Wayniac Posted September 28, 2017 Share Posted September 28, 2017 I have a cool idea to run a list that has a unit of Deathshroud w/a Lord of Contagion and a unit of Blightlord Terminators teleporting in to wreck havoc. I'm thinking of how to build the Blightlords from the box contents itself (no buying multiple boxes or hunting for bits). From what we can tell, the box has 4x axes (not sure of how many swords but probably about the same), 1x of each combi-weapon, 1x of each special weapon, and 1x flail of corruption. The obvious choice for the unit would be: Champion w/Balesword (not enough axes to give him one, and it makes him look different) 1x Flail of Corruption (a given/must-take) 1x special weapon + Axe 2x combi-bolters + axe Is adding a single special combi-weapon worth it, do you think? Probably combi-plasma, as it seems the most versatile. I'm thinking of the following unit: 5 Blightlord Terminators (254 points / 14 Power) - Champion w/Combi-Bolter, Balesword - 1x Combi-Plasma, Bubotic Axe - 1x Flail of Corruption - 1x Combi-Bolter, Bubotic Axe - 1x Blight Launcher, Bubotic Axe What do you think? I'm trying to avoid having to scrounge around for combi-plasma or whatnot, and this seems like a good unit that can be built from the box contents and pack a punch, especially if they are teleported in alongside a unit of 3 Deathshroud Terminators and a Lord of Contagion. Link to comment https://bolterandchainsword.com/topic/339907-equipping-blightlord-terminators-from-the-box/ Share on other sites More sharing options...
happyslugger Posted September 28, 2017 Share Posted September 28, 2017 I shall just put whatever guns they come with on and just say they are combi x or y. I converted combi melta and plasma for my old terminators (that I can't use now) and don't think I will bother this time around. Link to comment https://bolterandchainsword.com/topic/339907-equipping-blightlord-terminators-from-the-box/#findComment-4897903 Share on other sites More sharing options...
Blackheart1223 Posted September 28, 2017 Share Posted September 28, 2017 I have a crap ton of Calth pistols to use to make combi-plasma with, so using just the box isn't so bad. I am interested to see how easy it will be to magnetize these though. General Strike 1 Back to top Link to comment https://bolterandchainsword.com/topic/339907-equipping-blightlord-terminators-from-the-box/#findComment-4897909 Share on other sites More sharing options...
Interrogator-Chaplain Ezra Posted September 28, 2017 Share Posted September 28, 2017 I have a crap ton of Calth pistols to use to make combi-plasma with, so using just the box isn't so bad. I am interested to see how easy it will be to magnetize these though. Same. I'll probably do combi-melta myself. Link to comment https://bolterandchainsword.com/topic/339907-equipping-blightlord-terminators-from-the-box/#findComment-4897985 Share on other sites More sharing options...
Jbird Posted September 28, 2017 Share Posted September 28, 2017 I'll probably be running with 3 combi-meltas and a blight launcher. Was thinking about the reaper autocannon to put strength 7's on vehicles, but I guess blight launcher has better synergy being an assault weapon like the meltas. Expensive but dropping 3 meltas in plus a blight launcher will hopefully guarantee putting the hurt on a high toughness target, and give your opponent something else to worry about other than focus firing on Morty Link to comment https://bolterandchainsword.com/topic/339907-equipping-blightlord-terminators-from-the-box/#findComment-4898126 Share on other sites More sharing options...
Guidebot Posted September 28, 2017 Share Posted September 28, 2017 I was probably going to have a cheap squad; 4x Bubotic Axes, 1x Flail (comes out to like 220 pts or so I think) and an expensive Squad (4x plasma). Link to comment https://bolterandchainsword.com/topic/339907-equipping-blightlord-terminators-from-the-box/#findComment-4898330 Share on other sites More sharing options...
MoGuy Posted September 28, 2017 Share Posted September 28, 2017 Just build mine. There are only 3x axes and swords in a box. Link to comment https://bolterandchainsword.com/topic/339907-equipping-blightlord-terminators-from-the-box/#findComment-4898343 Share on other sites More sharing options...
Blackheart1223 Posted September 29, 2017 Share Posted September 29, 2017 So you're pretty much forced into mixed Weapon loadouts. Though expensive, I'm really liking the idea of combi-meltas and a blight launcher. Since they are M4" being able to advance and fire at full effect can be handy. Link to comment https://bolterandchainsword.com/topic/339907-equipping-blightlord-terminators-from-the-box/#findComment-4898444 Share on other sites More sharing options...
TURBULENCE Posted September 29, 2017 Share Posted September 29, 2017 I was going to build my first unit that way too. Axes, Meltas and a launcher, and a flail, second unit I was planning going swords, combi plasma, and an autocannon. Two boxes should give me all I need, and converting a couple of combi weapons will be child's play Link to comment https://bolterandchainsword.com/topic/339907-equipping-blightlord-terminators-from-the-box/#findComment-4898459 Share on other sites More sharing options...
DuskRaider Posted September 29, 2017 Share Posted September 29, 2017 I'm planning Combi-Melta x 5, Flail of Corruption, and Blight Launcher for my first squad with a mix of Bubotic Axes and Baleswords. Link to comment https://bolterandchainsword.com/topic/339907-equipping-blightlord-terminators-from-the-box/#findComment-4898482 Share on other sites More sharing options...
Fhanados Posted September 29, 2017 Share Posted September 29, 2017 Just curious, what's everyone's reasoning for using combi-melta over combi-plasma. Most people seem pretty decided that plasma is better than melta so I find it really interesting that a fair few of you have settled on melta. Link to comment https://bolterandchainsword.com/topic/339907-equipping-blightlord-terminators-from-the-box/#findComment-4898488 Share on other sites More sharing options...
DuskRaider Posted September 29, 2017 Share Posted September 29, 2017 Melta = Assault. That's pretty much it, I use Plasma on all of my Plague Marines for the ranged benefit. The Blightlords are in your face, I'm going to DS in your deployment zone and melt you ASAP. They benefit more. Link to comment https://bolterandchainsword.com/topic/339907-equipping-blightlord-terminators-from-the-box/#findComment-4898496 Share on other sites More sharing options...
Cryptix Posted September 29, 2017 Share Posted September 29, 2017 I'm planning Combi-Melta x 5, Flail of Corruption, and Blight Launcher for my first squad with a mix of Bubotic Axes and Baleswords. Squad of 7 right? Might want to make that clear because that brings up strange mental images of a blight launcher in one hand, a combi-melta in the other, and a melee weapon somewhere. Link to comment https://bolterandchainsword.com/topic/339907-equipping-blightlord-terminators-from-the-box/#findComment-4898510 Share on other sites More sharing options...
Bloody Legionnaire Posted September 29, 2017 Share Posted September 29, 2017 anybody know if the praetors combi-melta from BaC is the correct scale for blightlords? Link to comment https://bolterandchainsword.com/topic/339907-equipping-blightlord-terminators-from-the-box/#findComment-4898511 Share on other sites More sharing options...
DuskRaider Posted September 29, 2017 Share Posted September 29, 2017 I'm planning Combi-Melta x 5, Flail of Corruption, and Blight Launcher for my first squad with a mix of Bubotic Axes and Baleswords. Squad of 7 right? Might want to make that clear because that brings up strange mental images of a blight launcher in one hand, a combi-melta in the other, and a melee weapon somewhere. Ah yes, definitely squads of 7. Link to comment https://bolterandchainsword.com/topic/339907-equipping-blightlord-terminators-from-the-box/#findComment-4898542 Share on other sites More sharing options...
jlmb_123 Posted September 29, 2017 Share Posted September 29, 2017 I'm planning Combi-Melta x 5, Flail of Corruption, and Blight Launcher for my first squad with a mix of Bubotic Axes and Baleswords. Squad of 7 right? Might want to make that clear because that brings up strange mental images of a blight launcher in one hand, a combi-melta in the other, and a melee weapon somewhere. "It was horrifying, stalking towards us pumping rounds from some kind of huge grenade launcher and turning everything to slag with its meltagun. It leared through pus-filled, cataract-glazed eyes as pus wept from its armour joints. I thought it was the worst sight I'd ever had the misfortune to see .. until it turned around and we saw where it kept its sword ..." Lt. A. Flax, Mordian 21st Iron Guard, survivor of the Heol Ridge "Bumrush" massacre (shortly deceased, awarded penicillin posthumously). Plaguecaster, Eire, Gumo9 and 9 others 12 Back to top Link to comment https://bolterandchainsword.com/topic/339907-equipping-blightlord-terminators-from-the-box/#findComment-4898655 Share on other sites More sharing options...
Gumo9 Posted September 29, 2017 Share Posted September 29, 2017 ^^ nearly choked on my cup of tea. Well played sir ! ^^ Link to comment https://bolterandchainsword.com/topic/339907-equipping-blightlord-terminators-from-the-box/#findComment-4898710 Share on other sites More sharing options...
SkimaskMohawk Posted September 29, 2017 Share Posted September 29, 2017 Melta = Assault. That's pretty much it, I use Plasma on all of my Plague Marines for the ranged benefit. The Blightlords are in your face, I'm going to DS in your deployment zone and melt you ASAP. They benefit more. Except they're not in Melta range off of deepstrike. In subsequent turns you can run a little to get some more value out of them, but Melta out of the range isnt the most reliable of weapons. Generally for high cost deepstrikers, you need them to really kill priority targets and make some impact before they get swatted; Plasma with inexorable let's you rapid fire over bubble wrap, while can be pushed out of any range and at best is relying on 1 die Link to comment https://bolterandchainsword.com/topic/339907-equipping-blightlord-terminators-from-the-box/#findComment-4898728 Share on other sites More sharing options...
DuskRaider Posted September 29, 2017 Share Posted September 29, 2017 Melta = Assault. That's pretty much it, I use Plasma on all of my Plague Marines for the ranged benefit. The Blightlords are in your face, I'm going to DS in your deployment zone and melt you ASAP. They benefit more. Except they're not in Melta range off of deepstrike. In subsequent turns you can run a little to get some more value out of them, but Melta out of the range isnt the most reliable of weapons. Generally for high cost deepstrikers, you need them to really kill priority targets and make some impact before they get swatted; Plasma with inexorable let's you rapid fire over bubble wrap, while can be pushed out of any range and at best is relying on 1 die Fair enough. I haven't built them yet since they haven't been released yet / I don't have the connection unlike some lucky SOBs. I'll give Plasma some consideration, overall it's better than Melta in 8th but I was willing to give Melta a shot (no pun intended). Link to comment https://bolterandchainsword.com/topic/339907-equipping-blightlord-terminators-from-the-box/#findComment-4898744 Share on other sites More sharing options...
ArtificerArmour Posted September 29, 2017 Share Posted September 29, 2017 So what exactly do you get in the blightlord box? 3 axes 3 swords 5 combi bolters 3x special combi addons 3 special weapons 1 flail? So 6x left arms, 8 right arms, 1 flail with L&R arms? Link to comment https://bolterandchainsword.com/topic/339907-equipping-blightlord-terminators-from-the-box/#findComment-4898759 Share on other sites More sharing options...
General Strike Posted September 29, 2017 Share Posted September 29, 2017 The weapons are all attached to the arms already. DuskRaiderDave 1 Back to top Link to comment https://bolterandchainsword.com/topic/339907-equipping-blightlord-terminators-from-the-box/#findComment-4898897 Share on other sites More sharing options...
Vissah Posted September 29, 2017 Share Posted September 29, 2017 I like playing 1000 points max the best so if I field them I will keep them dirt cheap with combi-bolters and probably a reaper autocannon. Link to comment https://bolterandchainsword.com/topic/339907-equipping-blightlord-terminators-from-the-box/#findComment-4898921 Share on other sites More sharing options...
Lachdannan Posted October 1, 2017 Share Posted October 1, 2017 I plan on equipping mine all with combi-plas (I am really liking the new plas revolution, the one where my troops don't kill themselves through overheating!), and a blight launcher. Not too sure of the flail, but might do so as it looks cool. Link to comment https://bolterandchainsword.com/topic/339907-equipping-blightlord-terminators-from-the-box/#findComment-4899962 Share on other sites More sharing options...
Urauloth Posted October 3, 2017 Share Posted October 3, 2017 From the box with no conversions? Yes, I think 3 axes, a flail and the launcher is the best setup. I'd definitely take a combi with that if you have the points (always if you're using power). I'm building my first box now and I'm going to mag the heavy weapons in case I want to try out an autocannon squad in the future, and I'll see if it's possible to do the same with the combiweapon options. Should be. I plan on getting a second box soon and for smaller games I'll try pooling the axes and combiweapons into one squad. Link to comment https://bolterandchainsword.com/topic/339907-equipping-blightlord-terminators-from-the-box/#findComment-4902162 Share on other sites More sharing options...
Lagrath Posted October 3, 2017 Share Posted October 3, 2017 I am really torn between all combi-plasma and all combi-melta, and whether or not to add a blight launcher in there. The 18" double tap range on combi plasma seems really strong to me. On the other hand, I think few things in this game can do as much as meltaguns, and having a bunch of meltaguns on a tough to kill unit seems powerful (advancing and firing at -1 seems good too). Link to comment https://bolterandchainsword.com/topic/339907-equipping-blightlord-terminators-from-the-box/#findComment-4902170 Share on other sites More sharing options...
