Hopper21 Posted September 25, 2017 Share Posted September 25, 2017 Shooting the obvious today at at work, we discussed that if you used the hellfire rounds strategem on a dev squad marine and the cherub you could use it twice for the the use of 1 Cp? Anyone tried this at All? Looking at wording seems reasonable. Link to comment https://bolterandchainsword.com/topic/339805-hellfire-rounds-and-armourim-cherib/ Share on other sites More sharing options...
harrybo Posted September 25, 2017 Share Posted September 25, 2017 Good question but I think it's a no unfortunately. The wording for the Hellfire shells stratagem says you only make a single hit roll with this weapon THIS PHASE. But then the cherub rule says the model can immediately shoot again, which overrules the BRB regarding shooting but doesn't get around the wording of the statagem itself limiting the model to firing once this phase. But I could be wrong... Hopper21 1 Back to top Link to comment https://bolterandchainsword.com/topic/339805-hellfire-rounds-and-armourim-cherib/#findComment-4895310 Share on other sites More sharing options...
Frater Cornelius Posted September 26, 2017 Share Posted September 26, 2017 Well, the way I see it is that your HB can fire twice with the Cherub, but only one of those shots csn be Hellfire. derLumpi, CaptainMarsh, KhorneHunter57x and 2 others 5 Back to top Link to comment https://bolterandchainsword.com/topic/339805-hellfire-rounds-and-armourim-cherib/#findComment-4895559 Share on other sites More sharing options...
CaptainMarsh Posted September 26, 2017 Share Posted September 26, 2017 I believe Frater is correct. Hellfire Shells doesn't change the Heavy Bolter's profile or change the type or anything that would be allowable to be used twice by a wording miscue. Hellfire Shells doesn't change the heavy bolter attack profile, it uses the Heavy Bolter to make an attack as part of the strategem. So you would select the model with the HB fire, would use the Strategem, use the Cherub, and then fire your Heavy Bolter normally. Hopper21 1 Back to top Link to comment https://bolterandchainsword.com/topic/339805-hellfire-rounds-and-armourim-cherib/#findComment-4895562 Share on other sites More sharing options...
Hopper21 Posted September 28, 2017 Author Share Posted September 28, 2017 Thanks everyone you've all confirmed what I said! Link to comment https://bolterandchainsword.com/topic/339805-hellfire-rounds-and-armourim-cherib/#findComment-4897674 Share on other sites More sharing options...
Kallas Posted September 28, 2017 Share Posted September 28, 2017 you've all confirmed what I said! I mean, that's one way to interpret, "No." :P Stoic Raptor and Hopper21 2 Back to top Link to comment https://bolterandchainsword.com/topic/339805-hellfire-rounds-and-armourim-cherib/#findComment-4897714 Share on other sites More sharing options...
