swordofmandulis Posted September 28, 2017 Share Posted September 28, 2017 Guys, here's a question, can the Brotherhood Champion do Heroic Sacrifice to fight when killed, and use the stratagem Only in death to fight when killed enabling 2 additional fights before being removed? thanks Link to comment https://bolterandchainsword.com/topic/339900-brotherhood-champion-heroic-sacrifice-only-in-death/ Share on other sites More sharing options...
Muaddib Posted September 28, 2017 Share Posted September 28, 2017 Hum... It's v8 40k, if nothing says you can't, then you can. MosDef. I think. Probably. Maybe. Link to comment https://bolterandchainsword.com/topic/339900-brotherhood-champion-heroic-sacrifice-only-in-death/#findComment-4897765 Share on other sites More sharing options...
Gentlemanloser Posted September 28, 2017 Share Posted September 28, 2017 No reason you can't use both. Both trigger on the BC being slain and both are used before he's removed as a casualty. Link to comment https://bolterandchainsword.com/topic/339900-brotherhood-champion-heroic-sacrifice-only-in-death/#findComment-4897843 Share on other sites More sharing options...
swordofmandulis Posted September 28, 2017 Author Share Posted September 28, 2017 so if I can deliver my BroChamp to something big and scary and make the charge assuming I took the "Hammer of Righteousness" warlord trait, I get hammerhand off, and I select the blade strike stance I can deliver 12 attacks, hitting on 2's, wounding up to T7 on 2's (adding 1 for WT, 1 for hammer hand and 1 for blade stike), D3 damage. pretty sure anything in the game should be scared of that. Link to comment https://bolterandchainsword.com/topic/339900-brotherhood-champion-heroic-sacrifice-only-in-death/#findComment-4897851 Share on other sites More sharing options...
Gentlemanloser Posted September 28, 2017 Share Posted September 28, 2017 (edited) That would cause on average 16.7 damage. An Apothecary using Only in Death (no warlord trait) also deals 16.7 damage, facing up to T8. With the same -3AP. You could give him the relic hammer or the nemesis lord warlord trait to buff that even more. Edit. Which would take him to 22.2 damage! And he's 10 points cheaper. Not HQ slot, but has the regen. Edited September 28, 2017 by Gentlemanloser Link to comment https://bolterandchainsword.com/topic/339900-brotherhood-champion-heroic-sacrifice-only-in-death/#findComment-4897865 Share on other sites More sharing options...
skarn Posted September 28, 2017 Share Posted September 28, 2017 I reckon its only a matter of time until the apothecary gets nerfed. He is so much better than any of our troops. Link to comment https://bolterandchainsword.com/topic/339900-brotherhood-champion-heroic-sacrifice-only-in-death/#findComment-4897921 Share on other sites More sharing options...
swordofmandulis Posted September 28, 2017 Author Share Posted September 28, 2017 (edited) I could easily be wrong, I have the apothecary (4 attacks hitting on 3's) with OiD and HH up and no WT doing 13.14 Damage up to T7 and 10.44 vs T8 Brotherhood Champion (4 attacks hitting on 2's) with WT/HH/BS and OiD doing 16.53 up to T7 and 13.14 vs T8 Apothecary with Relic Hammer, HH and OiD tops the Brochamp with 17.52 up to T7 and 13.92 vs T8 how did you get to 22.2? Just did some more maths (if mine is correct) its actually better to have the Nemesis lord trait on the Brochamp and wound T5-7 on 3's and T8 on 4's. I'm getting 24.78 vs T4, 19.71 vs T5-T7 and 14.94 vs T8 some one please tell me if the numbers are off though. Edited September 28, 2017 by swordofmandulis Waking Dreamer 1 Back to top Link to comment https://bolterandchainsword.com/topic/339900-brotherhood-champion-heroic-sacrifice-only-in-death/#findComment-4897938 Share on other sites More sharing options...
Gentlemanloser Posted September 28, 2017 Share Posted September 28, 2017 Opps. Seems i have been cheating a little. ;) I thought he had 5A. Link to comment https://bolterandchainsword.com/topic/339900-brotherhood-champion-heroic-sacrifice-only-in-death/#findComment-4898004 Share on other sites More sharing options...
swordofmandulis Posted September 28, 2017 Author Share Posted September 28, 2017 No doubt the Apothecary is a beast, I usually have one in my bigger lists, this is for a 750pt doubles list so the cheap HQ is useful. I'll give the Brotherhood Champion a run out and see if he does a good job. Link to comment https://bolterandchainsword.com/topic/339900-brotherhood-champion-heroic-sacrifice-only-in-death/#findComment-4898057 Share on other sites More sharing options...
Gentlemanloser Posted September 28, 2017 Share Posted September 28, 2017 HH doesn't help an Apoth until T9 up. He wounds on 2+ T8 and below, and a roll of 1 is always a fail. Link to comment https://bolterandchainsword.com/topic/339900-brotherhood-champion-heroic-sacrifice-only-in-death/#findComment-4898147 Share on other sites More sharing options...
Helycon Posted September 28, 2017 Share Posted September 28, 2017 HH doesn't help an Apoth until T9 up. He wounds on 2+ T8 and below, and a roll of 1 is always a fail. A hammer Apothecary is S8, therefore wounding anything of T5 and over on a 3+, and T8 on a 4+, or am I missing something? Link to comment https://bolterandchainsword.com/topic/339900-brotherhood-champion-heroic-sacrifice-only-in-death/#findComment-4898184 Share on other sites More sharing options...
Gentlemanloser Posted September 28, 2017 Share Posted September 28, 2017 Gah! Ignore me.... For some reason i was looking at s8 wounding t8 in 2's. Think ill go back to bed. Today has been a wash. Link to comment https://bolterandchainsword.com/topic/339900-brotherhood-champion-heroic-sacrifice-only-in-death/#findComment-4898212 Share on other sites More sharing options...
Seizeman Posted September 28, 2017 Share Posted September 28, 2017 It is not an issue of the apothecary being too good, is an issue of most of our units being too expensive. Except for razorbacks, storm ravens, strikes and maybe GMNDKs, every unit needs a cost reduction. Link to comment https://bolterandchainsword.com/topic/339900-brotherhood-champion-heroic-sacrifice-only-in-death/#findComment-4898286 Share on other sites More sharing options...
Danarc Posted September 28, 2017 Share Posted September 28, 2017 Actually with hammerhand apo with hammer wounds T5+ with 2+ and T8+ with 3+ ;) Link to comment https://bolterandchainsword.com/topic/339900-brotherhood-champion-heroic-sacrifice-only-in-death/#findComment-4898406 Share on other sites More sharing options...
Waking Dreamer Posted September 28, 2017 Share Posted September 28, 2017 I could easily be wrong, I have the apothecary (4 attacks hitting on 3's) with OiD and HH up and no WT doing 13.14 Damage up to T7 and 10.44 vs T8 Brotherhood Champion (4 attacks hitting on 2's) with WT/HH/BS and OiD doing 16.53 up to T7 and 13.14 vs T8 Apothecary with Relic Hammer, HH and OiD tops the Brochamp with 17.52 up to T7 and 13.92 vs T8 how did you get to 22.2? Just did some more maths (if mine is correct) its actually better to have the Nemesis lord trait on the Brochamp and wound T5-7 on 3's and T8 on 4's. I'm getting 24.78 vs T4, 19.71 vs T5-T7 and 14.94 vs T8 some one please tell me if the numbers are off though. So with the right setup the BroChamp exceeds the Apoth even if the latter gets the relic hammer? Nice...seems good for a killy HQ who costs more than the Apoth. Link to comment https://bolterandchainsword.com/topic/339900-brotherhood-champion-heroic-sacrifice-only-in-death/#findComment-4898412 Share on other sites More sharing options...
skarn Posted September 29, 2017 Share Posted September 29, 2017 This is all assuming that you can combo the rule with the strategem. I'm not convinced, and I think your opponents wont be either. Link to comment https://bolterandchainsword.com/topic/339900-brotherhood-champion-heroic-sacrifice-only-in-death/#findComment-4898513 Share on other sites More sharing options...
Captain Coolpants Posted September 29, 2017 Share Posted September 29, 2017 Well if a squad of 20 khorne bazerkrs can stack their stratagems with their special rule allowing 3 fight phases in 1 turn, then I really doubt they'll bitch about a single guy doing the same... Link to comment https://bolterandchainsword.com/topic/339900-brotherhood-champion-heroic-sacrifice-only-in-death/#findComment-4898561 Share on other sites More sharing options...
Helycon Posted September 29, 2017 Share Posted September 29, 2017 Actually with hammerhand apo with hammer wounds T5+ with 2+ and T8+ with 3+ ;) I know. Since Gentleman wasn't using HH, neither was I :) Link to comment https://bolterandchainsword.com/topic/339900-brotherhood-champion-heroic-sacrifice-only-in-death/#findComment-4898688 Share on other sites More sharing options...
