Impact1 Posted October 6, 2017 Share Posted October 6, 2017 I've been building terrain and modeling in general for years. I've used tree basic methods. Punching bumps into plastic/metal using a modified 1/16" hole punch. Glueing small rhinestones or finger nail cabs onto flat surfaces. Or gluing finger nail caviar micro beads into divits. But I recently found a tool that makes the first method much easier, and more reliable. The ImpressArt hole punch pliers. the tip is removable/replaceable, and it has a set screw/stop, that makes it foolproof for maing rivit headas without punching through the material, even thin acrylic! You still have to reshape the tip, as described at Ironhand.com. http://www.alchemyandice.com/images/D/hole-punch-montage.jpg I picked them up michaels.com and used a %50 percent off coupon from their home page. You still have to reshape the tip, as described at Ironhand.com. http://www.ironhands.com/h2rivet2.jpg reckoning, Azekai, Markus_ and 3 others 6 Back to top Link to comment https://bolterandchainsword.com/topic/340154-making-rivets-reduex/ Share on other sites More sharing options...
JGeils81 Posted October 24, 2017 Share Posted October 24, 2017 looks good! won't work in every application, but can definitely cut down on labor on some pieces! Link to comment https://bolterandchainsword.com/topic/340154-making-rivets-reduex/#findComment-4916319 Share on other sites More sharing options...
