893396 Share on other sites More sharing options...
Seizeman Posted September 23, 2017 Share Posted September 23, 2017 The melta is literally twice as good as the typhoon vs vehicles. AP -2 really hurts the missile, and the melta rule is very significant. It's not worth just for the option of killing a couple of guardsmen. If you run out of good targets for the melta you have probably won already. Adeptus and skarn 2 Back to top Link to comment https://bolterandchainsword.com/topic/339673-stormraven-load-out/#findComment-4893483 Share on other sites More sharing options...
skarn Posted September 24, 2017 Author Share Posted September 24, 2017 So ideally las or assault cannon? Link to comment https://bolterandchainsword.com/topic/339673-stormraven-load-out/#findComment-4893984 Share on other sites More sharing options...
AnImA8 Posted September 25, 2017 Share Posted September 25, 2017 Really just depends on the meta. If you got a lot of tank wielding marines, take the las/mm. If you've got more gribblies take the Assault Cannon/Typhoon skarn 1 Back to top Link to comment https://bolterandchainsword.com/topic/339673-stormraven-load-out/#findComment-4895520 Share on other sites More sharing options...
Reclusiarch Darius Posted September 30, 2017 Share Posted September 30, 2017 I'm going with twin las and melta, plus hurricane sponsons. With that loadout plus its missile launchers, you can obliterate a key enemy vehicle or two Turn 1, and still hose down an infantry squad with extra bolter to support your infantry storm bolter dakka. AnImA8 1 Back to top Link to comment https://bolterandchainsword.com/topic/339673-stormraven-load-out/#findComment-4899389 Share on other sites More sharing options...
